AdrianMF Posted February 9, 2019 Share Posted February 9, 2019 Lovely aeroplane and brilliantly set off by the diorama base and background. Smashing! Regards, Adrian 1 Link to comment Share on other sites More sharing options...
crobinsonh Posted February 9, 2019 Share Posted February 9, 2019 Great job - how difficult/challenging was the build. I have 2 with all the Goffy resin/PE as well. 1 Link to comment Share on other sites More sharing options...
Viking Posted February 9, 2019 Share Posted February 9, 2019 Another superb build Russ, I particularly like the the painted out larger roundels under the little ones. Lovely layout too! Cheers John 1 Link to comment Share on other sites More sharing options...
russ c Posted February 9, 2019 Author Share Posted February 9, 2019 5 hours ago, crobinsonh said: Great job - how difficult/challenging was the build. I have 2 with all the Goffy resin/PE as well. Hi crob`, it`s the second time I`ve built it so it wasn`t too hard this time around. Just make sure you glue the internal bulkheads to the fuselage securely, because those wings are heavy and you`ll end up with a bit of anhedral in no time at all. The rest of it: measure twice cut once applies. I glued some small squares of plastic sheet at the wing roots to make sure everything stayed level and inline when I attached the wings. Oh and I epoxy`d a bit of chopped up clothes peg between the exhausts to make sure they stayed put. Nothing horrendous. Hope this helps Cheers Russ Link to comment Share on other sites More sharing options...
Hewy Posted February 9, 2019 Share Posted February 9, 2019 Another beautifully finished model russ, eye candy that 1 Link to comment Share on other sites More sharing options...
