Michael M
ORP Krakowiak, IBG, 1:700
😂 there is no white screen .  I've drawn new PE railings and few other bits and just printed them on paper for shape testing.
I know it's a bit early in your build, but have you decided on what technique you're going to use on the water?  I only ask because have just started to build the Mirage 1/350 Mazure and put her afloat.  This will be my first attempt at floating my boat and am a little nervous  (😨!!!)
Edited by Fizgig
46 minutes ago, Richard502 said:
Thank you for the tip about using clear cote on paper!.
Need to try, till now I used very thin CA, and the paper gets hard so it can be sanded into shape, but it is also brittle..
Well, that's not something you see every day, masking of a ship, thanks.
@Bandsaw Steve might be interested in this after he asked the question on his Carpathia build.
Stuart
Great to see what can be done at this scale and I'm sure it'll get more impressive as time goes on.
Can I ask, what greys you have used before and after masking?
Stuart
Thanks. Decks: grey tamiya primer then shadows around superstructures and other protruding bits with XF24 misted over with base colour XF75. Then masking the shape of anti slip coatings. Again shadows done with XF63 then highlights with white, afterwards misted over with base XF77.
Airbrushing phase of the hull done and dusted. I'll start playing with oils after Easter.
Thanks for watching.
What do you think about G45 Jamie?
Washes done, I'll let it dry for a few days, then move on to fouling scratching and general destruction ;)
base with the socket...
in the socket, in the tomb ;)
Thanks for watching
Mick
Paper templates?
Looks good, the trick with paper and CA I knew, but with the clear can be more handy, when it makes the paper less brittle... is it hard enough then so that you are able to sand the paper also then?
I somehow missed this one. What amazing modelling in 1/700! Really like your approach here.
Terry
Water of shame ;) ah well you can't win all the time. It won't go to the bin, I always use mishaps  like this for testing stuff ;) I'll start new one tomorrow...
Mick
