Dadias Posted February 4, 2019 Share Posted February 4, 2019 Hello, as the title suggests, I have in my possession a Tiger 1 built almost a decade ago, unfortunately it was packed and stored in the basement for many years and some dust came through, I am wondering if a renovation is possible and what to look out for, I am thinking about repainting it and fixing some flaws I did back then Thank you in advance Dimitris "Dadias" Link to comment Share on other sites More sharing options...
Karlj72 Posted February 4, 2019 Share Posted February 4, 2019 What kit is it? I only ask as if it was a cheap kit maybe just use it as a test model and rebuy the kit again. Or if it's worth saving then try and strip the paint off and do a repaint,now you need some oven cleaner the foam type and leave in a plastic bag for a few hours that should shift the paint, then wash in warm water and leave to dry. What paint did you originally paint it in? Good luck 1 Link to comment Share on other sites More sharing options...
Dadias Posted February 4, 2019 Author Share Posted February 4, 2019 Well it's the dragon tiger 1 late model w/out zimmerit. If I remember correctly, I used revel paints Thank you Link to comment Share on other sites More sharing options...
Karlj72 Posted February 4, 2019 Share Posted February 4, 2019 Sounds like the 3 in 1 kit well worth saving. Did you apply a zimmerit to the model? Revell enamel or acrylic,still the oven cleaner might get enamel off but never tried before only acrylic paints. Link to comment Share on other sites More sharing options...
Dadias Posted February 4, 2019 Author Share Posted February 4, 2019 No haven't applied zimmerit on the tank, if I remember correctly it was enamel. Thank you very much for your tips, I will try it out Link to comment Share on other sites More sharing options...
Bullbasket Posted February 5, 2019 Share Posted February 5, 2019 If I was to do something like this, I'd try and remove all of the small detail such as machine guns, tow cables, pioneer tools etc. They are going to get damaged in the clean up process, so why not remove and replace with new items? There is a material that you can buy, I think that it's called Modelstrip, made specifically for stripping old enamel paint from models. Good luck with it. John. 1 Link to comment Share on other sites More sharing options...
