vppelt68
*done* At least I tried...
...but no promises! Having just finished two B-17:s I thought it´d be tempting to try "a little" smaller model, so here we are, wish me luck! V-P
2019-02-04_10-38-51
Good luck. Try to think of it as a Blitz build with a few extra days.
A single colour scheme I presume?
Colin
No no, full FAA scheme with Etoiles Americains to intimidate the Vichy French during Op. Torch. The kit includes decal options for Torch, but as I have a Blackbird Models decal set, I'll use it instead. Managed to assemble the landing gear, more delicate parts there than in a complete Fortress kit! V-P
Brave effort sir! Best of good luck with it.
Good afternoon VP
 I really hope you will make it before the end of the Gb ...
Patrice
Thank you all for your warm welcomes! I decided to build the little cat (what is a martlet, by the way?) with her wings spread and landing gear down. After removing the unnecessary parts and assembling some subassemblies, what was left is drastically reduced compared to the opening picture above. Now I can´t do much before I´ve let all that paint dry :hmmm:but the fuselage should be buttoned up with wings and empennage fitted tonight. I won´t forget that landing gear assembly soon... V-P
2019-02-04_02-56-14
Hello VP
Very nice Start ..
But believe me You must follow the building instruction for the landing gear because if you want to close the fuselage and then after that place the underccariage it is almost impossible to do ...
Patrice
I believe you Patrice, and I already attached the LG to cockpit front bulkhead. V-P
The Martlet is (was?) a stylised bird used on heraldic devices. Nice work on the internal paint, it should fairly fly together now if all the mating surfaces are clean :)
And I'm trying really hard! Thanks for the advice Col. I did scrape those surfaces clean but still it was a pretty tight squeeze. So day 1 done, 6 more left to go 😊.
2019-02-04_11-14-11
The thing about the martlet is that it has no feet, so can't land. Hence it must stay aloft, eternally questing, ever vigilant. Somewhat appropriate for a naval fighter.
That's amazing progress for one day's effort! :speak_cool:
Good morning
I agree with Col for a one day's work the progress is amazing I guess VP will finish this build in time ..
Very good job so far V-P , maybe you could even build another one  ..
Patrice
Thanks Patrice but I have no more Grummans in my stash, and a nice little (compared to a Fortress, but not to a Martlet) Airfix Mitchell that I´m itching to get started after this!
I sanded the seams this morning and then washed the little bird. This evening I try to brush on Hu 90 all over her, as a first layer of paint for the belly and as primer for the tops. V-P
If you want another Cat in your stash I can recommend you the Eduard Hellcat it's a very nice kit easy to build ...
I think that you will be very satisfied by the Airfix Mitchell too ..
I hope we will also see you in the DC3/C47 STGB ...
Patrice
Well I didn´t finish this by the GB deadline. In the end I didn´t even try too hard. The little bird is completely assembled and painted, but needs a coat of gloss varnish before adding the decals, and then a layer of flat coat. Shouldn´t take many evenings, though. V-P
Martlet
Good afternoon VP
 That is too bad she looks good tough and I will be happy to see her finished  ..
All the best
Patrice
You may not have finished before the deadline, but that is a great effort V-P. I look forward to seeing it finished.
Oh big thanks to you good people showing interest and support for my build! Found watching the first half of ManU - PSG to be a waste of time and preferred to add decals to the U.S. NAVY Martlet :hmmm:. I decided to use only the kit supplied decals and save the Blackbirds until later. So, maybe tomorrow some rattle can flat varnish on and masks off and she's done. V-P
2019-02-12_11-15-13
2019-02-12_11-14-24
Good morning VP
She looks great with the decals on ..
Patrice
Thank you all for your comments and likes, the little :hmmm:...actually, it's twice as big as a Bf 109 Emil... Grumman in now behind glass doors. Thanks to our GB hosts, crew and regulars! Best regards, V-P
2019-02-13_06-01-55
2019-02-13_06-00-18
Nice work :speak_cool:
Good evening VP
Very nice but maybe you could do some weathering ..
Patrice
