Mike Posted January 28, 2019 Share Posted January 28, 2019 Fw.190A-3 Landing Flaps (48980 for Eduard) 1:48 Eduard As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. Eduard landing flaps use an ingenious technique to achieve excellent true-to-scale flaps using few parts, and requiring the modeller to simply remove the retracted flaps from the lower wing, plus scrape the upper wings to accommodate the thickness of the completed bays, all of which are shown in red on the instructions. Each flap bay is constructed in the same manner, by twisting and folding over the attached ribs to create a 3D shape, with extra parts added along the way. The bays glue to the inside of the upper wing and the flap is folded up and attaches to the rear wall of the new bay. Repeat this for the other side, and you're almost done. The bays have a "dimpled" panel in the small central section, and after pressing the details through with the tip of a ball-point pen, these are inserted and glued in place. Review sample courtesy of Link to comment Share on other sites More sharing options...
