Mike Posted January 26, 2019 Share Posted January 26, 2019 Fw.190D Fuselage Guns (648439 for Eduard) 1:48 Eduard Brassin More goodies from Eduard's Brassin line for their Fw.190D kits in 1:48. As usual with their resin sets, they arrive in the familiar Brassin clamshell box, with the resin parts safely cocooned on dark grey foam inserts, and the instructions sandwiched between the two halves, doubling as the header card. It contains six resin parts and a small fret of Photo-Etch (PE) brass for the small parts. This set takes the kit's blank internal gun bay floor and replaces it with a super-detailed alternative, to which the rear bulkhead, guns with full breeches, ammo cans and additional cowling fasteners are attached. There is also a fine PE part that depicts the network of windscreen clearing mechanism, which fits against the bulkhead and wraps around the lower front of the already installed windscreen. Other than cutting the resin parts from their casting blocks and removing a lug from the top of kit part X38, it is a drop-in replacement set. Review sample courtesy of Link to comment Share on other sites More sharing options...
