Fw.190A-5 Undercarriage Legs BRONZE (648436 for Eduard 1:48)
Fw.190A-5 Undercarriage Legs BRONZE (648436 for Eduard)
1:48 Eduard
Eduard have produced a line of Fw.190 kits that are peerless in 1:48, and as that range expands, so does the variety of aftermarket sets, tailored to their kits, and with exceptional detail that makes them a worthwhile investment if you're after the perfection.
As usual with Eduard's resin sets, they arrive in the familiar Brassin clamshell box, with the resin parts safely cocooned on dark grey foam inserts, and the instructions sandwiched between the two halves, doubling as the header card.  There are two cast bronze legs in the box, with two gear bay doors, consisting of two captive main and two inner doors that hinge along the aircraft's centreline.  The casting of the bronze is superlative, and far better than white metal, as well as being much stronger and less flexible.  If you are planning on loading up your model with resin cockpit, engine, gun bay, etc., these may be just the ticket to support all that extra weight, as well as improving the detail and scale fidelity substantially.
Review sample courtesy of
