Cessna L-19/O-1 Bird Dog "Asian Service" - 1:32 Roden
Julien
1:32 Roden
The Cessna Bird Dog was a military version of the Cessna 170, called the Model 305A by them. It was developed to a US Army requirement for a two seat observation and liaison aircraft. The design featured a single engine high wing monoplane with a tail wheel configuration. This was the first all metal fixed wing aircraft ordered by the US Army after aviation was split on the formation of the Air Force in 1947.  As well as the US Army the aircraft would be operated by the US Marine Corps, and the US Air Force famously in the Forward Air Control role in Vietnam. US Forces would lose 469 aircraft in the conflict in total.  The aircraft would also serve in many other militaries around the world including Australia, Canada, Japan, Spain, and South Vietnam to name a few. Over 3000 were built and there are still some 300 on the US civil register today.
The Kit
The kit arrives on 7 sprues of plastic, a clear spure, a sheets of decals, and 3 lengths of wire for the aerials (not shown). The parts rattle around in a large box, and as the clear sprue was not individually bagged one part was off the sprue and others have been marked. The parts generally are well moulded, and the surface detail is very good, especially on the control surfaces. However there is some flash evident on the clear parts. This contains the same plastic as the initial USAF boxing so a USAF / US Army aircraft can be made if the modeller sources alternative decals.
Construction starts with the engine which looks to be a detailed one. The main undercarriage units are then made up. Pilots seat is made up along with its bracing struts. and the rear seat is also built up at this time. The completed engine is mounted to the engine frame and then to the firewall. To the other side of the firewall the instrument panel is added. Care will need to be taken with the engine and mounts as the tolerances with Roden kits can be tight and if not assembled correctly then they maybe be a fit issue with the cowling. The completed seat can then be attached to the cockpit floor along with other flight controls. The rear seat should probably be put in at this time though is gone AWOL in the instructions!
Next up the instructions have you build the tailplanes. These have antennas on the front held on by a front cap. Even though these are wire they are probably best left unto the end of the build. The final parts of the exhausts are now built up and attached to the engine. The clear parts and doors now need to be placed into the fuselage halves along with the tail wheel. The tailplanes and landing gear are then attached to the fuselage halves.  The fuselage can the be joined together placing the cockpit in and the engine.  The move-able tail elevators are also added now.
We then move to the main wing. The top side is one part with left and right lowers. The observation windows need to be placed into the wing at this stage. Flaps & ailerons are separate but only shown in the neural positions. The main wing is then added to the fuselage and the bracing struts are added. The engine front and cowlings can then be added. The model is finished with the main top whip antenna and a couple of blade antennas.
Decals
Markings are provided for 3 aircraft, they are printed in house and look to have no issues on the sheet.
  1. Japanese Self Defence Air Force, JG-1043, unknown base, 1950s
  2. South Vietnamese Air Force, April 1975, flown by MAJ Boung.
  3. Royal Thai Navy, s/n 22860 (51-16973), No 1302, 103 Sqn, RTNB U-Tapao, ca. 1982
Conclusion
This looks to be a good kit in the box, however care will be needed as Roden kits do need it when putting them together. Even in 1.32 this is not a massive model and should build up to look good. Highly recomended for a Big Bird Dog.
Review sample courtesy of
