phantom61 Posted February 12, 2019 Author Share Posted February 12, 2019 Hi Guys, fuselage and cockpit glued ... I lost so many engraved, many to correct the general line of engines is excellent at the end of each job I always spray the tamiya primer gray ... almost certainly I will engrave the primer ciao Silvano I inserted a copper rod into the nose bay wheels, in order to unload the weight evenly and not on the glued part... 🤔 4 Link to comment Share on other sites More sharing options...
giemme Posted February 13, 2019 Share Posted February 13, 2019 Looking smooth! Ciao 1 Link to comment Share on other sites More sharing options...
phantom61 Posted February 13, 2019 Author Share Posted February 13, 2019 1 hour ago, giemme said: Looking smooth! Ciao I'm a maniac for smooth surfaces ... you will see the work of chisel 👨🎨 Ciao Link to comment Share on other sites More sharing options...
phantom61 Posted February 13, 2019 Author Share Posted February 13, 2019 Hi Guys, besides starting to engrave the new lines, I used aluminum adhesive sheets to simulate the anti-blasting plates ciao Silvano 3 1 Link to comment Share on other sites More sharing options...
giemme Posted February 13, 2019 Share Posted February 13, 2019 Nice job with the alu foil I take you riveted it after applying it, right? Ciao Link to comment Share on other sites More sharing options...
phantom61 Posted February 13, 2019 Author Share Posted February 13, 2019 (edited) 2 hours ago, giemme said: Nice job with the alu foil I take you riveted it after applying it, right? Ciao 👍 with the plasticard template cut alu foil help ... the engraving lines are random ... great trumpeter 😨 they are not seen well but the access doors have been engraved again Silvano Edited February 13, 2019 by phantom61 5 Link to comment Share on other sites More sharing options...
giemme Posted February 14, 2019 Share Posted February 14, 2019 That's a lot of rescribing job there, Silvano Ciao Link to comment Share on other sites More sharing options...
phantom61 Posted February 14, 2019 Author Share Posted February 14, 2019 hello Guys... Engraved and Riveted Part 1 ciao Silvano 5 Link to comment Share on other sites More sharing options...
giemme Posted February 15, 2019 Share Posted February 15, 2019 Very neat rescribing, Silvano! Ciao 1 Link to comment Share on other sites More sharing options...
James G Posted February 15, 2019 Share Posted February 15, 2019 Superb work Silvano, looks great! 1 Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted February 15, 2019 Share Posted February 15, 2019 Beautiful work. I can hardly recognise Trumpeter's work there 2 Link to comment Share on other sites More sharing options...
phantom61 Posted February 16, 2019 Author Share Posted February 16, 2019 On 2/15/2019 at 8:57 AM, giemme said: Very neat rescribing, Silvano! Ciao grazie Giorgio I really like me too Silvano Link to comment Share on other sites More sharing options...
phantom61 Posted February 16, 2019 Author Share Posted February 16, 2019 21 hours ago, James G said: Superb work Silvano, looks great! James, Thank you so much 16 hours ago, Jamie @ Sovereign Hobbies said: Beautiful work. I can hardly recognise Trumpeter's work there Thank Jamie... me too ... but I persevere 😉 the drawings arrived?? 1 Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted February 16, 2019 Share Posted February 16, 2019 1 minute ago, phantom61 said: Thank Jamie... me too ... but I persevere 😉 the drawings arrived?? They did, thank you Link to comment Share on other sites More sharing options...
phantom61 Posted February 16, 2019 Author Share Posted February 16, 2019 Hi Guys... little deal... replaced the heat shield with brass sheets I also glued the engine nacelles to the fuselage and putty whit milliput next step, primer on the whole fuselage ciao Silvano 4 Link to comment Share on other sites More sharing options...
phantom61 Posted February 16, 2019 Author Share Posted February 16, 2019 horizontal stabilizer and elevator riveted... 4 Link to comment Share on other sites More sharing options...
giemme Posted February 17, 2019 Share Posted February 17, 2019 Impressive job, Silvano! How did you bend the brass sheet for the heat shields? Just pressed on in place or pre-bent in some way? Ciao Link to comment Share on other sites More sharing options...
phantom61 Posted February 17, 2019 Author Share Posted February 17, 2019 (edited) 10 hours ago, giemme said: Impressive job, Silvano! How did you bend the brass sheet for the heat shields? Just pressed on in place or pre-bent in some way? Ciao Ciao Giorgio, I made a paper template ... I cut the brass plate engraved and riveted then put in place ... with the dremel I also dug to adapt it the result is good ciao Silvano Edited February 17, 2019 by phantom61 1 1 Link to comment Share on other sites More sharing options...
Nikolay Polyakov Posted February 17, 2019 Share Posted February 17, 2019 Stunning and very skillful build, Silvano! 👍 Looking forward for your progress here. Cheers! 🙂 1 Link to comment Share on other sites More sharing options...
phantom61 Posted February 17, 2019 Author Share Posted February 17, 2019 Hi Guys... engravings and primer completed... I hope you like ... welcome comments ciao Silvano 5 Link to comment Share on other sites More sharing options...
Nikolay Polyakov Posted February 17, 2019 Share Posted February 17, 2019 3 minutes ago, phantom61 said: I hope you like ... Absolutely! Cheers! 🤝 2 Link to comment Share on other sites More sharing options...
phantom61 Posted February 18, 2019 Author Share Posted February 18, 2019 Hi Guys... I started "baby mom" Kh-22 Kitchen 😎 Cheers... Ciao Silvano 3 Link to comment Share on other sites More sharing options...
phantom61 Posted February 18, 2019 Author Share Posted February 18, 2019 this is the target 🤔 2 Link to comment Share on other sites More sharing options...
giemme Posted February 18, 2019 Share Posted February 18, 2019 2 hours ago, phantom61 said: I started "baby mom" Kh-22 Kitchen 😎 Looks like a big mean boy! Ciao 1 Link to comment Share on other sites More sharing options...
Apex Posted February 18, 2019 Share Posted February 18, 2019 Tu-16's carried KSR-5 instead, did not they? Link to comment Share on other sites More sharing options...
