ProfSparks
Matchbox Skyservant Flying Doctor
Hi All
Here's an 'After Hours' project that I'm embarking on with the view of;-
a) being a filler in for when other projects are drying/setting/etc
b) seeing if I can get a comparable White to NATO Black
c) building it just because it's from Fernando Poo island
It shouldn't trouble the accurists amongst you, but that's not the point.
I suspect the kit was brought through by Noah judging by the water damage
It's drying from a soapy bath to remove the flood residue.
Anyhoo, there's something oddly comforting about a matchbox kit, like worn out shoes that you still wear, or an LP you still play even though it's covered in scratches.
Comments and suggestions welcome
Steve
Hi All
The large side doors look to be the only way in or out, and they can be posed open or closed
Mine will be closed because there's nothing much to see inside unless you have a penchant for mid seventies singles bar decor
No painting necessary!
Ok, so I painted it
The glazing has no surrounding locating flange, so i guess they just fit flush?
Cheers 🍷
Steve
Hi All
I tried in a window, and it just pushes in flush from the outside, so I figure I'll leave them out until it's painted.
I ran a strip of tape along the inside to stop the spray getting in, hopefully it should just pull out again,,,
It's all buttoned up for the night, as am I
I had a window recount and only came up with seven, so I suspect a bodge is in the offing.
Comments and suggestions and the missing window welcome
Cheers 🍷
Steve
Nice project.
Try Microscale Micro Krystal Klear. Worth investing in if you can get some. It does windows like that quite neatly and much easier than trying to make a replacement out of clear sheet. There are other similar products I think.
Cheers.
A perfect sentiment!
Very nice project, as well.
A product called 'Formula 560,' now disributed by Zap, is a similar product that has become my go-to for such uses. I slightly prefer it to Krystal-Kleer because it's a bit thicker...which makes it easier to bridge gaps, and keeps it from running off quite as easily. Dries just as clear with less shrinkage. Just my two cents.
Hi All
Thanks Smudge, I've ordered some Klear, it should be here in a couple of days.
Thanks thorfinn, if I can't get the Klear to work I'll get some 560.
Thso, after much sanding, the body was ready for some engine pods
They set quite well, so on with the wings
I'd notices they looked pretty flat so that's what I went for
Turns out they're mostly ok!
I'll fill any gaps when I do the rears
More joy to follow.
Cheers 🍷
Steve
Hi All
I've put the rest of the surfaces and wheel spats on, and trying in the windscreen it looks like a quite good fit
However, there are a couple of gaps that will need to be filled before paint
Herein lies a quandary:-
I figure I could leave it off for the paint, remove the internal masking tape, fit and fill and repaint locally?
Or I could cut off the side windows from the screen, fit fill and paint it all, then remove the internal masking through the side gaps and use this Klear to make side windows like the fuselage portholes?
Steve
Hi All
Guess which option I went for?
I don't suppose by any chance they have wind down side windows?
Steve
A nice piece of work. Those Matchbox kits do have a period charm especially the plastic colours used. Liked the comments on the 70's bar colour scheme, truly the decade taste forgot.
There's a good chance they open, maybe not in the wind down style.
Check out some images on the net.
I've opened a few recently, on DC3 with a pilot leaning out, etc.
Gives a bit of life, or animation, to the model.
A Matchbox kit is a joy forever!!
And this is a lovely little thing.
Nice little subject and a Matchbox build t'boot. Coming along nicely but I'm not looking forward to trying to get that tape out...
Stuart
Great to see this build, don't think I've seen the Skyservant built.
Beautifully put about feelings for Matchbox kits in your opening post, absolutely agree!
Hi All
On 2/19/2019 at 7:42 PM, rob Lyttle said:
https://www.airplane-pictures.net/photo/1011537/d-ires-rk-flugdienst-dornier-do-28-d-skyservant/
Check out this from airplane - pictures. Net
Looks like the windows are tophinged and flip outward. If you fancy having a go! 👍
Hi Rob, thanks, that certainly looks like it could be on the cards if I can give it a go!
In the mean time, I've been messing around with paint.
Tamiya X-1 Black, but I now think I should have used a NATO black as I'm after the corresponding white
Anyhoo, taped
And after several rounds of various light grey lightened with white, veering towards white darkened with light grey
I discovered it was just as difficult to photograph scale white as it was to mix it.
Regardless, this is where I ended up
Looks white until something white is beside it, then it still looks light grey.
I can't tell if it's covered with the final mix of white with a drop of light grey, or just a patchy blend of all the previous shades as I couldn't really tell where I was spraying
A conundrum and no mistake.
But onward. I'll get the stickers on, give it a rub down with a Florry wash and try to remove the internal tape without consigning it to the bin.
Then there's the Kristal Klear to experiment with.
Steve
Hi All
Decals made it in one piece each! (all three of them)
The carrier film is quite firm yet quite fragile, and also quite resistant to solutions.
It's had the Micro Sol, the Daco Strong and the stern glare, but remains unmoved.
It's going to get the Silent Treatment for a couple of days while I'm away, let's see if that works.
Steve
Well, of course, back in the day, at the height of the Cold War, Matchbox decided that it would be better to make the decal sheet to survive Armageddon
Hi All
Hi Rob, yeah I was surprised that they held together or came off the backing paper at all, considering the water damage they had sustained.
But, as every silver lining must have a cloud, they were just as resilient on application.
Anyhoo, a bit of detail painting with Grey Flory Wash
Taking it off with some kitchen roll
Leaves
It looks like the Flory is a residue effect like mud or dust or clay not panel lines, Lesson 1.
I put some Sand on the wheels
And it looked like dried mud, so that's what it's for.
Now onto the main event, removing the internal window masking...
And it's out!
Next Experiment is with the Klear
Gloopy and thick, managed to cover the windows and windscreen sides
So there it is
It's not big or clever, but has served its' purpose as a test of getting close to a NATO white, and an added bonus of Kristal Klear introduction.
It's still slightly foggy where it was thick
Hopefully this will clear eventually.
But if not, then I'll know not to put so much on next time.
All in all it's been a bit of a blast, thanks for all the help and info.
Steve
Looking good Steve. Only time will tell if your Klear works, should do. I used Formula 560 canopy glue to do the same job on my boat windows and it worked a treat.
Stuart
