Col. Posted February 17, 2019 Share Posted February 17, 2019 7 hours ago, IanHx said: ... just found the miniscule individual throttle lever photoetches that I have to glue x4 to the pilot's right front console.... Sounds fun Ian Link to comment Share on other sites More sharing options...
IanHx Posted February 17, 2019 Author Share Posted February 17, 2019 (edited) Don't know what it is about google photos... image URLs from there just won't embed properly for me... back to Flikr... Edited February 17, 2019 by IanHx 2 Link to comment Share on other sites More sharing options...
IanHx Posted February 21, 2019 Author Share Posted February 21, 2019 My first last attempt at PE seat belts.... 4 Link to comment Share on other sites More sharing options...
Col. Posted February 21, 2019 Share Posted February 21, 2019 Looks to be going well for you Ian. What's the, umm, 'object' to the left side of the cockpit? Link to comment Share on other sites More sharing options...
IanHx Posted February 21, 2019 Author Share Posted February 21, 2019 11 minutes ago, Col. said: Looks to be going well for you Ian. What's the, umm, 'object' to the left side of the cockpit? The Red thing ? No idea. Don't think it's a fire extinguisher, but haven't found enough pictures of the bombardments station yet to positively identify it. 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted February 21, 2019 Share Posted February 21, 2019 (edited) Heres a link to the 360 panographic camera view of the Tornado cockpits. Go to the bottom of the link. https://www.nationalmuseum.af.mil/Visit/Museum-Exhibits/Fact-Sheets/Display/Article/196105/north-american-b-45c-tornado/ Im guessing an extinguisher as theres a similar one in the co-pilots station. Edited February 21, 2019 by Corsairfoxfouruncle 1 1 Link to comment Share on other sites More sharing options...
IanHx Posted March 2, 2019 Author Share Posted March 2, 2019 Seats finally assembled. Belts were very fiddly. Am I going to attempt the incredibly small throttle levers ? To quote James May - "Two words. Seven letters. Three of them are F". 1 2 Link to comment Share on other sites More sharing options...
IanHx Posted March 3, 2019 Author Share Posted March 3, 2019 Today has been a lesson in mathematics. Specifically, stickiness (superglue, metal, plastic) < stickiness (superglue, finger ) Rudder pedals now attached. Should've painted them first... 2 Link to comment Share on other sites More sharing options...
IanHx Posted March 3, 2019 Author Share Posted March 3, 2019 At this point the flight deck is glued into one fuselage half. Lots of bits had to be refitted. And nothing short of CA was going to keep it in place. Waiting for front landing gear to set before doing any more. 1 Link to comment Share on other sites More sharing options...
IanHx Posted March 10, 2019 Author Share Posted March 10, 2019 Sand. Dry-fit. Repeat. Yes, the fuselage on this particular build is a right sod to fit together.... Also seem to be missing the main wing spar, so bit of card cut to shape . 1 Link to comment Share on other sites More sharing options...
Col. Posted March 11, 2019 Share Posted March 11, 2019 The extra effort you are making now will prove worthwhile later Ian Link to comment Share on other sites More sharing options...
IanHx Posted March 16, 2019 Author Share Posted March 16, 2019 Nobody will ever guess which bit went missing..... 3 Link to comment Share on other sites More sharing options...
IanHx Posted March 17, 2019 Author Share Posted March 17, 2019 I once heard that superglue was invented during the Vietnam War to glue body parts together. After assembling the resin exhausts I have no reason to doubt the veracity of this statement ! 1 Link to comment Share on other sites More sharing options...
IanHx Posted March 24, 2019 Author Share Posted March 24, 2019 Wings glued together eventually. Ejector pin marks on top of the wheel wells foul the closure of the two wing halves and must be chopped off. 1 1 Link to comment Share on other sites More sharing options...
IanHx Posted March 24, 2019 Author Share Posted March 24, 2019 Only downside with using runny CA is that you need to sand down the seams. Engine pod hasn't turned out too bad. Note to self : READ...THE...DIMENSIONS...BEFORE...YOU....START.....BUILDING..... Attached the wings and now have a bad case of whereamigoingtoputitonceitsbuiltitis 1:72 bomber.... what was I thinking...... 7 Link to comment Share on other sites More sharing options...
IanHx Posted March 24, 2019 Author Share Posted March 24, 2019 In case you're wondering why only one tailplane - reckoned it would be easier to fit the greenhouse over the tailgunner position with one side still accessible..... 1 Link to comment Share on other sites More sharing options...
Creepy Pete Posted March 24, 2019 Share Posted March 24, 2019 Is your left wing also better fitting than the right one? Link to comment Share on other sites More sharing options...
IanHx Posted March 25, 2019 Author Share Posted March 25, 2019 6 hours ago, Creepy Pete said: Is your left wing also better fitting than the right one? Yes. Might have been because I put the left one on first, and then had to hack away at the improvised cross spar. Definately more brute force and CA required for the right wing. The other fun part is guesstimating the correct angle to attach the tailplane at.... instructions not overly helpful in this regard. Lots of Googling required 1 Link to comment Share on other sites More sharing options...
IanHx Posted March 26, 2019 Author Share Posted March 26, 2019 Finally found a decent pic of the tailplanes on t'interweb Now I just need to make mine look a little like that...!! 4 Link to comment Share on other sites More sharing options...
IanHx Posted March 29, 2019 Author Share Posted March 29, 2019 How can we possibly make this large 1:72 bomber even more difficult to find space on the shelf for ? YES !! TIP-TANKS !! No this isn't a scratch-built top secret downward camera port. It's the hole I made to pour the liquid gravity in ( it looked like it was going to be a bit of a tail sitter, so taking pre-emptive action with a little lot of liquid gravity ) 7 Link to comment Share on other sites More sharing options...
Col. Posted March 30, 2019 Share Posted March 30, 2019 Taking shape nicely Ian Link to comment Share on other sites More sharing options...
IanHx Posted April 2, 2019 Author Share Posted April 2, 2019 Well, the wheels are on, and there's no other way to describe it except as a Collosal Tail Sitter. Packed the nose and forward fuselage with lead weights and liquid gravity, but no joy. Makes a great plane-shaped rattle though.... 1 Link to comment Share on other sites More sharing options...
franky boy Posted April 3, 2019 Share Posted April 3, 2019 That is a big beast. Can I make a suggestion. Hang it on a wall? Ill get my coat now.... James Link to comment Share on other sites More sharing options...
IanHx Posted April 5, 2019 Author Share Posted April 5, 2019 On 4/3/2019 at 10:51 AM, franky boy said: That is a big beast. Can I make a suggestion. Hang it on a wall? Ill get my coat now.... James I suggested hanging it from the ceiling of my daughter's room. I never knew teenagers could meltdown for 2 hours straight... ! 1 3 Link to comment Share on other sites More sharing options...
IanHx Posted April 7, 2019 Author Share Posted April 7, 2019 (edited) Unbelievable *. I'm now attaching the landing gear doors, and have come to the step where this kit - which has loads of extra PE etc- instead of having a piece for the forward gear bay door instead just lists the dimensions and tells me to make my own.... * well, not that far-fetched. At least it's a simple part to scratchbuild. But imagine the furore if Airfix or Revell simply put in their instructions "we couldn't be bothered to provide all the bits, make this one yourself". On the other hand at least Valom made an effort to provide the necessary info to fix their parts planning oversight, when they could have kept quiet and hoped nobody noticed...so credit for that. Edited April 7, 2019 by IanHx 1 2 Link to comment Share on other sites More sharing options...
