S-boat 55 Posted February 1, 2019 Share Posted February 1, 2019 (edited) 5 hours ago, Schweinebacke said: Hello. I see you have used putty where the superstructure blends in with the hull. Is the fit not good ? Iam asking as I have not yet made up my mind as to which kit to buy, Trumpeter or Airfix. I'll be watching this. Tom I'm halfway through the airfix kit and the fit is awful I've had to fill every joint, I've no experience of trumpeter kits but I'd be surprised if it could be worse Edited February 1, 2019 by S-boat 55 Link to comment Share on other sites More sharing options...
Jase Posted February 2, 2019 Author Share Posted February 2, 2019 17 hours ago, Schweinebacke said: Hello. I see you have used putty where the superstructure blends in with the hull. Is the fit not good ? Iam asking as I have not yet made up my mind as to which kit to buy, Trumpeter or Airfix. I'll be watching this. Tom Hi Tom, fit is ok but there is a viry small gap to fill. I have built the Airfix version too and its a dog to biuld lots of fit issues and filling to do and as it is out of production genraly more expensive then the Trumpeter version hope that helps Link to comment Share on other sites More sharing options...
Jase Posted February 2, 2019 Author Share Posted February 2, 2019 So I have come across a small problem with the Atlantic Models etch. Clearly this was originally designed for the Airfix kit and as such the advanced railing set for inside the hanger does not fit. The trumpeter kit has a different shape rear hanger bulkhead making the etch for it too wide. The etch is designed to interlock which ads complication to the fit issue. I am working on a modification now and will post my solution when done Jase 3 Link to comment Share on other sites More sharing options...
George Swalwell Posted June 9, 2020 Share Posted June 9, 2020 Did you ever get a solution to the problem with the hanger PE?? Link to comment Share on other sites More sharing options...
