Complete after 3 years: 1/72 Aerovac Latecoere 302.
Pin
On 30/05/2020 at 08:58, Pin said:
 Who produces 1/72 vacforms now? I can only think of Broplan, have you seen much of Broplan kits built?
One I did earlier:
Unmasked for cleanup and remasking
From the very beginning I felt something was wrong about the nose. After some studying I came to sad conclusion that the shape of the kit is incorrect and cannot be fixed without major surgery. The cockpit is too far aft. There is a risk that if I attempt to correct it this build will never be finished
Pin, are you making the lovechild of an aircraft, a boat and a bus shelter?
Good work so far, really impressive! :thumbsup2:
That's a very brave thing to do Alexey, I doubt many of us on here would have undone all that previous work, but then we would have had a lifetime of looking at the completed model regretting not having corrected it !
Look forward to seeing the next instalment
Cheers Pat
Some proper engineering. Revived my SketchUp skills to create a fold for the new greenhouse nose
1592765336_Screenshot-from-2020-06-21-19
1592765339_Screenshot-from-2020-06-21-19
1592765342_Screenshot-from-2020-06-21-19
1592765346_Screenshot-from-2020-06-21-19
1592765349_Screenshot-from-2020-06-21-19
Printed the fold, cut paper version to verify the model
Cut transparencies from clear styrene sheet
Also decided to correct the shape of the nose and cheekbones. MilliPut to the rescue
Eventually the greenhouse is in place. Still a lot of filling, sanding and polishing ahead
Wow that's some proper modern day modelling.
What awesome solution for the greenhouse, very fascinating.
What CAD software are you using ?
Edit: Oh I see it's SketchUp, the folding feature is very neat.
Martin
Clumsy me has hit the nose, something got loose inside
Glued it back,
remasked
Tried to add some variation to the black bottom with various shades and heavy chipping fluid. Did not work very well, seems more like a bad paintwork than deliberate art effect
Proud French tricolor, these boats never wore Vichy's "pajamas of shame"
I run out of Alclad Dull Aluminium. Ordered more but it is not clear when the resupply mission would arrive
  • Like 9
  • 1 year later...
Time for KUTA.
Blown the dust from the plane, blown some "dull aluminum" on the wing. Because of its size I haven't found proper roundels that are 60mm in diameter. The plan is to print my own but I could not find transparent paper so I ordered more.
I find that printing roundels on a transparent paper and applying over the white background works better than printing on white mostly because some toner/ink will inevitably go off on the edges.
Attaching a large parasol wing is quite challenging and I could not help thinking that something is not quite right
After studying existing references and some measurements I realized that the central pillars are 4 mm too short. Original kit plans are way off
Old pillar for comparison
I need to fill in old strut mounting points and repaint the wing
The wing has sucked a lot of my blood
but 2/3 of supporting struts are now in place and the structure is secure enough to remove additional support
Is it the biggest KUTA duo ever?
  • Pin changed the title to Complete after 3 years: 1/72 Aerovac Latecoere 302.
