Shar2's heavy metal year.
Shar2
This is the first batch from this years output, you'd never guess I was mainly a maritime modeller, all the ships I started seem to stall at one point or another. Still not a bad number of builds, none of which are actually finished as I have plans for dioramas for most of them, except the big guns which need crew, which, I have been told, may appear in 2019.
Takom 30.5cm WW1 mortar, on a ground base of AMMO dark earth acrylic paste
Trumpeter Grille30-30.5cm (Grw) L/16 Morser 'BAR' (Bear) SPG
Takom 420mm howitzer, "Big Bertha" once again using the AMMO dark earth acrylic paste.
Trumpeter StugE100, out of the box, and I've just seen needing some attention on the left track join. This was a mojo lifter when I had a slipped disc back in November.
Takom General Lee late, Straight out of the box, really enjoyed this one.
Dragon Maus super heavy tank, with ET models etch set and Metal barrel set from Aber. The camera seems to have picked up some strange patterning on the hull which isn't visible in real life.
Trumpeter TOS-1 Heavy Flamethrower for something a bit more modern.
  • Like 15
  • 3 weeks later...
