F-4J Phantom 1/72 Revell
A new project to build an F-4J Phantom of the Vietnam era using the Revell 1/72 kit, which I think is the old Monogram kit, but happy to be corrected. It has raised panel lines so I decided to sand those off and re-scribe (using my go-to UMM SCR-01 SCRIBER) and also add some rivets (using Rosie The Riveter tools).  I find the SCR-01 SCRIBER the best I have used. It is easy to use and the results are better than other devices I have used. Thoroughly recommend.
IMG_8843
My normal approach is to sand and re-scribe & rivet before assembly so it seems to be weeks after opening the box to eventually "sticking" things together. Once together, filled and sanded, the plan is to coat in Mr Finishing Surfacer 1500 Gray (cut 50/50 with Mr Color Levelling Thinner 400)  and then sort out the blemishes.
Tools used:
IMG_8855
Before starting:
IMG_8854
Top half of fuselage "as was" and bottom half with scribing underway. My technique is to sand an area to the point the raised lies are just visible and then scribe and then sand the rest of the raised lines away when I have enough of a scribed line to act as a guide.
IMG_8849
Another before and after compare - this time around the nose.  Taking lots of photos on the iphone also helps to keep track of the lines. I also use "blueprint" images of the aircraft I find on the internet. Such are particularly useful when it comes to rivets.
IMG_8848
Below is a before shot of the wing. in progress; only partially done.
There are some whitish blotches on the leading edge of the outboard wing section.  This is Mr Dissolved Putty which is good for fixing areas where I have overrun the end of a panel line.  It works very well but is not suitable if I have made a mistake that needs re-scribing. For that I have my own concoction of old sections of sprue dissolved in an old pot of Humbrol glue in a ratio of about 25% glue / 75% sprue. It is essentially liquid plastic that I brush on and when it sets hard, it is just like the original plastic and can be re-scribed once sanded and polished. Warning, it can only be used in small amounts otherwise the model melts! Also it needs to harden for about 24 hours,
IMG_8992
Once I have done the two fuselage halves, I tape them together to ensure the lines over the spine line up.
IMG_8856
Once I am happy the scribing looks reasonable, I give each part of the model a primer coat of Mr Finishing Surfacer 1500 Gray mix and start marking out the rivet lines with a soft pencil, using a straight edged strip of thin sheet plastic as a guide, whilst referencing the "blueprints".  I then run the riveting tool alone each line.
IMG_9006
Here is an almost completed wing section. I give each section a rub down with 4000 grit paper.
IMG_9007
And here is the result with the fuselage.
IMG_9008
  • Like 15
The kit seems to have a good overall F-4 shape; it looks right, but I am no F-4 expert. The parts fit is not great but the cockpit is quite good. That said, the parts will go together but filler is required.  One exception; the wing root join to the fuselage on the upper side is excellent. No filler or anything required at all. The air intake cowl presents the biggest challenge but filler sorts them out.
Cockpit built out the box.
IMG_9081
IMG_9084
Fuselage joined up with cockpit installed. Quite a lot of filler on the fuselage spine but I expected that so re-scribing not yet complete.
IMG_9082
Wings on and cowls in place. I needed to bend them a bit to get them to fit with the model and then filled the gaps with filler (Humbrol's finest - I'm no filler connoisseur) and my liquid plastic cocktail.  Wing root required no work.
IMG_9138
  • Like 9
Progress on getting the air intakes to fit..........not the best fit but they came up alright in the end.
IMG_9140
IMG_9141
Just need re-scribing and riveting.
  • Like 11
48 minutes ago, Unfinished project said:
Cracking start I’ll tag along with you if you don’t mind
A pleasure. There is still a long way to go and it nearly went for its maiden flight this afternoon....out the window.
  • Haha 2
  • 10 months later...
My goodness, nearly a year since I last posted anything on this project. Anyway, I have made some progress. Post the previous photo, I sanded some more and gave a primer of Mr Finishing Surfacer 1500.
IMG_9161
IMG_9168
Once the black primer was down, it was time to start on the top coats. At this point I tried acrylic Hataka Red Line as they have a good range of paint sets, including US Navy and USMC from the right era. Sadly, I really struggled with them and could not avoid a significant issue with nozzle clogging so I gave up and mixed my own colours from Gunze paints; they always work well. I did not try Hataka  thinners as I did not have any, but tried just about everything else. I would like to get them to work as they have a good range.  Anyone got any pointers?
IMG_0739
IMG_0983
IMG_0984
  • Like 13
Superb re-scribe and rivet detail on this.  I too was suffering badly with the airbrush nozzle clogging but using Vallejo Model Air.  Have started using Tamiya with their own thinners and haven't looked back.  Not a single issue with them at all.  I have found that XF80 - Royal Light Grey is a good match for US Light Gull Grey.
I briefly used acrylics with an airbrush and found they worked much better when I got vallejo drying retardant. It kept the airbrush from clogging, the tip from drying and improved the smoothness of the finish.
Personally I loathe acrylics -- I use the Gunze lacquers and have found Hataka's lacquers to be superb.
The finish looks fantastic, BTW!
I think I have found the formula for using Hataka's acrylics and that is Vallejo Airbrush Flow Improver plus thinning with Hataka's own thinner. Much better results. I am glad I have got the acrylics to work as they have a good range.
IMG_1246
Some more progress over the last few weeks. The following is ready for decals having given a gloss coat.
IMG_1176
And now with decals on using Gunze solution.
IMG_1224
And the other side.....
IMG_1222
  • Like 10
  • 3 months later...
  • 6 months later...
32 minutes ago, Gene K said:
What do you use for a wash and what do you do to remove the "excess"?
Judging from the label on the bottle, it's Flory wash - clay-based pigments in water suspension.
Which is great, you can wipe the model off with soft tissue or cotton buds for the smaller places. Since it's clay & water, cleanup is easy.
Hi Everyone, that is correct - Flory Model's clay wash. Really easy to use as you just rub off the excess.
2 hours ago, VT Red Sox Fan said:
Great build--really liked how you sorted out the intake seams, the scribing pointed out by many and the paint finish.... well done🙌 & I will be following this and hopefully your future builds with interest... best, Erwin
Hi - thanks for the comments. Just finished a 1/48 Monogram B-29 and, guess what, that's a complete re-scribe too! I'll start posting the build soon.
