Shar2 Posted December 30, 2018 Share Posted December 30, 2018 PLAAF J-16 1:48 Hobbyboss History The Shenyang J-16 is a multirole fighter capable of both ‘beyond-visual-range’ air-to-air and precision strike roles. The aircraft is the latest addition to the ‘Sino-Flanker’ family, which has been developed by the Shenyang Aircraft Corporation (SAC) from the Russian Sukhoi Su-27 ‘Flanker’ airframe, but incorporated with Chinese indigenous avionics and weapon systems. The most noticeable difference of the J-16 to the previous J-11B series is its two-person crew, with the pilot seated at the front of the cockpit and the weapon system officer (WSO) at the back. The airframe of the J-16 appears to have been developed from the Shenyang J-11BS two-seat fighter-trainer, an unlicensed copy of the Su-27UBK ‘Flanker-C’. Therefore, the aircraft can be distinguished by its cropped vertical fin tails (same as the J-11BS/Su-27UBK) as opposite to the square topped vertical fin tails of the Su-30MKK. At the same time, the J-16 also bears some design features of the Su-30MKK, including the side-mounted electro-optical sensor (as opposite to the centre-mounted design on the J-11BS/Su-27UBK) in order to make room for the in-flight refuelling probe, and the twin-wheeled nose landing gear (as opposite to the single-wheeled gear on the J-11BS/Su-27UBK) to support the extra weight. Like the Su-30MKK, the J-16 is also expected to have undergone structural enhancements in its airframe in order to achieve an increased take-off weight. The Model The large sturdy box with a depiction of the aircraft in flight over a non-descript Chinese city hides something pretty nice. On opening the box, and on giving a very unusual WOW!, you are confronted with an inner tray which carries the upper and lower airframe, neatly tied to the tray and protected by foam wrap for particular areas. Normally you have to glue the wings to the fuselage when building an aircraft kit, which is why I used the term airframe, as the upper and lower fuselage halves are complete with the main wing sections, I’d love to see the mould for these parts. On removing the tray there are a further twenty six sprues in a similar grey styrene, three sprues of clear styrene, four vinyl tyres and two medium sized decal sheets. The mouldings are very nice indeed, with no sign of imperfections, flash but a fair few moulding pips. The surface detail is nice and fine with the panels all seemingly in the correct place and of the right shape. The build begins, naturally, with the cockpit. The twin bay tub is fitted out with front and rear bulkheads, instrument panels and coamings, rudder pedals and joysticks, which I wouldn’t have though the WSO would have had, so looks like the kit hasn’t been modified from the SU-27UB. Not being able to find any cockpit photos on the internet I’ll have to rely on the BM massive to confirm this. The ejection seats are each assembled from eight parts and look to be a reasonable representation of a Russian K36 seat, the biggest problem being a complete lack of seat belts, so it looks like the modeller will be using some aftermarket belts. The completed seats are then glued into place and the tub glued into the upper airframe section followed by pilots upper coaming. The nose wheel assembly is built up from nine parts and put to one side. Before the two airframe sections can be joined together, the two, three piece exhaust nozzles are assembled and glued into position, as is the five piece nose wheel bay. Ensure that you have drilled out all the holes required for the pylons you wish to hang from the wings, before you join the airframe together. Once the airframe has been assembled it’s time to add the pair of two piece flaps, nose undercarriage assembly, four piece vertical tail fins/rudders, two piece horizontal tailplanes, exhausts, either open or closed, and separate slats/leading edge flaps, depending on your choice of phrase. The two ventral fins are also glued into place, along with each of the five piece intakes, with the internal ramp being positioned to the modellers wishes. The underside of the forward intakes looks like it should have some moveable slats, but the detail is quite indistinct and soft, at least to my eyes. The main undercarriage is now assembled, from the main oleo, with actuator moulded onto it, the two piece wheel and the mounting bracket at the top. These are then glued into place and the undercarriage doors added as are several aerials to the airframe. The separate nosecone is large enough to pack with weights should the kit require it, and I would presume it would need some, It looks pretty accurate, but may need a rub down to get rid of the moulding join line as from pictures it is a pretty clean shape, without the lightning runs seen on some radomes. The canopy is fitted out with PE rear view mirrors, rear hinge plates and mid section strut. The canopy can be posed open or closed and per the modeller swishes. The windscreen is moulded complete with the IRST on the right hand side, which has a separate clear part to fit on the end. The separate inflight refuelling probe is also fitted as is its cover panel. The three piece airbrake is also poseable, although it is very rarely seen open with the aircraft o n the ground and shut down. The airframe is finished off with the addition of the pitot probes, AOA sensors, air temp sensors and radome tip pitot. The kit comes with a fair selection of weapons to fit onto the twelve pylons provided, these include:- 6 x PL-12 medium range air-to-air missiles 4 x PL-10 short range air-to-air missiles 2 x KD-88 anti shipping missile From the pictures I’ve seen on the net, this aircraft is meant to be quite a bomb truck, so it’s a shame no bombs or air to ground missiles have been included Decals The kit comes with two decal sheets, the national markings and exterior of the aircraft while the other is for the cockpit and the markings for the missiles. The decals are very nicely printed with minimal carrier film, in register and with pretty good opacity; they are slightly glossy and should settle down ok on a glossy surface. There are two colour schemes to choose from:- J-16, No. 78077 in blue grey over light grey and with full colour national markings. J-16, No. 70191, in Barley grey over medium grey and with toned down markings. Conclusion This is my first big Mig from Hobbyboss and from what I can tell it certainly looks like a J-16 from the research I’ve done, but I’m sure those of the BM massive will know better just how accurate, or inaccurate it is. For me though it’ll build into a pretty impressive model and will look great in any collection. Not a difficult build by anyones standards so could be good for those who want to try out a big jet. The only real downside for me is the lack of air to ground weapons which should really have been included even at the expense of the multiple medium range missiles, especially at the price point it’s been set at. Review sample courtesy of 2 3 Link to comment Share on other sites More sharing options...
