Sign in to follow this
Paul A H
USS Missouri Cartoon Model (no scale)
Meng
The USS Missouri is an Iowa Class battleship, and the last of her type to be built for the US Navy. She was commissioned just in time to serve in the closing stages of the Second World War, and famously hosted the signing of the Japanese surrendered by Mamoru Shigemitsu. She went on to serve in the Korean War before spending the next three decades as a tourist attraction. She was reactivated in the 1980s under Reagan's programme of naval expansion  and was fitted with Harpoon and Tomahawk missiles, as well as Phalanx defensive weapon systems and a multitude of other upgrades. She served in the first Gulf War prior to being retired for a second time in 1992. She is berthed at Pearl Harbour, overlooking the USS Arizona memorial.
Cartoon-style kits seem to be in vogue these days, with an increasing number of manufacturers jumping on the bandwagon started by Hasegawa with their egg planes. Meng have quite a few under their belt now, and this is the fourth ship kit to be produced in this style. The kit has been moulded from styrene in three different colours, each appropriate to the parts represented (save for the rather bright blue decks). The lower hull is moulded from dark red plastic, the aforementioned decks and turret roofs are moulded in blue plastic and the rest of the kit is moulded from grey plastic. The kit is well packed into a sturdy box. All of the plastic parts are nicely moulded, and  in line with their other similar kits, the parts snap-fit together  and stickers are included instead of decals.
Construction of the kit is fairly conventional, notwithstanding the fact that the parts snap together rather than requiring glue. Bearing this in mind, I would advise against test fitting the parts prior to final construction, as snap fit parts rarely snap apart again. Construction begins with the lower hull, to which the propellers and shafts click into place. The upper hull is formed from the joining together of the hull and the deck, with a part sitting below the deck that pushes through and includes parts for the turret bases and other details. some small details such as AA guns and deck cranes can be added at this point. Assembly of the superstructure is pretty straightforward, with blue deck parts sandwiched between grey structural parts in a layered fashion. All of the features you would expect to find, such as funnels and fire control systems are present and correct, except in cartoon form. Both the primary and secondary turrets are made up from three parts each (except No.2 turret, which features additional AA armament on top). The guns do not appear to be designed to be moveable once fixed in place.
A colour painting guide is included within the instructions. AK paints are recommended by Meng, in what appears to be a commercial arrangement (their logo is emblazoned on the side of the box). The aforementioned stickers are used to add detail. There are no decal alternatives.
Conclusion
I shan't comment on the cartoon style of the model - not least because this sort of thing will either appeal to you or it won't - but I will state that this appears to be a well-executed kit, with nice moulding and detail. If you like this style of kit then this will be an excellent addition to your collection.
Review sample courtesy of
Your sprue shots seem to suggest that they don't include the Rodan-sized bald eagle perched on B turret in the box art. How very disappointing!
 That can easily be remedied thorfinn, but I'm wondering more about where the spotter aircraft are. I'm awaiting this kit in the post so I'll try and keep you on your perch. 🦜
