Robert Stuart
Sd.Kfz. 165 Hummel - ### calling it finished ###
That’s a nice figure set you’ve picked up they build into a very nice scene.
58 minutes ago, Hewy said:
 Very nicely done camo Robert,looks great that
Thank-you Hewy
Thanks Ozzy, you've used one of them before?
Yeah, I used them on a build I did with a train dio. I put a few bottles around to add a little atmosphere.
I remember seeing your photos in that build ... but hadn't connected with individual kits.
Hi Robert,
All looking good!
An interesting collection of goodies you have there.
A nice 'pin-up' poster slapped on the side of your Bee will improve its looks by a factor of about 1,000,000.
How are you at figure painting? I'm rubbish!
BTW, Tamiya's solid Nashorn barrel is great, with only the faintest of seam lines. So faint, I removed them with my thumbnail. The added 3-part muzzle has a ring inside  with a 'shell width' aperture (not sure what it's called) and whilst you can see beyond that, the solid barrel isn't really visible.
Rearguards,
Badder
Thanks Badder
Mmm, Painting? I like to think I'm competent, but I'm better at sculpture and drawing ...
... but reducing that to 1/35 would be a pain
One of my ETA 'Signal magazines' includes a small version of this cover from 1941 ...
th?id=OIP.yaD2xpiLefMuCyCTPT7c3QHaJ7&w=1
Maybe not as risqué an image as a gunner would have wanted, but one that might be displayed and survive foraging by 'friendly' troops.
Just as well.  If I'd had the nerve, I should have tried for a metal barrel.  My next AFV does have a metal barrel (:penguin:), but will have to wait for June ...
20 minutes ago, Robert Stuart said:
Thanks Badder
We seem to have similar interests then Robert,
I've done a fair bit of artwork over the years, though more your Sci-fi, fantasy stuff. I did a lot of work for a local Heavy Metal band in the 90's and regularly bump into people who still have my artwork on their walls!
Liking the magazine cover. Typical Nazi brainwashing material. That'd keep 'em warm on the Eastern Front - when set alight!
Rearguards,
Badder
The Jack-in-the-box image looks (sort of) familiar, I wonder if I've seen it somewhere else?
Progress - I've attached the bee's legs ... wheels, sprokets, tracks, that sort of thing ...
You may also (just) spot a cable on the front glacis in this image.
And a few details at the back
They will need a bit of re-painting, but that's normal
I've also started working out which figures I'll use, and where they'll go ...
The character in the box (''Hacker'' also seen in the image below it) was one I designed for the band Bardiche- a Swindon band, back in the late 80's early 90's.  So, if you were around High Wycombe back then you might have seen them play there and sell cassettes/posters which these images (and others featuring Hacker) were on? They played a 'live music rock venue' pub there 3 or 4 times during that time. (can't remember name of pub)
Good to see the tracks on Robert,
And those figures look promising, sitting on the back.
A question for you, saying as the Hummel and Nashorn are so similar - that rear panel they are sitting on - is there a daylight gap between it and the  floor behind the ammo/charge boxes? Both times I've build my Nashorn, there's been a gap which I've had to get rid of by filing the ends off the side panels and reducing their length by about 0.5mm.
The thing is, I'm pretty sure that in real life, the entire rear panel could be dropped down ,a bit like a tail-gate, and so maybe that gap is SUPPOSED to be there?
If your Hummel has the gap, then I've made a boo boo!
Rearguards,
Badder
Thanks Badder
Do you mean these gaps behind the boxes?
I think it is needed to open those boxes.  They were hinged at the top*, and, as it is, there isn't enough space to set the lid vertical, much less open beyond the vetical.
*and half-way down the front.
Hi Robert,
No, what I meant was does the rear panel fit flush with the floor panel, or is there a gap - as if the floor panel is too short and doesn't join the bottom of the rear panel. With my Nashorn, I could look down behind my long 'chest' and see daylight between the floor panel and the end panel. I got rid of that gap by sanding/filing the side panels a bit shorter. I've seen other Tamiya Nashorns where they left the gap. I think I'm right in saying that I've seen a Dragon Nashorn with the same gap. That's why I'm wondering if the gap is supposed to be there't .
As your Hummel is built on an identical chassis, and isn't a Tamiya kit, if the gap is there then it's supposed to be there.
Rearguards,
Badder
Great to see more progress Robert and excellent progress it looks too! It's always good to see the tracks going on! And good luck with the figures! :thumbsup:
Kind regards,
Stix
1 hour ago, Badder said:
Hi Robert,
Rearguards,
Badder
At the back? No
Had to use my phone to light this area (phone is the fuzzy thing at the top of this imaget) , but ...
I did, however, have a small gap (0.5 to 1mm?) between the gun platform and the glacis, behind the driver's compartment.
This I subsequently filled
2018-pz-iv-040.jpg&key=1e46fc27cb397c9d9
HTH
I'm watching @Badder going through the pain of painting kill rings on a gun barrel, meanwhile I have the, perhaps simpler, task of painting ranging rods ...
Having masked my rods, I then had to un-wrap them ...
Three stages of un-wrapping - which may give a hint as to how I approached painting these rods.
Ths tape in the middle of the middle image (below) was used when dealing with bleed ...
I did have the advantage of a scanner, so I could 'photograph' the rods actual size, and some suitable graphics software to work out where I wanted the ?guide bands? to help line up my masking tape.*
The tape was folded over the ranging rods,  squeezing the tape into the gaps between the rods (to reduce bleed), and finally squeezing closed (again, to reduce bleed).  Accurate line up is easier (IMO) than rolling the tape around a stick (gun barrel, or in this case, ranging rod).
There is yet more bleed to deal with - it is visible in the last section of the image above, more so in this dry fit image ...
The shoes (?) and spikes still need to be painted, and I have to work out what colour to use on the rings(?) first big white stripe.
*Note, the red/white on my scan was in the wrong order, the rods are OK though.
Ah ha! I see what you mean now Robert.
I did contemplate doing the same to my Nashorn's shorter, and more attractive, ranging poles, but decided to stick with the plain wood prescribed by Tamiya.
I do prefer the red and white ones, adding some nice colour to the model, but I'm not sure I'd have been happy to be driven around in the back of a thin-skinned vehicle with a big red and white target on the back,
As for your bleed problems, you could just use a heavy wash and run that into the 'crevices'. That area would have gotten fairly dirty after all, with splashes, spray, and mud from the crew's' boots.
Liking the bucket where it is now.
Rearguards,
Badder
Thanks Badder,
Those ranging rods are a bit bright.  Before gluing them on, I plan to soften the bright contrast with a light misting (modulation coat?) of Dunkelgelb, and, maybe, a light shadow of burnt umber.
Somebody asked if I'd place my Hummel in a diorama, and I did buy some figures to go with it ...
... but I feel it needs something else, maybe a tree?  Looking on YouTube for how to do videos - there are plenty, mostly aimed at railway modellers,
So I bought a roll of Oasis florists wire at the local branch of a craft shop and cut it into lengths.   If I'd known I'd use the whole roll for one tree, I would have cut every nth loop (maybe every 3rd?) and had a more even set of lengths - but these seemed to do.
For twisting, this florists wire is soft and easy - maybe easier than sculptors armature wire.
The next stage will be to coat the tree, developing some bark - and, maybe, lose the keeper wire runnimg backward around the trunk?
There is a decided risk that I'll not finish the diaorama before the end of this GB - time looks tight for the amount of work I envisage.
Hi Robert,
Probably a bit late now, but I 'invented' a method for making realistic trees (I might even say, VERY realistic trees) using real twigs, wire-cored garden twine, nylon monofilament fishing line and herbs.
The results can be seen in two of my dioramas - The first, a completed diorama 'Carry on Regardless' features two trees and is available to view in the Dioramas RFI section under that tag. EDIT - FORGET ABOUT THAT RFI FOR NOW, MOST OF THE PHOTOS HAVE GONE. I WILL REPLACE THEM AT SOME POINT.
The other, far larger tree, was a step-up in realism and is available to view in the Dioramas WIP section under the title ;Ever Evolving Diorama' (currently on hold due to THIS STGB.
Here's the finished tree:
And here's the link to the start of the tree's construction.
Anyway, they may help in some small way, if nothing else.
Rearguards,
Badder
Edited by Badder
More lovely progress Robert and I'm looking forward to seeing your tree in progress. :thumbsup:
Kind regards,
Stix
Thanks Badder
I had a quick look at your thread, there is a LOT to read there, too much for me when using an iPad.
I did see stuff on buildings in the thread too ... and casting walls?
I decided that the wire I used for my first tree was a bit heavy, so bought a reel of finer wire, and made a couple of trees from that ...
Bare metal
I gave the trunk and branches a coat of latex.  This was followed by successive coats of latex mixed with a little acrylic ink, some yellow ochre in layer two, mainly white in ther rest.
Two trees together
One, with figure - this is Dragon's artillery man included with the Hummel
And the other.  The bulk of the lower trunk here has been covered with some stripes of kitchen towel soaked in latex.
Hi Robert,
The trees are looking great with the thinner wire.
Rearguards
Badder
Thanks Badder
I've started work on a base, and started painting the trees ...
I stole the idea for the embankments from  @PlaStix build, here, though I feel I can only aspire to the quality of his base.  I've used a drop of latex glue to fix the bits of polystrene food tray here - trees, vehicle and figures are loose.
The trees both have coats Halfords grey primer.
The smaller one has been given a mix of blue and white acrylic ink - though I'm wondering whether to re-visit the texture of its trunk?
Windy today which means spraying outside is difficult ...
Never mind, I made some progress on the base, adding some plaster bandage
The tub of 'dirty' water contains a squeeze of burnt umber (acrylic) ink and a couple squirts of yellow ochre which help take the stark white off the plaster.
And with the trees attached - I hope the plaster bandage will help tie the trees in place
Note to self: If I use plaster bandage again, get some pinking shears to soften those hard edges.
Fantastic work on the trees and the base Robert! It all looks to be coming together beautifully! :thumbsup:
Kind regards,
Stix
