Courageous Posted December 31, 2018 Share Posted December 31, 2018 Thanks for the explanation Moa. As a Shaolin Modeling Monk, one has to expect to get asked questions about the ancient arts of 'scratching' and whether you think it is superfluous or not, as a theacher...teach. Stuart 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted December 31, 2018 Author Share Posted December 31, 2018 Primer and some base colors are airbrushed: 4 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 2, 2019 Author Share Posted January 2, 2019 The exit point of the rudder control cables is drilled: Almost ready to go: The Yahu instrument panels are glued after some thinning of their locations (the fuselage walls are too thick for them to fit comfortably otherwise): 5 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 2, 2019 Author Share Posted January 2, 2019 This is for me the most fastidious stage: priming, sanding, puttying, sanding, oh the inexhaustible layers, akin to political coverup. Darn! 5 Link to comment Share on other sites More sharing options...
zigster Posted January 2, 2019 Share Posted January 2, 2019 Dear Moa As I wrote some time ago, you are an inspiration! There's a (modeling) life beyond 109, 190, 51, 47, 38, Mk this, or that! And you do your research on those "weirdos" :-)) 👍 I've got a :48 RWD-8 "in waiting". Wings are ribbed like a starved dog. That will get the same treatment as your's 72. When I get to it, though... Took me years, to figure-out the aileron linkage setup, it's tricky around center wing 🙂 Now it's just about the throttle. Maybe you got something better, but I suspect - it was just a long rod, with an "offshoot stick" with a ball in both cabins. No quadrant. Just push - pull. Maybe GrzeM can add his knowledge to it? Anyway! Great to look again at your output! And All The Best 4 2019!! Regards Zig 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 2, 2019 Author Share Posted January 2, 2019 6 hours ago, zigster said: Dear Moa As I wrote some time ago, you are an inspiration! There's a (modeling) life beyond 109, 190, 51, 47, 38, Mk this, or that! And you do your research on those "weirdos" :-)) 👍 I've got a :48 RWD-8 "in waiting". Wings are ribbed like a starved dog. That will get the same treatment as your's 72. When I get to it, though... Took me years, to figure-out the aileron linkage setup, it's tricky around center wing 🙂 Now it's just about the throttle. Maybe you got something better, but I suspect - it was just a long rod, with an "offshoot stick" with a ball in both cabins. No quadrant. Just push - pull. Maybe GrzeM can add his knowledge to it? Anyway! Great to look again at your output! And All The Best 4 2019!! Regards Zig Hi Zig I got some small drawings, will try to post later as work permits. Cheers Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 2, 2019 Author Share Posted January 2, 2019 15 minutes ago, Moa said: Maybe you got something better, but I suspect - it was just a long rod, with an "offshoot stick" with a ball in both cabins. No quadrant. Just push - pull. Hi Zig These excerpts come from a plan made by Felix Pawlowicz in Melbourne. I hope I am not upsetting anyone posting these, I found them on the Net. Hope this helps. As you can see, it's actually two little sticks. 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 3, 2019 Author Share Posted January 3, 2019 (edited) The flying surfaces look nice now: The fuselage halves are united: A noticeable detail not seen in this kit is a prominent exposed tank located under the fuselage on the left hand side. The section is thus cut out to make one according to photographs: Edited January 3, 2019 by Moa 4 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 3, 2019 Author Share Posted January 3, 2019 The control surfaces are separated and the horns form the photo-etched fret are glued in place. The scratched tank can be seen to the left: I added a cylinder behind the air intake, but notice that the kit sort of provides one on the locating block of the nose tip -where the arrow is pointing) which I erased since I didn't need it anymore. The fact that nose tip and nose base with exhausts and cylinder are so cleverly provided by this old kit makes you wonder why contemporary manufacturers don't adopt such clever solutions to avoid seams where you don't want them, and help with detail: 4 Link to comment Share on other sites More sharing options...
zigster Posted January 4, 2019 Share Posted January 4, 2019 Thanks Moa. I know those plans. Throttle/mixture combo is a bit fancy for a basic trainer though, maybe some DWL for aero clubs had it? There were plenty variations of a basic airframe. Have look here: http://odkrywca.pl/forum_pics/picsforum27/_57_2_copy306.jpg Now you have to employ a spider to do all those fuse to tail steering links :-)) Zig 2 Link to comment Share on other sites More sharing options...
spiton Posted January 4, 2019 Share Posted January 4, 2019 Wing after Your facelift looks great!!! And I am very moved, that You Build model od Polish plane RWD-8 ! 2 Link to comment Share on other sites More sharing options...
Courageous Posted January 4, 2019 Share Posted January 4, 2019 Going great Moa. You have subdued that ribbing on the surfaces nicely. Stuart 2 Link to comment Share on other sites More sharing options...
Martian Posted January 4, 2019 Share Posted January 4, 2019 On 02/01/2019 at 01:23, Moa said: This is for me the most fastidious stage: priming, sanding, puttying, sanding, oh the inexhaustible layers, akin to political coverup. Darn! Exactly how I feel about the Albatross at the moment. I have got to the stage of using much stronger expletives about it though! Empathetic of Mars 👽 1 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 4, 2019 Author Share Posted January 4, 2019 1 hour ago, Martian Hale said: I have got to the stage of using much stronger expletives about it though! Oh, go ahead, unleash your tongue (tongues?), nobody speaks Martian here anyway. Not even the moderators (but are they from another planet too?) 2 Link to comment Share on other sites More sharing options...
Martian Posted January 4, 2019 Share Posted January 4, 2019 16 minutes ago, Moa said: Oh, go ahead, unleash your tongue (tongues?), nobody speaks Martian here anyway. Not even the moderators (but are they from another planet too?) I think this might be the time to quote what you colonial types call the Fifth Amendment. Martian the Cautious 👽 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 4, 2019 Author Share Posted January 4, 2019 Fuselage ready for the first primer coat: 3 Link to comment Share on other sites More sharing options...
zigster Posted January 5, 2019 Share Posted January 5, 2019 You doing that very well, Mister! Hope, you'll get to the finishing line :-)) z 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 7, 2019 Author Share Posted January 7, 2019 Some priming of fuselage and tail, and some base color (white) for the wing: 3 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 10, 2019 Author Share Posted January 10, 2019 More airbrushing ensues. The wing is painted aluminium, while the fuselage and vertical tail are still in the gloss white base stage: 5 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 12, 2019 Author Share Posted January 12, 2019 The aftermarket photoetched set provides a couple of control levers that very prominently are located at the fuselage sides and handle the elevator cables. The kit provides them too, but of course the P.E. are more to scale. They are given axles made of discarded drill bits, always useful to have in the spares bin: The landing gear is glued on, as well as the handles and the photoetched assembly that replaces the kit's tailskid: The cabane struts are added. the remaining four short struts that connect fuselage with wing are going to be made of airfoiled brass, replacing in turn the kit ones that won't do (the kit's long wing V struts will be utilized, though): 5 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 13, 2019 Author Share Posted January 13, 2019 Since my gifted kit was missing the windscreens, a couple are made from clear plastic, first carving the curve at the bottom: And then cutting the curve on top: 4 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 14, 2019 Author Share Posted January 14, 2019 I am concocting a fueling dolly: Fuselage is given its aluminium color: 5 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 14, 2019 Author Share Posted January 14, 2019 Masking and painting of the red color on fuselage and ancillaries follows: The home-made fueling trolley is given some base colors: 3 Link to comment Share on other sites More sharing options...
Martian Posted January 14, 2019 Share Posted January 14, 2019 The penny has just dropped that the late mother of a friend of mine once told me how she worked as a seamstress at the RWD factory prior to WW2, helping to do the fabric work on these aircraft and how the young girls often used their charms to cadge flights off of the factory test pilots. Oddly, she had never told her daughter this story but knowing my interest in aviation thought it was something I would like to hear. She was a truly remarkable lady who managed to escape from German occupied Poland to Sweden and from there, via a B17 flight, to this country. Martian 👽 5 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted January 14, 2019 Author Share Posted January 14, 2019 5 minutes ago, Martian Hale said: The penny has just dropped that the late mother of a friend of mine once told me how she worked as a seamstress at the PZW factory prior to WW2, helping to do the fabric work on these aircraft and how the young girls often used their charms to cadge flights off of the factory test pilots. Oddly, she had never told her daughter this story but knowing my interest in aviation thought it was something I would like to hear. She was a truly remarkable lady who managed to escape from German occupied Poland to Sweden and from there, via a B17 flight, to this country. Martian 👽 Nice addition of an historical note to the thread, Martian, thanks! Note, though, that this a RWD machine, not a PZW one. Not sure if they were related (besides being Polish) regarding production or facilities. Unless you meant RWD and made a typo, of course. 1 Link to comment Share on other sites More sharing options...
