warhawk Posted December 23, 2018 Share Posted December 23, 2018 (edited) Hello, Looking at various photos of 343FG/11FS aircraft, namely aircraft No.49, I have noticed that no photos of these early birds show gun barrels protruding from the wing leading edges. Was this another modification for operating in the cold weather (like sealing the openings around exhaust pipes)? Or were they deleted from the photos by a censor? https://www.asisbiz.com/il2/P-40/343FG/images/Curtiss-P-40E-Warhawk-343FG11FS-Y49-Aleutian-Islands-1942-02.jpghttps://www.asisbiz.com/il2/P-40/343FG/images/Curtiss-P-40E-Warhawk-343FG11FS-Aleutian-Islands-1942-02.jpghttps://i.pinimg.com/originals/8b/4e/3e/8b4e3eff19b82dc9948d665c437bbed2.jpg Edited December 23, 2018 by warhawk Link to comment Share on other sites More sharing options...
72modeler Posted December 23, 2018 Share Posted December 23, 2018 Just guessing, but either deleted by the censor, or guns not fitted when the aircraft were ferried to Alaska to save weight, use the gun bays for parts/tools, etc. If you look at the last photo, you can see where the case ejection chutes were either blotted out by a censor or covered over. Just spitballin' here! Pretty darned strange photos, that's for sure! Maybe @BS_w might know, as he seems to have a ton of H-75 and H-81 reference material! Mike Link to comment Share on other sites More sharing options...
Dana Bell Posted December 23, 2018 Share Posted December 23, 2018 Hi Warhawk, Those 1939/40 designs were the first to carry internally mounted 50-calibre wing guns, and no one was quite sure how to minimize the drag along the wings' leading edges. They all had blast tubes extending from the barrels, but until the NACA reports came in there were many variations. Clearly, flush-with-the-leading-edge was not the best, since the blast tubes were quickly extended in production. Cheers, Dana 2 3 Link to comment Share on other sites More sharing options...
BS_w Posted December 23, 2018 Share Posted December 23, 2018 As Dana wrote, it's first model of blast tube opening. I've change the curves of the pic and now we can see the openings in the leading edge. They are as the drawing on the right, at top(1940). later, the blast tube will protrude the LE and a fairing will be around it.(drawing at bottom 1941) Note the large opening and blast tube diameter of first model. 1 1 Link to comment Share on other sites More sharing options...
warhawk Posted December 24, 2018 Author Share Posted December 24, 2018 Thank You very much for concise explanations and drawings. This brings me a step closer to completing my model. But now, I don't get to use those beautiful 1/72nd gun barrels by Master (doh!) Regards Aleksandar Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted December 24, 2018 Share Posted December 24, 2018 (edited) 3 hours ago, warhawk said: But now, I don't get to use those beautiful 1/72nd gun barrels by Master (doh!) Sure you do ... Just buy another P-40 ! 😉 Edited December 24, 2018 by Corsairfoxfouruncle 3 1 Link to comment Share on other sites More sharing options...
BS_w Posted December 25, 2018 Share Posted December 25, 2018 On 12/23/2018 at 5:16 PM, warhawk said: Was this another modification for operating in the cold weather I found this: - oil system modified - cowl flap altered to prevent 100 percent closure - drain valve installed in lowest part of oil tank sump - added a 750w immersion heater in oil tank - all bearing exposed -60°F lubricatd with another grease - additional heat for carburetor and guns - oil lines lagged with asbestos tape and cotton tape - cockpit heating system modified - added propeller anti icing system and more 3 1 Link to comment Share on other sites More sharing options...
warhawk Posted December 25, 2018 Author Share Posted December 25, 2018 3 hours ago, BS_w said: - added propeller anti icing system Great info, thanks! Should this system be visible on the prop blades? Link to comment Share on other sites More sharing options...
BS_w Posted December 25, 2018 Share Posted December 25, 2018 Rubber feed shoes are cemented along the leading edge of each blade and distribute the anti icing fluid. The thickness of feed shoes is thin so it's not easy to see it on the pic 2 Link to comment Share on other sites More sharing options...
warhawk Posted December 25, 2018 Author Share Posted December 25, 2018 (edited) 38 minutes ago, BS_w said: Rubber feed shoes are cemented along the leading edge of each blade and distribute the anti icing fluid. I think I see what You mean, but by looking at these photos... They cover the entire back surface of each blade... and are attached by some rivets (just after the leading edge of each blade, parallel to it)? source: worldwarphotos.info source: asizbiz.com The color of this rubber surface looks like a light grey to me (maybe un-vulcanized rubber, just like used in WWI for tire production, which is indeed a very light neutral grey). Edited December 25, 2018 by warhawk Link to comment Share on other sites More sharing options...
HBBates Posted December 25, 2018 Share Posted December 25, 2018 7 hours ago, BS_w said: I found this: - oil system modified - cowl flap altered to prevent 100 percent closure - drain valve installed in lowest part of oil tank sump - added a 750w immersion heater in oil tank - all bearing exposed -60°F lubricatd with another grease - additional heat for carburetor and guns - oil lines lagged with asbestos tape and cotton tape - cockpit heating system modified - added propeller anti icing system and more I'll on the subject of the Aleutian P40 I came across a photograph sometime back that showed at least one with a real strange anomaly that have never been able to figure out, which is the circular hatch in the rear right glass .. 1 Link to comment Share on other sites More sharing options...
BS_w Posted December 25, 2018 Share Posted December 25, 2018 (edited) Hello Hume, how are you? in the right rear window it's the cap filler of de-icing tank which is behind the headrest armor plate. "An opening is cut on the right-hand side of vision glass to allow for the filling of the anti-icer tank. This opening is fixed with a hinge cover operating from inside.", this change sept 1942 Merry Christmas !!! Edit: the propeller anti-icer tank is between Sta 7 & 8 on P40E (and Sta 5 / 6 on F, L, K & M when fitted, on these models, the cap is just behind the frame Sta 5) Edited December 26, 2018 by BS_w 1 1 Link to comment Share on other sites More sharing options...
warhawk Posted March 5, 2019 Author Share Posted March 5, 2019 On 12/24/2018 at 12:45 AM, BS_w said: Looking back at this photo, I cannot determine the shape and color of these tape patches over the gun openings (they look circular, but I have doubts someone would bother to cut them that way every time they need replacing). What would You suggest? Link to comment Share on other sites More sharing options...
