Dansk Posted January 23, 2019 Author Share Posted January 23, 2019 On 1/22/2019 at 7:34 PM, Collin said: I'll be waiting overhead for you to finish and join me for a raid. Nice looking build. Hey Collin can I ask - the colour palette looks awesome - did you use Dark Sea Gray (tamiya xf-54) for the upper surfaces? Link to comment Share on other sites More sharing options...
Collin Posted January 23, 2019 Share Posted January 23, 2019 1 hour ago, Dansk said: Hey Collin can I ask - the colour palette looks awesome - did you use Dark Sea Gray (tamiya xf-54) for the upper surfaces? I think so. I built this about 3-4 or so years ago, so my memory on what I used has faded. I probably used whatever was the recommended color that this squadron used...of course weatherd a bit due to the enviroment they flew in. sorry I can't be more help. Here is a link to the finished build post, maybe this will help since there are better photos of the topside: Cheers Collin 1 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted January 24, 2019 Share Posted January 24, 2019 That cockpit detail looks Excellent Paul, is a pity you will have to hide it under the canopy when done! Link to comment Share on other sites More sharing options...
Christer A Posted January 24, 2019 Share Posted January 24, 2019 No doubt about it, those radios look good! 1 Link to comment Share on other sites More sharing options...
Dansk Posted January 24, 2019 Author Share Posted January 24, 2019 (edited) Thanks guys 🙏 canopy is now back on again after the IP top and HUD are now in and painted. canopy came off nicely, the crystal clear glue gave way easily with a clean break thankfully. so onwards... Edited January 24, 2019 by Dansk 3 Link to comment Share on other sites More sharing options...
Col. Posted January 25, 2019 Share Posted January 25, 2019 That's good news. Glad to hear you're back on track with this one as it's looking great so far. 1 Link to comment Share on other sites More sharing options...
Dansk Posted January 25, 2019 Author Share Posted January 25, 2019 (edited) Good evening all. So the canopy is sewn up again and i’ve been working hard on trying to clean up pva glue marks around it and cleaning up everything as a whole on the aircraft. It’s really difficult - it looks silky smooth - but then i photograph it up macro close and it looks awful! Every spec is magnified. So then i have to redo it 🤨 - so i’ve been continually sanding and priming. But now i’m ok with how it all looks with my skills i can’t get it any better so it’ll pass (... actually the real reason is i’m tired of it). So after this marathon and a last prime, i’ve been preshading. I used the opportunity to test my new badboy airbrush 😎 I figured preshading is the perfect time to try it out and wow its really a better feel to my previous £9.99 amazon bargain basement special. The preshading is a bit speckled here and there while experimenting with air pressure, paint viscosity and locking the trigger travel. I also preshaded the gear doors, painted the spinners medium sea gray (like mozzy hr116 - they look warm coloured in the photo but in the flesh its neutral), gave the props another black coat, and painted the external tanks (but they need more sanding/cleaning of course 🤪) So things are progressing ok - no more major cock ups so far Edited January 25, 2019 by Dansk 6 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted January 25, 2019 Share Posted January 25, 2019 On 14/01/2019 at 12:01, Christer A said: Spilled primer and thumbprints are a must for every model, or so I like to tell myself 😇 And if you are really good, you can get the thumbprint across a transparency... 3 Link to comment Share on other sites More sharing options...
Col. Posted January 25, 2019 Share Posted January 25, 2019 Given the hard life these aircraft had and the weather conditions they were subject to during it I'd not spend too much time and effort getting a perfect paintjob as it'll look better with plenty weathering 1 Link to comment Share on other sites More sharing options...
dnl42 Posted January 25, 2019 Share Posted January 25, 2019 (edited) Coming along quite nicely!!! On 1/22/2019 at 2:09 PM, Dansk said: So this evening i finished up the interior by installing the gee radio navigation units and livening them up a bit with wiring. Its been really fun using the different thickness brass wires to do this - a real learning experience. I used a sharpie again for the silver wiring. One thing to try on a future build is solder. Very pliable and already a usable color. UMM-USA sells lead wire in round and rectangular shapes and multiple sizes but I would think a local electronics store would be more convenient for you... Edited January 25, 2019 by dnl42 Link to comment Share on other sites More sharing options...
Dansk Posted January 25, 2019 Author Share Posted January 25, 2019 (edited) 32 minutes ago, dnl42 said: Coming along quite nicely!!! One thing to try on a future build is solder. Very pliable and already a usable color. UMM-USA sells lead wire in round and rectangular shapes and multiple sizes but I would think a local electronics store would be more convenient for you... I’ll try that thanks - the copper wire was a little too ‘springy’ to work with Edited January 25, 2019 by Dansk Link to comment Share on other sites More sharing options...
Rob G Posted January 26, 2019 Share Posted January 26, 2019 Run the copper wire (and brass rod too) slowly through a candle flame to remove the 'spring'. A few tries should give you an idea for how long you need to hold it in there. Just umm... don't do it with bare fingers. 1 Link to comment Share on other sites More sharing options...
Dansk Posted January 26, 2019 Author Share Posted January 26, 2019 17 minutes ago, Rob G said: Run the copper wire (and brass rod too) slowly through a candle flame to remove the 'spring'. A few tries should give you an idea for how long you need to hold it in there. Just umm... don't do it with bare fingers. Brilliant tip Rob, great idea thanks. I will definately try this on my next build. 1 Link to comment Share on other sites More sharing options...
Dansk Posted January 26, 2019 Author Share Posted January 26, 2019 Tonight i tuned and brought the pre-shading back a bit, in retrospect i thought yesterdays work was a little bombastic. I think together with weathering further down the line - the two together would have got way too heavy i think. I also sprayed a lighter white/light gray hue (a touch lighter than the primer) in the centre of the large panels to bleach them out a touch there. So i think the upper surfaces are ready for paint. The underside i have painted in tamiya xk-21 sky. It’s extremely difficult to capture the hue correctly on my phone camera but hopefully you can get an impression. I also got the wing tanks sanded and primed (not photographed here). This is the best bit - paint and weathering is top fun. I love it. 🤗😁 8 Link to comment Share on other sites More sharing options...
Grey Beema Posted January 27, 2019 Share Posted January 27, 2019 (edited) Great work Paul, keep it up. I have this kit in the stash, which will need to be converted to a MkXIII so I am following to get hints and tips.. Before you go much further should you attached the wing tip Nav. lights in case they need some blending into the wing surface? You don't want to damage the wing finish around them. I think I would fit them and mask them off before going much further.. Edited January 27, 2019 by Grey Beema Link to comment Share on other sites More sharing options...
Dansk Posted January 27, 2019 Author Share Posted January 27, 2019 2 hours ago, Grey Beema said: Great work Paul, keep it up. I have this kit in the stash, which will need to be converted to a MkXIII so I am following to get hints and tips.. Before you go much further should you attached the wing tip Nav. lights in case they need some blending into the wing surface? You don't want to damage the wing finish around them. I think I would fit them and mask them off before going much further.. Thanks for the advice @Grey Beema I’ll do that 👍😉 Link to comment Share on other sites More sharing options...
Robert Stuart Posted January 27, 2019 Share Posted January 27, 2019 That is looking nice Paul. How are you getting along with your new airbrush? I ask because I bought the same model just before Christmas. Link to comment Share on other sites More sharing options...
Dansk Posted January 27, 2019 Author Share Posted January 27, 2019 5 hours ago, Robert Stuart said: That is looking nice Paul. How are you getting along with your new airbrush? I ask because I bought the same model just before Christmas. Thanks Robert. I’m obviously no expert -and It takes a bit of getting used to but compared to the old one it feels ‘silky smooth’ i think is the best way of describing it. Feels really nice to use and has more control. 1 Link to comment Share on other sites More sharing options...
Dansk Posted January 27, 2019 Author Share Posted January 27, 2019 Hey @Grey Beema I’ve painted the nav lights (hard to photograph) and cleaned them a touch and dry fitting they seem to be perfect now (this kit is great with fitting) so i think with my dodgy modelling skills and kak handedness i will find it a little easier to stick them on with a dab of crystal clear last (so i dont knock them off before) 🙄 6 Link to comment Share on other sites More sharing options...
Dansk Posted January 27, 2019 Author Share Posted January 27, 2019 (edited) And another update I’m steaming along these days: Looking at the reference shots e.g... ... it seems mostly that the demarkation between upper and lower camo colours is a little softer on the fuselage but harder where it’s on the engine cowling panel line on most aircraft. So i have used tamiya tape on the cowls and worms of this stuff on the fuselage... ...A.k.a. White tak. Now ready for the dark/extra dark sea gray Note the tanks are painted installed and masked also. The upper fore section of the tanks is to be painted DSG also according to refs Edited January 27, 2019 by Dansk 6 Link to comment Share on other sites More sharing options...
Col. Posted January 27, 2019 Share Posted January 27, 2019 (edited) Masking the paintwork with "Elefant Snot" That's not something I expected to read today! Edited January 27, 2019 by Col. 2 Link to comment Share on other sites More sharing options...
Dansk Posted January 27, 2019 Author Share Posted January 27, 2019 45 minutes ago, Col. said: Masking the paintwork with "Elefant Snot" That's not something I expected to read today! it's a great product name isn't it Col.? 😁 OK And my last update from a busy weekend on this little aeroplane - Top half is all painted. as i lost most of the pre-shading despite using heavily thinned paint, i tried to recreate it by post-shading it by adding a touch of black to the original grey. (Maybe i should have kept the pre-shading as dark as it was originally) Theres a few bits and bobs here and there to touch up tomorrow night - then after that I’ll try and get time to seal it with a coat of gloss. The props are just a dry fit because i couldn’t resist 😋 I think it's really starting to come together now. This bit is so much fun i love it. 6 Link to comment Share on other sites More sharing options...
zebra Posted January 28, 2019 Share Posted January 28, 2019 Your Mossie is looking very nice indeed Paul. I have two of these in the stash, starting to get tempted to dig them out. 1 Link to comment Share on other sites More sharing options...
Christer A Posted January 28, 2019 Share Posted January 28, 2019 Wow, that's some excellent painting you've done over the weekend! What did you use for DSG/EDSG? 1 Link to comment Share on other sites More sharing options...
Dansk Posted January 28, 2019 Author Share Posted January 28, 2019 6 hours ago, zebra said: Your Mossie is looking very nice indeed Paul. I have two of these in the stash, starting to get tempted to dig them out. Thanks! Its a great kit - generallly everything seems to fit together really nicely. Link to comment Share on other sites More sharing options...
