Big thank you to you all for the warm welcome, I really enjoyed reading your messages! I'm a fairly committed WW2 aviation buff but even so I've been impressed and awed by the knowledge and attention to detail seen here so far! I guess as you say that may be something I become attuned to with time, but at the moment I'm just enjoying researching all the different models and makers, and of course actually putting my own models together. I've started reading Griffon Spitfire Aces tonight for further inspiration. I can see why there's such an interest in the XII.
Going to rehash this thread.
This is all relating to 1/72 scale
Have read through the pages of this topic with great interest because like many others, I too am a fan of the first production Griffon Spitfire.
Been making a Spitfire collection (quite unintentionally. Started with one which led to another and another till I'm now up to a Mk.XII).
Thought of using Jay's (ex Ventura) Seafire MK.XV as a base for a conversion. Read a few reviews and builds on Jay's/Ventura kits that say with a bit of TLC it will build into a nice replica. Having the kit now in my hands I don't think I have that much TLC available.
Massive sprue gates, very rough texture to the plastic, for me only the fuselage and wings are usable. Have plenty of spares from my Eduard spitfire collection to substitute  the smaller parts, but it will take a bit of effort to get something presentable. (How good are the Eduard Spits for spares!)
Anyway may give up on this idea. Looking for your input and advice on other possible avenues to making a Mk.XII from what I have at hand/in the stash.
Eduard Mk.VIII
Eduard Mk.IXc and e
AZ Mk.IXc/e
Airfix Mk.XIX
AZ Mk.21
Airfix Mk.22
Special Hobby Mk.22
Without any conversion sets in the stash, I’m looking at kits that would be a good base with which to build a Mk.XII.
Plan 1- Use an Airfix Mk.XIX
    use fuselage as is
    re-scribe panel lines and add cannon bulges to represent a ‘c’ wing configuration
    remove wing tips
    add Coffman starter bulge to upper cowling
    add tubular oil cooler to lower left wing
    Need to source correct spinner. Here lies the main problem. Have plenty of spare prop blades from AZ Mk.21 and Special Hobby Mk.22 but no larger spinner that accommodates four blades.
Plan 2 - Use either an Eduard Mk.IXc or Mk.VIII with the same additions as above and use rocker covers from Special Hobbies Mk.22. Not sure how these will fit just yet. Also unsure of other differences in engine/cowling area.
Leaning towards using the Airfix Mk.XIX as it would be far easier with rocker covers already in place, no need to get Special Hobbies parts to conform and fit to the Eduard fuselages without losing all that great detail.
Not too concerned about an incorrect panel line here or there. Would like to know how well the kits compare to the overall shape of a Mk.XII. Anyone have plans or pictures that can compare these kits with shape and contours of the Mk.XII
Red Dog
Red Dog
Having done a few using a Hasegawa IX, today I would use a the Eduard IX or VIII as basis.
As you state, you will need a new oil cooler. This could come from a Tamiya V. (See post #21)
You will also need a Giffon nose. The trust line is a bit different from a Merlin, so it will not work with modification. The XII nose is also a bit different from a XIV, but it may be adapted (shortened). The bulge between the rocker cover is for the magneto, BTW, but will need to be present.
So no easy route to a decent XII, I'm afraid.
Edit: This is some of my XII-ish Spitfires WIP.
Top row: Tamiya Ia with Paragon nose as DP845 in the '42 Farnborough "race" with the captured FW190 and Typhoon. A XII using a Brigade model undercowl and paragon copy upper on a Hasegawa IX.
Botton Row: Xtrakit XII with a Paragon nose (I gave completely up on the nose of this one). The CMR XII (which I don't like at all, very curious shape and needing major surgery to fit the lower cowl to match the spinner).
First three close to the painting stage.
/Finn
Edited by FinnAndersen
Red Dog,
In 1/72 it would be much easier to just swap the noses between the Ax, AZ/KP or Ed IX and the Ax XIX.  Shorten the XIX nose as the early griffon was shorter and add the lump on the nose.  Replace one of the rads with the tubular type oil cooler.  Stick the leftover IX nose onto the XIX and you nearly have a Mk.XI too!  Sticking IX nose onto an AZ/KP Vc would be easier, though they're not cheap yet.
Okay its a bit more involved than that.  Something along these lines was my plan until I ended up with 2x Aeroclub conversions, the Xtrakit cheap and the decal sheet from the Brigade version (no idea why anyone would be selling the decal sheet only , but hey ho).  It would still be easier to swap the Aeroclub nose onto an AZ/KP Vc, (rather than recurve the Airfix 1 wings as intended) if AZ/KP ever do one of their triple-packs.
Hope this helps your thoughts.
Will
Using the XIX fuselage would not work as this is longer than the XII and the canopy are is quite different because of pressurisation.
From the kits listed above my plan would be using the nose from the spare Mk.22 fuselage in the AZ Mk,21 kit (at least mine came with two fuselages) on either the Eduard or AZ Mk.IX. Must be a IXc and an early one, that is with the short intake. The AZ kit is not as accurate as the Eduard one but allows the modeller to build an early Mk.IXc easier. I would probably use this one.
So chop the spare griffon engined fuselage to the length of the single stage Griffon cowl (the Mk.22 cowling is longer), chop the Mk.ix engine cowling and replace with the Griffon one. Fill the area on the wing below the oil cooler and add one from a Mk.V or aftermarket. Then add the various parts required for your build from Eduard or AZ parts (elevators, tailwheels etc.). Of course the magneto fairing on the top of the cowling must be added. In my old KP/Fujimi Mk.XII I made this from a small bomb.
Since you have a Jay Seafire XV,. you may also cut the cowling from this one, or see if you can adapt the whole Jay's fuselage to the AZ or Eduard wings. From the Jay's kit you can also take the propeller, that otherwise has to be made modifying parts from the other kits. If using the Jay's parts you'll have to rework the lower cowling area a bit as these kits have part of the longer carburetor intake moulded with the fuselage while the Mk.XII had a Mk.V style short intake
On ‎12‎/‎11‎/‎2018 at 4:32 PM, 72modeler said:
I agree- the Seafire XV is one gorgeous airplane! The fuselage halves on my Xtrakit XII were badly warped forward of the cockpit and the cross section at the nose was elliptical, not circular...not sure if that was just my kit, but looking at some build articles, it seems others had the same problem.
Mike
Nope- same problem with mine; one of the reasons it became a parts mule! (Unless you and I got the only two cruddy ones pulled out of the injection machine!)
Mike
I have gone down the Jays/Ventura Seafire XV route.
Trimmed the wingtips, spare rudder from the Eduard IXc, infilled the second radiator and fitted the circular oil cooler that comes as an optional part in the Airfix Spitfire Va boxing.
Would admit that the base kit looks crude on the sprues but it cleans up and fits quite well.
IanJ
Very much my experience when I went down this route a couple of years ago.
Steve.
Thanks for the input guys .
Nice work on the XII-ish models Finn. They do look good. Can see a lot of work gone into them, all the best with finishing them off.  Yes magneto cover not Coffman, my mistake.
Giorgio & Steve - I may have to give the Jay's XV a second chance and see what I can do with it. Just looking over it again now (shiver).
Using the spare 22 in AZ's 21, great idea Giorgio will keep that in mind if the XV falls flat or needs some help.
Getting the front end to look right is where the hard work is, the distinctive Mk.XII details I find is the easy part with plenty of Spitfire leftover parts in the spares box.
No easy solution unfortunately, but that's what makes this hobby so interesting.
I'll give it a go as soon as the paint dries on the recently finished Mk.XI. Come on Valiant Wings, bring on Pt.2 of the Spitfire - Griffon Engined variants. Great reference books.
Cheers All
Red Dog
Edited by Red Dog
