Hi everyone,
this is my first WIP on this site...
I'm already some weeks into this build so no real 'in progress' pictures.
I don't have too much time for modelling so my focus lies on building rather than taking pictures on the go.
But now I found some time and thought I share some pictures.
The kit should be well known, its the 1/350 Tamiya Tirpitz. I got it as a present from friends last year for my birthday and used the time to obtain some goodies for it: the eduard big ed set and a wooden deck from a chinese companie I do not know...
So here we go:
bridge assembly
upper bridge
full bridge assembly:
and with radars
all radars:
funnel:
scratchbuilt interior:
...aaaaand how little you see when the funnel cap is attached... I don't want to imagine how it looks after painting... At least I know its there! :D
Now the hangars, first the only WIP I can show:
side hangar before and after PE
both done:
big hangar:
Now the big pieces:
and everything together so far... looks like theres more brass than plastic :P
and next the wooden decking...
there are many issues with that... for example
1 easy to fix problems where eduard replaced the 'balconies'...
2 Big problem where eduard corrected wrong fittings on the deck... I still have no idea what to do with that... maybe fill in pieces out of sheet to simulate hatches...🤔
3 Huge problem where shields where moved to the correct positions... see also the first picture of the wooden decking aft of the 2nd tower in front of the bridge...
I dont know what to do... as shown on previous pictures eduard provides etched decking but I know my painting skills will never be good enough to stand up to the real wooden decking on the main deck...
Any input is highly appreciated.
Thanks for looking
Konrad
Good show, lots of detail.
No idea how you solve your problems.
Carry on with the good work.
Stuart
Thanks Stuart!
Well I still have no good solution for the wooden deck problem but I carried on regardless.
The next installment was the masts.
main mast assembly was a little tricky with that amount of PE...
the kit parts used:
...and modified
there was an issue with one of the ladders eduard provided... way too short!
luckily I had some spares
and the finished main mast
And how it looks in its place
Next, the forward mast.
Take this...
...add that...
...aand you get a finished mast!
Thats it for the moment.
Next in line will be cranes and small deck fittings and as soon as the brass barrels arrive, the armament.
thanks for watching, any comments welcome
Konrad
Impressive work on the masts with you your own touches too. Good step-by-step images :yes:.
Stuart
Great work on the superstructure. It's looking real good. As to the deck discrepancies, I have no idea. If you don't mind cutting extra thin strips of masking tape you can mask and paint the deck almost panel by panel. Time intensive to be sure, but if you're not in a rush it's a viable alternative.
Or... Trim what you have (of the wood decking) and use the extra that it was cut out of to fill in any gaps.
Like you I didn't want to paint a deck area, but after watching some youtube (mainly about painting WW1 aircraft...) I did some practice, then took the plunge. Now I don't know what the fuss was about 😋.
Have a look into it, I find it much easier than getting aftermarket decks to fit.
Stuart
On 07/12/2018 at 09:05, mick said:
great work
Thank you!
I might give it another try on a test piece but every wooden finish I tried so far looked somehow scrappy... :(
The trimming and filling in thing looks like the route I might try although the offcuts do not have the decking cut into it. Maybe reproduce the pattern with a hard pencil?
Next steps:
I built the cranes and had the chance to use my dremel as an improvised lathe. The eduard set included a pulley with a 2D Stand (or wathever it is). that just didn't look wright so I turned a toothpick into a 3D version of that thing.
and all in place:
not sure wether to use all the PE parts for the crane jibs so I postpone this part.
Moving on to armament!
first the torpedo tubes before and after the brass treatment
and a scenic view also showing the masts in place
 the Postman brought me something!
YEAY!!!
I might have bitten up more than I can chew with the 20mm AA...
but time will tell.
For now I started with the big guns.
You can clearly see the age of the kit with all undersides just open... had to fix that
just for comparison
and the complete turret
 and all four done:
Thats it for now...
Only so many things to still complete before I can finally get to priming and painting...:(
Thanks for watching, all kind of comments welcome
Konrad
Hi Konrad
Well done so far. What will you be using for the blast bags betwwen the main guns and the turrets?
Regards Toby
Outstanding! The turrets look great, esp with those new barrels.
As for the decking, a fine ruler and maybe a hobby knife with a brand new blade and a very fine stroke..?
18 hours ago, Sofusthecat said:
Hi Konrad
Regards Toby
Asking the real questions here...
honestly I have no idea. I guess I could sculpt them using Green stuff or something similar but that would take me the option of displaying the ship in different situations...
Does anyone know a way to produce moveable blastbags in 1:350?
Konrad
