Sign in to follow this
Dee1234
Mr Hobby Aqueous vs Mr Color
Hi
I am new to Airbrushing and wanted to airbrush some plane models such as the F16 , F18, F14 from Hasegawa and Tamiya.
I will prime with Tamiya primer and have a 3M Respirator with Organic Filters.
I was wondering which out of Mr hobby Aqueous which is a solvent based acrylic or the Mr Color (lacquer) is better or more suitable, I want to use the Mr Color Levelling Thinner with the paints.
I understand the Aqueous is less toxic but the lacquer based paint is more durable?
Thanks in advance for any advice.
Dee
Dee,
Welcome to airbrushing and all I can say is that I wish I'd come across these Gunze range of paints a lot sooner than I did. Mr Colour Leveliing thinner works exceptionally well with either the Mr Color (Lacquer) or Mr Hobby (Acrylic) paints. The Lacquers are very durable and unless I'm using a solid bright colour such as yellow, I rearly need to prime before hand. I used to avoid any Acyrlic based paints due to their inherent inability to bind to the plastic or not strip after masking (Vallejo!), however I've had no problems with either issue when using Mr. Hobby paints. When using these acrylics, I would still recommend that you prime before you paint and can also recommend this same company's Mr. Surfacer series of products for this purpose.
I hope I've answered your question?
Cheers.. Dave
Thanks for your reply Dave but i still am not sure if i should get the hobby aqueous acrylics or the mr color lacquer ones?
I also have some tamiya acrylics and model master i am using on other models such as the clear uss enterprise and tamiya f117 but need the mr color or mr hobby as they have specific fs colors for the main body of the f14 16 18s. I can use the tamiya acrylics on any other parts of the f14 16 18 as well as i already have the colors required
Edited by Dee1234
All the paints you mention can be thinned with Mr Levelling thinner, if your using this to thin you may as well just buy the Mr Colour as the Aqueous, although they can be thinned with Mr LT they were marketed to use the ipa based thinners like Tamiya X-20A
You will definitely need a spray booth with Mr Levelling thinner though, your mask will be ok for you but everybody else in the house won't like you for using it
If you're set on using the Self Leveling Thinner (which is a great product) I don't see the point in getting the water based range. Get the Mr. Color paints, they're brilliant. They dry pretty quick, the finish is incredible, good pigments... Not to mention the GX range, been using the gloss varnishes, I'm in love with the way those turn out after they're properly cured. And I second the idea of a spray booth, the thinner will stink up the house.
Ok thanks will get mr color . Not got a spray booth but maybe i can airbrush outside if the weather is good in some sort of mdf enclosure or box
Edited by Dee1234
Mr Color is just wonderful stuff. Beautifully smooth and resilient finish. While you need good skills to use it, the rewards are quite high.
Lacquer paints are the thinnest coating,  so make sure the surface is smooth. Thin with Mr Leveling Thinner to consistency of 1% milk. Spray close-in, say 5mm to 50mm. Mist on light coats for coverage. Since it dries so quickly, this is only a single session, even for a small 1/144 model.  Use grazing light to ensure it hits the surface slightly wet. Only apply a heavier wet gloss coat when you have full coverage.
I use thinned Mr Surfacer as my primer in the same way. Doesn't obscure fine detail but will cover slight surface scratches.
Again. It's really worth the effort!
Either or.. If you can get the lacquers then get and use those. Both the Tamiya acrylic and Gunze aqueous thin and spray well with lacquer thinner as does the Tamiya enamel.
HTH
Another vote for Mr Color Lacquers with the self levelling thinners. The Aqueous colours are ok too and I have used both on the same model before but prefer the Lacquers.
Duncan B
I solely use Mr Hobby aqueous paints and love them. I use their special aqueous thinner in a 50/50 ratio with excellent results.
http://www.mr-hobby.com/en/itemDetail.php?iId=85
The Mr Color paints are also very good as are the Mr Metal paints which I use and love.
Edited by Homerlovesbeer
Hi Dee
Gunze's Mr Hobby is not solvent based, they sell as an "Acrylic" paint, but in reality its a oil paint that has been made Water soluble, so with Mr Hobby, you can use Mr Hobby acrylic thinner, Water or
any other generic acrylic thinner, BUT you can also use Mr COLOR (lacquer) thinner and most lacquer thinners on the market. The same goes for Tamiya's "acrylic paints".
You CANNOT do it the other way around, MR Color paint will seperate if you use Mr hobby thinner or Tamiya acrylic thinner.
Mr Hobby is rather kind and nice to your lungs and brain if you use acrylic thinner.... if you use lacquer thinner; not so much (use charcoal mask)
Bo
