AndyBunney
1/72 SAR RAF Leconfield
I am soon going to be making a 22 Sqn Wessex and 202 Sqn Sea King. These will be placed on a re-creation of the pan at Leconfield where I worked on both types in the late 1980s. I have a Houchin GPU on the way and have purchased a JB Models Bedford Tactical re-fueller (We had one of these for a while) The main re-fuellers we had were Bedford MK6 (Based on the Bedford TK) I don't suppose anyone knows how I can re-produce one of these in 1/72?
Ta2-kLmsQ0LUm-9R4Per3RBVLD2fD0svqUz8PEGpEWiWg2M_QH8Aac-d7VceBqQxITF1tfvG0zJycoX1
I am hoping to scratch build a Massey Ferguson MF40 Towing tractor by basing it on a 1/76 Diecast David brown Tractor shown superimposed here.
GpUcxIAE0eWmnoWxidWQ4DQV2zA5u2xubg-AnifM
I shall also be adding a Lightweight RAF Landrover (to tow the Houchin) and TACR2 firetruck to the scene. This will all be a pretty good re-creation of the time when D Flt 22 Sqn Wessex where replaced by E Flt 202 Sqn Sea Kings in 1987/1988.
Sounds like a great plan. My first posting as a baby rigger was on Sea Kings at HMF, St. Mawgan so I'll be following this with interest. As for the TK, have you considered modifying one of Oxford Diecast's versions? The cab shouldn't need any work and the bowser body could be relatively easily scratch built onto a cut down chassis. Oxford also produce a TACR 2 that would be ideal.
I have ordered the 1/76 Oxford diecast RAF Centenary set (76set58) This includes a lightweight landrover and TACR2 (complete with red bonnet and correct Royal Air Force Fire Service markings.) The cow catcher also looks better than on their black bonnet version.
I had a quick look and this might make a good base. Thanks for the advise.
RR-XP0CAaXSIBRkShYSgfbNJm9VG8mSaX0BLqthx
Edited by AndyBunney
Houchin GPU kit arrived today. I actually only ordered one but they sent me a pack of two by mistake! Win win!
This is what they should look like when done.
ma6cEUbvjrso63Nu0glhnSqw5sqZ6SA6GTQ49PIB
Air-Graphics (in conjunction with L'Arsenal) have the Massey on their future list.  Test shot looks good.
The Mk5 GPU - most commonly seen with the Wessex is available from Flightpath.
We didn't have mk5 GPUs and who parked it that close to Walter?
That's the Douglas Taskmaster, not quite the same but does look good. The one we had was, I believe, made by Cameron Gardiner. We didn't have mk5 GPUs and who parked it that close to Walter?
I just looked at his website. I think Mr Air Graphic may have put the wrong name on his product.  He lists it as a Douglas Super Taskmaster which is this
His resin prototype, which does look nice, is of one of these which as far as I'm aware is a Massey:
Edited by Evalman
Houchin number one about to be started.
3BqlznXDhu2wFH2W04F02icZABcMw8xkBVYa5bM7
Parts prepared for assembly
TNFP2AIQnwbc8-FMFcxG80ZGcQvY869WwRcs1-ak
Finished Houchin awaiting paint & decals
fP_erz4l6C1qZDIl9ACVEGSL1aRGZ2B16iB5NOKu
And the completed article.
6dYDnHSuGMA2cO0BCoXVODNvDTcRrP6HHslEWLlz
Bowser and Houchin kits ready to start
cNQSOq9ao4wne7_ypD886mYJm4cNH_xbRqUg1iV5
Chassis, Tank & Pump unit assembled ready for paint.
UEtOT_5w4Qq_I3-zd12S-YdQaeOWqBX19jYZuYcg
And painted ready for assembly.
AAlx_hFRU_YBRwHS6XaXTy7IjeEf8bhTKpBqVGgG
Following on from a suggestion by paul_c I bought a cheap TK box lorry from Ebay It already had a twin wheel rear axle and round rear arches. Wheelbase will need cutting down but the box body can be used for the pump cabinet.
2JRIe2upjjIpVXK_At68hvqH9bxAdm2Fjx6Wmgms
Dismantled, box body cut to rough length and rear axle moved to approximate new position. Tactical MK alongside for scale.
PeAxnSx_FmNV5N0n0BTmsh6ql9FHFlJ9kwVIUACE
Height of box reduced to give correct fit. I think the box is still a few mm too long and I will have to round off the top more where it meets the sides.
2fs0l9cG4i-HwkUkE2zpnR9hIs02kbCaDZQHQXz9
Photos not loaded properly
I've now cut the pump box to the right length and moved the rear axle to the back of the chassis ready to cut 25.5mm out from the middle of the chassis. This should bring all the major components into the right place.
Vfi2W2K6UmON1rMboupFlOZx6yTm_itP6a8ZGMVh
Chassis is now the correct length, Rear axle in the correct position and a coat of Nato Green to cover the emerald green body and red wheels. Panel lines next and fire extinquisher stowage to cut out then the tank to fabricate.
SHGclbZfpy7QfOOj5oMdCNkY8INMXkyO2dv_yja6
With the Flightpath Diorama kit and Nitrogen trolley I shall have towing arms, chocks, fire extinguishers and I already have the TACR2 and lightweight Landrover, 2 Houchins and the Tactical Bowser. Better get on with the Wessex and Sea King soon!
NU2plIpmKRaS_dk00EgylCTfzHlsVM85tWRrwPXF
Made the beacon and mounting bracket. It is slightly too big but there is a reason for that and once the booms are mounted either side on top of the pump housing I don't think it will look too bad.
Ry-CFP0qtMv7tbGCYJMA2QoBhvLiPfs7hzVBh9iI
xXp2Fih8pe_EyNp75SaUjzrQ7XC583EkIBUtXgZf
And that's why it's a bit big! 1.8mm LED painted with clear orange hopefully it will be connected to a small flasher circuit set within the box running off a 3v battery.
Tank starting to take shape now. I think I will add some struts fore and aft before trying to wrap a skin round it.
1JbzZJ1PuQyO7LsHqBOY0WB9upI3yNMceeYQNnoZ
This is all your fault @paul_c😁
Ha! My pleasure! It's looking great though Andy!
Homemade battery holder installed in the pump cabinet to run the flashing LED
fh4IP527xtFWatr7qvJWvHZXqP8-LucMfJSZ65AC
Switch attached to chassis rail and tank & pump cabinet attached
WSnxTROTSnnU0mKpp74HhiYumkFNWUDtV73LJNeu
Basic construction complete and a thin coat of NATO green added to the tank, next thing to do is add booms and pipes, ladders tank access panels etc. Does anyone have ony pictures of the top of one of these?
0DGxp6m3XfI_o75osMfJxLEbAfiDwGZ_4E7wVtok
vasB70Z29iunSfBE6GpRRrGdNB98aWXc7VcEDfLR
Made a start on the ladder today. 0.4mm brass rod cut, bent and soldered together. Once the excess solder is cleaned off I think it will look good.
li-JWP4LJhZBo5mltoam-suILijrxXw_e1s-fjTK
Positioned on the rear of the bowser I think it needs to be a bit further to the left but I dropped my 0.4mm drill and broke it so will need a new one before I can re-position it.
iNCP03LRW-ouAu951dLTjOQrC8kMurtH0X53hgtX
