Degsy E39's 1/72 Airfix F4U Corsair
degsye39
Hi another entry from me..
An airfix oldie from the V.J. Day set boxing.. Looking at using the supplied decals (eeeek!) VMF 321 Hells angels.
The kit
I've just started with the ''classic' airifx pilot and some fuselage paint!
Cheers all!
welcome along with you'r second build, a Corsair this time, can't have too many of them in a build.
I don't know about the markings though, that squadron operated in the Solomon Islands, which is just outside the eligible range of this GB. The FAA and RNZAF were big uses of this aircraft and both are fine for this GB. Hopefully this doesn't put a stop to the build.
Hi rich.. I should of read the rules properly! Doh!
Anyway no bother, i am planning to purchase xtradecal sheet X72209 and model RNZAF NZ5632 ''Kathleen'' from that sheet.. I think this is eligible?
Only thing is i have painted my pilot in USMC colours but i think the RNZAF uniform may be close 🤔  I suppose i could always poke my brush into the *just joined fuselage and make some modifications? 😂🤣
Cheers chaps!
RNZAF Aircrew in the forward operational areas wore USN/USMC issue
flight gear as in the photo below, so your pilot will be fine
Quote
Bear in mind NZ5632 is a FG-1D (which flew in the Pacific Theatre), which wore overall
Glossy Sea Blue with RNZAF Pacific Roundel - You should be able to build this from the
decal sheet roundels and serial number.
NZ5632 Only served from June 1945, so won't be overly weathered
NZ5632 as "Kathleen" only wore this,  in Japan post WWII as part of the J Force
occupation
Regards
Alan
Edited by LDSModeller
added additional information
occupation
Regards
Alan
Alan thanks for the help chap :)
Though i would consider myself a ww2 aviation fan i i know very little of aviation in the pacific theatre!
Im presuming NZ5632 is just eligible for the GB, If not on the same hannants sheet we also have NZ5272/NZ5307  No.1 Servicing Unit Guadalcanal 1944
Im guessing i could do either NZ5272/NZ5307 as a failsafe!
Cheers :P
She was in theatre by VJ day but would only be Garrison Duties
One of the reasons she was chosen for J Force was she had little wear.
One of the other Corsairs on the sheet will do too :thumbsup:
Regards
Alan
Cheers :P
anything flown by the RNZAF in the Pacific during WWII is eligible
  • 3 weeks later...
Evening all made some progress on this and got the paint.. the mold is pretty trashed but im enjoying this oldie my only regret is i should of done a little scratchbuilding in the interior!
Some progress shots..
Getting there and determined to finish this and my zero for the 30th!
Here is my qaundary though lads.. I have put the paint down for corsair f4u-1a NZ5272/NZ5307 but i have only just realized that the airfix kit is a corsair f4u-1d
What are the differences between these two is it just the bomb racks?
Also should i be that concerned considering the airfix kit is BEYOND :P spartan and is lacking exhausts,interior detail etc.
Cheers!
Cheers!
In 1/72, I wouldn't be too concerned about the kit being
a 1D. The under wing hard points don't need to be added
(if the kit has them). The only other issue might be the Propeller
blades if for a late F4U-1D (wider type).
Looks good otherwise :thumbsup:
Regards
Alan
41 minutes ago, Corsairfoxfouruncle said:
The canopy on the 1A had the horizontal support beams.
HI Dennis,
I keep forgetting that not all F4U-1D model kits have  also the canopy
cross frame like the 1A's- Many if not all of the early F4U-1D's received
by the RNZAF also had the canopy cross frame..
If Degsye39 has the later canopy, sans cross frame, he can add it on
Later F4U-1D's/FG-1D's flown by RNZAF had full blown canopy
  • Thanks 2
I’ll take your word on that. You are more knowledgable about the RNZAF in WW2. I have added this info to my subject files. 👍
Dennis
Dennis
I can confirm the canopy in my kit has these support beams so i will carry on as normal!
Just kleared the bird! Decals tomorrow time for a KUTA
Cheers all.
Dennis
Hi Dennis,
The RNZAF F4U-1D's were a little different to their USN/USMC counterparts in that
they carried the plumbing, but never carried the under wing rocket stubs either.
FG-1D's did though
The accompanying photo link is of NZ5485 (Bu. No. 57473) one of the early 1D's, you can  clearly see
the canopy cross frame these 1D's had
NZ5485 RNZAF F4U-1D
Regards
Alan
as Alan mentioned the differences are relatively minor and for the most part you can get away with living everything as is.
These early Airfix kits were quite basic interior, though the pilot looks to be one of the more modern types. You're nearly there so push on and keep up the good work! :thumbsup:
14 hours ago, LDSModeller said:
HI Dennis,
I was wondering Alan if there was any mix-n-matching with the canopy's on the different models, if a canopy was damaged or an aircraft was used for spares?
Aaaarghhhhhh! Less than 24 hours to go! :frantic:
Almost done with this one finally nailed the winsor and newton galeria matt.. turns out all that i needed was a powered stirring device to get it really mixed with some flow improver (bizarrely the tub says to shake gently?! )
Best get the prop on and the radio mast and the rest of it! ;)
Really Looking nice :thumbsup:
As an Added bonus, you have it it in the proper colours and not some
daft Grey colour some modellers seem to think it wore - Thank you so Much!!:thumbsup:
No pressure, but it's 2030 hours December 30, here in New Zealand :D
Look forward to seeing yours finished :bye:
Regards
Alan
Regards
Alan
Thanks alan i actually started to paint the corsair humbrol 15 for the glossy sea blue at first! :o
Then i wisely did a little research and ended up using the paints below
These rusty little 17p tins went on a dream! good old humbrol.. Crusty corroded old tins that i had to emery paper for a while (paint was fine in every tin!) i bought 300 :o it was tiresome im afraid!
colors used are humbrol 181,144,134
