JOCKNEY
Scourge of the Atlantic
Hi Pat,
how is the repainting going?
I haven't checked you thread for almost a week and I expected to look at pictures of decals drying!
I spent a few days in good old Harare to find ubiquitous half a kilometer fuel queues at petrol stations, prices in shops that put London to shame and a thoroughly depressed mood... And I could not even access my BM site properly. So, nice to be back home! Now must rush to the B-17 GB to see what you have been up to!!!
So much stress!
JR
My continued apologies for not starting this one, I'm trying to get my Coastal Command B-17 finished in the B-17 GB, and naturally being male I can't multitask ! :frantic:
Cheers Pat
No probs there Pat, I was the same with my builds here, since the end date is further down the track. But now I must get on with them as my B-17 is now in the display case
Good for you Ray, my B-17 is currently parked on the living room table.
I am hoping to make a bit more progress tonight
cheers Pat
With the Coastal Command B-17 finished in the B-17 GB, it's long overdue getting the Condor moving. First thing was remove the interior repaint the correct colour and make adjustments until it fitted.
I found another reason the 2 fuselage halves wouldn't close was that there was no hole opposite one of the locating pins in the other half of the fuselage !
Next up a coat of interior green
IMG_4276
The observant amongst you will notice I have an unforeseen problem.
The Port Inner Flap part #54 is missing, see instruction page below. I have searched high and low without success and it's a bit big to be another victim of the carpet monster !
IMG_4275
So it's off to the wanted section here on BM you never know your luck :pray:
Cheers P
That´s a big part to be eaten, so it should keep the carpet monster fed for a long time before her next meal! Luckily, should you not be able to find the awol part or no luck at the wanted-section, you can always cut a replacement from a piece of sheet plastic, using the starboard flap desrever (=reversed) as a template. If you plan to show them lowered, that means of course some more work for the ridges :sad:.
V-P
41 minutes ago, Rob G said:
There's that, or this...
https://www.eduard.com/Eduard/Fw-200C-Condor-landing-flaps-1-72.html
You can thank me later.
:D
And indeed they are "cheap like soap", as we say here in Finland. Probably designed for the new tool Condor ( :hmmm:does that mean I suspect new tool and old tool aren´t dimensionally identical?)
Pat, I've got two of those old Revell kits. I could cut off the part you need and send it to you. Hell, I could just send you the whole kit.
I've got one of the newer Revell Condors so I can't see me ever trying to build one of those twisted & warped ancient monstrosities.
Chris
V-P
Thanks V-P, great idea but as you will see in a minute things have changed unexpectedly
:D
Hi Rob
Thanks very much for the idea, I didn't know these existed, although I now as you will see have an alternative solution
cheers Pat
Chris
Hi Chris
Thank you for your most generous offer which I was going to PM you about, when it occurred to me to look through my stash list to see if I had any spares. Better than that I found another whole kit !
No you are not seeing double this is a different kit
IMG_4282
Here are the contents, still well below the 25% rule so I will build this one and keep the wanted request so that I can pass on the other kit if I can find the missing part.
IMG_4283
cheers Pat
I was actually kidding about the etched flaps, actually.
Now that you have found a way to replace your missing bit, could I suggest that you have a go at moulding and casting the piece using the 'new' kit as a source? There's easy ways to do so now that we live in modern times. Just a thought.
Just caught up with this. All this talk of an "old" kit! When we didn't know that there was a Revell Germany (everything came from Potters Bar) the original Condor was moulded in a fetching shade of pale blue, so you didn't need to paint the underside. Show me one of those and I'll tell you that it's old!
You saved on paint that way too did you Jo? :D
Steve.
Absolutely. No need to paint when it's already the right colour! (At least when you're 9 years old). I did paint the top green though.
On 14/02/2019 at 17:03, Robert Stuart said:
Nice find Pat
Are the wings on this Condor any better?
Hi Robert
Oh yes, as you can see below the parts just fell into place, it almost seems a shame to glue them !
IMG_4284
Seriously (for a moment) the top and bottom parts of the wing are a shocking fit to each other, once the glues goes off I will be able to judge how much of a battle it's going to be to get the engines to fit.
Mean while I have been wrestling with the undercarriage which is a real piece of work, having assembled one side I have been searching hi and low for the other parts without success. Slowly being driven demented, then I checked the photo of the kit earlier in the thread the other one was missing before I started (see if you notice it in the picture with the white plastic parts) Still it wouldn't be half as much fun if everything was in the box ready to build would it !
cheers Pat
Following this with great nostalgia, built the original light blue plastic version when I was 11-12 & thought I was the bees knees 'cos I used stretched sprue to create the nose mounted radar. The Airfix 109 was released around the same time in blue plastic & to someone my age was utterly amazing, two decal choices, choice of two air filters/intakes & a choice of cannon pods or rocket launchers underwing, for two bob!
Indeed at least one 109 was completed with rocket launchers & gun pods, I'm not proud to admit it but I liked weapons on my planes, the more the merrier. I think the main reason I bought the Condor was it had so many guns & bombs, different kinds of guns too, cannons & machine guns, whats not to like. Simpler times.
I remember those days, when a kit had several decal options it felt like a waste not to put all of them on the model, so that's what I sometimes did 😊
Pat, you can do it - great work so far! I have this exact same kit and I went on to pick up other Revell 'Warbird' kits on the back of the level of 'working features' on this one. I am right with you to share your pain as I will come up with a similar excuse to build this one day! All the best. Mike.
