_alfisti_ Posted November 25, 2018 Posted November 25, 2018 (edited) Hi all. Found the new U-125A kit from Sword at yesterdays "Plastic Winter"- Show in Bratislava and for just €10,- I had to take it home😁. I will build 12-3028 in the nice dark "Offshore-Camouflage". I began with some basic painting in the cockpit and the cabin. Only added some tissue and seatbelts made from Tamiya tape to the seats. I hope I can finish the interior tomorrow and may close the fuselage. Regards from Austria Daniel Edited November 25, 2018 by _alfisti_ 9
Corsairfoxfouruncle Posted November 25, 2018 Posted November 25, 2018 I like that camouflage ive seen it on fighters but never a patrol craft.
Team Aer Lingus Posted November 26, 2018 Posted November 26, 2018 Oh I do like the look of that kit I wonder if Sword might release the 125 thanks for sharing Eamonn 2
_alfisti_ Posted November 27, 2018 Author Posted November 27, 2018 On 25/11/2018 at 18:25, Corsairfoxfouruncle said: I like that camouflage ive seen it on fighters but never a patrol craft. Like it too, looks amazing on the F-2 and F-4 but there are also Black Hawks wearing it. On 26/11/2018 at 11:38, Team Aer Lingus said: Oh I do like the look of that kit I wonder if Sword might release the 125 thanks for sharing Eamonn Would be nice if the release a 125, like the black scheme on that aircraft. 1
_alfisti_ Posted November 27, 2018 Author Posted November 27, 2018 Yesterday I finished the interior, I didn´t payed to much attention to details cause you will not see later. The windows needs some extra work to fit in the holes in the fuselage. The cockpit section is a bit to small in it´s diameter so I had to use some Evergreen Stripes to hold it in it´s correct place. Last step was some weight for the nose, don´t know if it´s neccesary but better than getting a tail sitter😁. I started glueing the two halves at the nose end, it needs slight effort but it could be worse. Regards from Austria Daniel 15
Team Aer Lingus Posted December 1, 2018 Posted December 1, 2018 looking good Daniel impressive start regards Eamonn
_alfisti_ Posted December 2, 2018 Author Posted December 2, 2018 Some progress on my U-125A. I allready closed the fuselage, without any putty, only some sanding was required at the end. On the fin I cut off the rudder. The fitting on the wing parts look also very good. Found some inlets and outlets to open... For a better handling I cut of the intake section of the engines, so i can fill and sand the inside befor putting in the fanblade. Cheers Daniel 14
huvut76g7gbbui7 Posted December 2, 2018 Posted December 2, 2018 That's quick work and I'll be watching your progress whilst waiting for mine to arrive. A company called Plamoya in Japan did a beautiful anniversary decal sheet in 1/144 for this aircraft so I have contacted them to see if they would consider doing it in 1/72.
_alfisti_ Posted December 3, 2018 Author Posted December 3, 2018 I know this decal sheet, found it on the internet when I was searching for some aftermarket items for my kit. Unfortunately there is nothing in 1/72 scale yet, would be nice if they bring out the sheet in 1/72 too. 1
Romeo Alpha Yankee Posted December 4, 2018 Posted December 4, 2018 You are doing a lovely job Daniel, I can't wait to get one of these. I like the refinements you are making to the kit 1
_alfisti_ Posted December 15, 2018 Author Posted December 15, 2018 Thanks mate👍 ...in the last two weeks some progress has been made. The clear parts for the cockpit fitted very well, only some putty was used to get a perfect smooth blending in this area. Next big step was the join up of from wings and fuselage. It needed a bit more attention to get them together. I did some sanding on the middle section of the wing to get it up and minimalize the step on the underside. Therefor on the upperside a bit more putty was needed. After some sanding an a coat of Mr.Surfacer1000 it look not bad at all. On the wingtips I cut of the position lights and made some new from a clear sprue. I over thought my approach with the engines and decided to take the easy way. So i started do make some FOD-covers. In the meantime the correct colors received from the dealer, will also need the in the future for my F-2 and maybe for a Phantom. Regards from snowy Austria. Daniel 11
Robin Posted December 15, 2018 Posted December 15, 2018 Hi Daniel. Coming along fine, sorry that the work on the engine clean-up didn't work to plan. Did you find any close up pictures to help with the work on the inlets and outlets, I found some good shots of U-125As on the UKAR webpage, there are some fantastic shots of Japanese Phantom camo markings, wouldn't mind doing a what-iff of a U-125A Squadron hack from an F4 Sqn. Robin
_alfisti_ Posted December 15, 2018 Author Posted December 15, 2018 Hi Robin. The engines are not an unsolvable problem but it would be a long way to come to a satisfying result, so I decided to quicken my build to get it ready for 2019th firs exhibition in february😁. Close ups of this aircraft seems very rare on the internet, couldn´t find much good pics. I´m also still looking for pics from the self defence pod which 27 and 28 are carrying underneth their wings. Daniel
Robin Posted December 17, 2018 Posted December 17, 2018 Hi Daniel. My kit of the model arrived today from MJW Models, excellent service with good packing and reasonable price. Found a couple of pictures of 28 on Airliners, in both dark and light blue with the s/d Pod, unusual looking item, the mounting rail looks a little like the old F4 Phantom missile mount, not too clear where it goes on the wing though. Robin. 1
Robin Posted December 17, 2018 Posted December 17, 2018 Hi Daniel. Had another search in Airliners.net, put in "U-125A." and got a page that had almost 100 pictures of the aircraft, including one with special markings, and a couple of 27 & 28. Robin. 2
David H Posted December 18, 2018 Posted December 18, 2018 Looks nice so far! A model building friend of mine who flies Hawker 800s/900s will find this interesting. On a unrelated note, this has piqued my curiosity about the Amodel Falcon 50s, since i fly one for a living. Thanks for posting! -d- 2
_alfisti_ Posted December 18, 2018 Author Posted December 18, 2018 Thanks for your coments. @David My interest in bizz jets is growing since I started this project, may I will get some other typs soon. With a personal connection like you got it´s even more fascinating to build a model. @Robin I will see how i went on with the pod, may I can find some more / better pictures. In the meantime i got some spare decals from a friend, so I´m able to build the 27, it got the more spectacular paint sheme.
_alfisti_ Posted December 22, 2018 Author Posted December 22, 2018 I went on with the U-125, adding some bits and pieces. The antennas on the fin were rebuild from old etched parts useing the kit parts for right dimensions and shape. The wing fences were sanded down as the were much to thick. The engines are allready attached to the airframe, only little sanding and some Mr.Surfacer 1000 was needed. On the pics below you can see some more antennas which was not included in the kit or were sanded down befor, so I made them out from sheet. Regards Daniel 5
Robin Posted December 23, 2018 Posted December 23, 2018 Coming along fine, the little details certainly help. Robin.
_alfisti_ Posted December 26, 2018 Author Posted December 26, 2018 Merry Christmas to everyone around! I found some time over the holidays to work on the U-125. Last little details were added bevor painting. A thin layer of Tamiya Fine Primer L shows the last little things to mend. I drawed the demarcation lines of the "Oceanic-Camo" on the primer. As I wrote above, I´m going to build the "27" not "28" from the box. So I used some pics from as reference , because the camo of 27 and 28 are very different. I started with the darker blue, Mr.Hobby C375. The s/d pods were also made with only photo references. I used different plates of sheet for it. They still need some work... Regards Daniel 10
huvut76g7gbbui7 Posted December 26, 2018 Posted December 26, 2018 Progressing well Daniel. Pictures of them with the pods are few and far between and I haven't found any of 001,002 or 003 with them. (I'll be doing one of those three) Those with the pods also have the RWR wedges on the tail bullet fairing.. Is it my imagination or is the fairing longer than that in the kit? 1
_alfisti_ Posted December 26, 2018 Author Posted December 26, 2018 I don´t realized the RWR on the fin yet🙈, thanks for your post. Had to change this detail immediately. You´re right, it´s longer than the normal, may to give space for the RWR. The pods were only mounted on 027 and 028, so you don´t have to pay any attention to them when building 001, 002, 003. 1
Robin Posted December 27, 2018 Posted December 27, 2018 Hi Daniel. Your rendition of the u/w pods is excellent, given the lack of information, I am still undecided where they should fit in relation to the flaps, time will tell. Robin. 1
