Airfix 1/24 Spitfire Mk1
Winter is coming and I have picked a real challenge, I think.
I had heard a lot of bad press on this and when I opened the box the initial impression was that a lot of what I was hearing was confirmed.
The kit seems pretty basic and the age of the moulding shows. It lacks the crispness of more modern kits, and I am clearly going to have do a lot of work here. I'm probably going to retain some of the minor defects.
I'm going to need to build a spar and I'm thinking I'll probably try and build in gun bays, wheel wells and flap detail and I'd be very grateful if anyone out there has anything they can let me have in terms of advice.
I do have this,
More later...
  • Like 10
Update on this, should anyone be interested.
I've spent a lot of time just thinking about how I'm going to do this and testing. The place I'm going to start is the wing which because the plastic is notoriously has tendency to flap about. This gives problems with the dihedral and so on.
First problem is the lower wing section.
Oh Wow. The only saving grace is that the piece is SO flexible that it should rectify when I glue everything together. Seemed to work OK when I taped it.
The second problem is the big void in the wing.
Cloudman1961,
I feel your pain. I have 2 kits of the Spitfire MK1 and P-51D and the JU-87 Stuka in 1/24th scale.. Bought them while stationed at RAF Lakenheath back in the late 70's. I still have them and with all the after market stuff out there I'll have to start building up replacement parts. Decals mostly. I'll watch with interest your progress.
Thanks
Ron VanDerwarker
32 minutes ago, Cloudman1961 said:
After a weekend on this, learning as I go. I've cut out the flaps and I'm about 80% through the internal structure I want in the port wing:
wish I'd seen this sooner.
Flaps were up on the ground unless down for maintenance.  You got fined for leaving them down.
Interior colour, apart from the cockpit forward of the seat bulkhead was aluminium paint,  engine bay, gun bays, rear fuselage, the inner leg of the wheel well, the outer wheel part is the underside colour (this gets debated, never seen a photo showing anything else though)
http://spitfiresite.com/2010/07/anatomy-of-spitfire-cockpit.html
Quote
The aircraft serving as our subject is Supermarine Spitfire Mk. Vb BL628 YO-D, recently completed by Avspecs Ltd in Auckland, New Zealand. Due to the fantastic quality of the restoration work which took full 30 years, the cockpit of this Spitfire conforms almost entirely to wartime production standards. For this reason, the following photographs can serve as reliable reference to the cockpit layout of the production Spitfire Mk. V.
note alu/grey green paint line,  and a Mk.V cockpit is very similar to a Mk.I as well.
this wartime shot, if you look carefully at the radio hatch and open gun bays cover you can see the Aluminium paint
3052829500_1ce4f68d71_o.jpgSpitfire in England by Etienne du Plessis, on Flickr
more wartime Spitfires in colour here
https://www.flickr.com/search/?w=8270787%40N07&q=spitfire
The PSL book has some good info, but it also 45 years old....
HTH
T
I built the Stuka earlier this year and it’s a pretty good kit, actually.
The only real problems were because of the age of the kit. The decals were pretty much throw away and some of the parts were brittle.
I used a Montex mask set instead of decals, and some aftermarket cockpit labels and stencils. You can build a pretty decent kit out of the box. I shared a few photos last week, if you’re interested.
I also have the P51D, and I’d be interested in comparing notes if you feel like opening the box any time soon.
Thanks for the correction Troy Smith. I didn’t know that. I thought I’d got that right so I obviously need to do a bit more research. You see a lot of conflicting stuff.
Im going with Sky wheel wells to tie into the lower body colour, aluminium for the undercarriage leg but until now, I was going to go with light a/c grey green inside the wheel fairing.
The ambition is to go with an aircraft in maintenance, including flaps down. But I’ll get to that as I go through.
Any pointers gratefully received.
Well the engine is there and you could pose it in a maintenance setting ? Probably need some greeblies and gubbins in there to busy it up.
What I had when I got all my household goods from a follow on assignment to Cannon AFB New Mexico one of the Mustang and Stuka was torn apart. I do have all the pieces that fell of the sprue trees in zip lock bags. The guns and engine parts of the mustang look great and beg for enhancement. On the Stuka, the engine mounts were broken off the fuselage halves. With that in mind it's been nearly 30 years since I returned to the US. So plans are to see what metal and resin parts are available and decals I'll order and place in zip lock bags for later use. So far your on the right track in your build. Press on with pride.
Ron VanDerwarker
Indeed, but we’re getting a bit ahead of our selves! 😉
Still trying to work out the wing!
On 11/26/2018 at 9:03 PM, Troy Smith said:
Troy Smith, looking back at this photo, is there any guidance on what is the correct colour for the squadron code letters?
Also I’m not seeing any of antenna wires that extend from the cockpit aerial back to the tail or the IFF wires. Presumably these were on later models, then?
Medium Sea Grey
Standard colour for all codes on Temperate Land Scheme  (TLS) fighters from 1938 to 1941, with the change to Day Fighter Scheme (DFS) and Sky codes
For a really good grounding in the basics of NW Europe Spitfire cam and markings, read the scans of this
Supermarine%20Spitfire%20Camo%20&%20Mark
here
https://boxartden.com/reference/gallery/index.php/Modeling-References/Camoflage-Markings/01-Supermarine-Spitfire
note on my monitor the above photo gives an excellent representation of the actual colours of TLS, in particular note that Dark Green is an olive green, not a blue green like Humbrol 30 suggested  in the instructions.
the photo is from late spring 1941, and is part of a series taken for Life Magazine. Other are in the link I posted above.
Not really up on this, depends on the radio.
Don't think the IFF had external wires.   Good questions though, try in the WWII section if you want more info.
HTH
not much really.
Aftermarket has skipped over these kits pretty much.   The ones that have been subsequently been done by other companies, there will be AM for those.
There decals and mask sets for some subjects, have a look on Scalemates
see (as I wrote note, which should have read not) now corrected.
for more on this....
11 hours ago, Alex Gordon said:
I think that this one had the IFF wire antennae,the attachment point is visible in the roundel.
The attachment point may be there, but not always the wire, or so it seems
Lok at this picture from the same source (Flickr):
Spitfire Mk. Vb.
4 hours ago, pinky coffeeboat said:
Does anyone know at which airbase the picture was taken?
Thanks,
Jeff
It's most probably 54 Sqn, in which case judging from the scheme and the fact the erks are in singlets, spring/summer 1941, which would put it as Hornchurch.
it's credited as 54 sq in the comments on this one
4181500566_4e42df0dd7_o.jpgSpitfire in England. by Etienne du Plessis, on Flickr
again, note aluminium paint on ammo boxes and open gun bay door.
2 hours ago, Troy Smith said:
this is the other photo in the sequence
3757129355_dd7a89479f_o.jpgSpitfire II. 1941. by Etienne du Plessis, on Flickr
captioned
Note the Albion refueller in the background.
That's obviously fake:
1) the panel lines aren't black
2) the panels aree monotone, all panels fade in the centre
3) no soot trails from the guns over the wings
4)tyres aren't flat
5) crowbar's wrong colour
  • Haha 6
4)tyres aren't flat
I think I love you.
4)tyres aren't flat
Haven't you ever thought of modellers having created their own ideas about what is the real thing. That the special embellishment of models have little to do with reality, but serves to please the establishment of co-modellers?
I believe that these photos tell the true story: (as you see, I totally agree with your commentary)
Spit-1
You have set yourself a challenge, but you've got Troy watching now to give you sound advice, and some good reference material.
I thought this kit was the bees knees when it was first issued ( I think I was in my mid 20s ) but when I bought another one about 25 years ago for old time's sake, I took one look at it and gave it away.
Watching with interest.
John
