L-39Z Albatros Update set, Seatbelts & Masks - 1:48 Eduard for Trumpeter Kit
These are sets for the new Trumpeter kit.
Update Set (49920)
This set has one brass fret & one nickel one. The coloured parts are primarily for the cockpit in the form of new instrument panels and side panels, There is also a new HUD, other cockpit parts, the insulated inside panels and rudder pedals.  There are new parts for the ejector seats, but not belts in this set.  For the airframe there are new landing gear wells, the inside parts for the airbrakes, and insides of the doors. There are new IFF antennas and vortex generators for the tail. For the engine exhaust there are some internal and external parts. There are a complete set of entry steps and some parts for the external stores. Finally there and canopy mirrors and some external antennas.
Zoom Set (FE920)
This is just the colour fret from the update set.
Seatbelts (FE921)
This set contains seatbelts, seat pads and ejection seat handles in the now familiar steel material.
Masks (EX611)
Supplied on yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the glazing.  In addition you get a set of hub/tyre masks for the wheels, allowing you to cut the demarcation perfectly with little effort.
Tface Masks (EX612)
Supplied on yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the glazing (inside & out).  In addition you get a set of hub/tyre masks for the wheels, allowing you to cut the demarcation perfectly with little effort.
Review samples courtesy of
