Smudge Posted November 19, 2018 Share Posted November 19, 2018 (edited) Hello Chap's, This is a little unfinished project from the Eleventh Hour GB, which recently finished. I was unable to get it finished in time, due to just being too busy and also partly to some procrastination on my part about how to go about achieving the 'summer camouflage' and which colours to use. The Roden instruction are a little confusing regarding the colours, but as best as I can work it out, it involves two greens and a brown. Anyhow, here is a link to where I was up to: https://www.britmodeller.com/forums/index.php?/topic/235044673-roden-172-albatros-diii-oeffag-s253/&page=2 And here is the start of the camouflage. I used a small piece of sponge dipped sparingly into some paint, and then just lightly dabbed on. Hope to do a bit more this afternoon. Thanks for looking Edited November 19, 2018 by Smudge 6 Link to comment Share on other sites More sharing options...
nimrod54 Posted November 19, 2018 Share Posted November 19, 2018 Good to see this one continuing Smudge, nice work on the camouflage. I did one of these with a swirl pattern but that was using decals. 1 Link to comment Share on other sites More sharing options...
Smudge Posted November 19, 2018 Author Share Posted November 19, 2018 Thanks, Nimrod. I have a sheet of 'swirl' somewhere in the stash. Always liked the look of it, quite striking I should think. I may have to dig it out and have a look. Well, here we are after some brown and a lighter green, all enamels. Where the sponge hadn't quite got into the little nooks and crannies I used a small brush to dab a little paint on, and to try and even everything out. So, not too bad, and I think when the decals are on it should look quite passable. Some heavy handed 'dabbing' has dislodged the starboard aileron, again! These are so thin and delicate. Nearly time for the upper wing to go on. Cheers. 7 Link to comment Share on other sites More sharing options...
nimrod54 Posted November 20, 2018 Share Posted November 20, 2018 That's looking great Smudge, you have made a terrific job of the camouflage. 1 Link to comment Share on other sites More sharing options...
Andwil Posted November 20, 2018 Share Posted November 20, 2018 Great little Albatros! You have done really well to sponge on the camouflage without breaking that rigging line from the lower wing to the nose, I would have snapped it for sure! AW 1 Link to comment Share on other sites More sharing options...
Smudge Posted November 21, 2018 Author Share Posted November 21, 2018 (edited) Thanks guy's. On 20/11/2018 at 12:33, Andwil said: ............sponge on the camouflage without breaking that rigging line from the lower wing to the nose, I would have snapped it for sure! Haha, yes. I would have done so myself. I usually use heat stretched sprue, that would definitely be broken by now. This is my first attempt with elastic rigging thread. It really does stretch quite a lot Well, I was hoping to be posting a few pictures of the Albatros with the upper wing on. However, whilst trying to glue it all together it became obvious that 'something was not right'. The central cabane struts were either too long or the outer V struts were too short by several millimetres. I tried to force it all together, but as one can imagine that did not quite work out. After giving this some thought and looking at a few other builds and reviews on the 'net, and some scale plans, I think the problem is lack of dihedral on the lower wings. I will need to try and get some 'upwards bend' into them, and this should help remedy the problem. Thanks for looking. Edited November 22, 2018 by Smudge 3 Link to comment Share on other sites More sharing options...
Smudge Posted November 27, 2018 Author Share Posted November 27, 2018 Ok, so here we are, upper wing on, and most of the rigging done. My first 'bash' at WWI rigging with elastic thread, and it was rather fiddly, but overall I think it is probably better than stretched sprue, once you get the hang of it. A bit of tidying up and then I'm looking forward to putting the decals on. Cheers Guy's. 8 Link to comment Share on other sites More sharing options...
Brandy Posted November 28, 2018 Share Posted November 28, 2018 (edited) Lovely paintwork, the camo has turned out beautifully! Elastic thread or monofilament fishing line is always (in my opinion) better than stretched sprue. You just won't be able to get the sprue thin enough for scale rigging. Ian Edited November 29, 2018 by limeypilot 1 Link to comment Share on other sites More sharing options...
Smudge Posted November 28, 2018 Author Share Posted November 28, 2018 Thank you, Ian. Yes, I think the stretched sprue will have to be filed away with the balsa wood and sellotape masking tape Link to comment Share on other sites More sharing options...
Smudge Posted December 6, 2018 Author Share Posted December 6, 2018 Ok. So just finished off a few small details, made up a windscreen from scrap plastic and tackled the decals. They were a little fragile, and the white arrow on the fuselage did break up whilst trying to slide it off the paper onto the model. I also used Winsor and Newton matt varnish for the first time, and I'm very pleased with it. Unlike some other 'matt' varnish I've used recently, this really does dry very matt and not a satin kind of sheen. So here are a few pictures, I will try and get some better ones for the Gallery latter. Thanks for your interest 10 Link to comment Share on other sites More sharing options...
Andwil Posted December 7, 2018 Share Posted December 7, 2018 Great work Smudge, that looks terrific. Is it Friedrich Navratil’s kite? AW 1 Link to comment Share on other sites More sharing options...
Smudge Posted December 7, 2018 Author Share Posted December 7, 2018 Hi Andwil, 15 hours ago, Andwil said: Is it Friedrich Navratil’s kite? Yes, it is. One of the options in the box. I was attracted to the camo scheme and what I guess is a personal marking. Glad you like it. 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted December 7, 2018 Share Posted December 7, 2018 Well done Smudge, that's a beautiful job mate. I have really enjoyed watching this one progress. 1 Link to comment Share on other sites More sharing options...
Smudge Posted December 8, 2018 Author Share Posted December 8, 2018 Thank you, John. I really enjoyed building it. I have a Roden SE5a which I think I will have a bash at in the near future. Thanks for the encouragement and following along Link to comment Share on other sites More sharing options...
Brandy Posted December 12, 2018 Share Posted December 12, 2018 That's turned out beautifully. Interesting style of cross on the tail for an A-H aircraft! Ian 1 Link to comment Share on other sites More sharing options...
Smudge Posted December 13, 2018 Author Share Posted December 13, 2018 Thank you, Ian. Yes, the cross is rather unusual. I just went with the kit decals I'm afraid, so I can't shed any light on it. The Roden kits do offer a remarkable choice of markings and they seem to be well researched, so I defer to their better judgement Cheers. Link to comment Share on other sites More sharing options...
AdrianMF Posted December 26, 2018 Share Posted December 26, 2018 That looks super! Love the camouflage effect. Regards, Adrian 1 Link to comment Share on other sites More sharing options...
stevehed Posted December 27, 2018 Share Posted December 27, 2018 Lovely job, very impressive. Although much later than the Germans the A-H did start to convert to the Balkan cross. Regards, Steve 1 Link to comment Share on other sites More sharing options...
John Masters Posted December 29, 2018 Share Posted December 29, 2018 Finally catching up on this. I am very impressed. Lovely paint job, excellent rigging. I feel that of all the Roden 1/72nd scale offerings, the Oeffag Albs are the best. Some of my favourites and you certainly nailed it. Bravo! 1 Link to comment Share on other sites More sharing options...
Smudge Posted January 2, 2019 Author Share Posted January 2, 2019 Thank you for the kind comments, guys. @John D.C. Masters glad you liked it. I'm looking forward to having a bash at the Caudron, but might get a few more 'easier' types under my belt first. Thinking about doing a little base for the Gallery pictures. Cheers. Link to comment Share on other sites More sharing options...
