Tubes
dov
Tubes
With Micro Tubes from Albion Alloy, you may create a better appearance of your model. We use for these matters the 0.5mm/0.33mm brass tubes and cut it in proper length of 5mm. alternatively, you buy it already finished in new silver as product number TB1 with 0.4mm/0.25mm 3mm long or TB2 with 0.5mm/0.33mm 4mm long. The self-cutting method is the cheapest, but you need a jig and a Dremel to cut it. Afterward the ends must be deburred.
https://www.albionalloys.com/de/
Well, the thing you have to care is, not to forget to put two of them on your filament.
Happy modelling
For any tube under 2mm I just roll a scalpel blade where it needs to be cut and then snap it off with a small pair of pliers. For 2mm I use a JLC razor saw blade (as it's hard-point) to score around the tube and then snap it off as above. Using this method the burr isn't too bad so a minimum of clean-up. I find it's quicker and gives a cleaner cut than using a dremel.
