DaveyGair
'Hettie SHALL make it to the ball!' ****FINISHED****
Ok, don't know if I'll get this done as I'm having a bit of 'modellers block' (see 'Butterworth Blenheim' in the Pacific at War GB).
Sprue shots show wing parts, fuselage removed just to test fit.  I'm doing Kitsworld's 'Hekla Hettie', an early 'F' model, so using the 'E' as a basis as this has the correct forward fuselage side glazing. I have QB paddle blades, engines and cowlings (apparently the kit parts aren't that good), Falcon clear parts for the frameless nose glazing, don't know how much I'll use of the Eduard Etch I'll use as I'm late into this!
Davey.
DSC_0015DSC_0016DSC_0017DSC_0018DSC_0019DSC_0020DSC_0021DSC_0022
After a huge lack of 'modelling mojo' I've finally got round to getting on with 'Hettie'.  19 days left, doable? well, gonna give it a go.
Fortunately the Academy kit is very simple in its breakdown of parts and lacks a fair bit of smaller details, so just going for 'effect' rather than adding a lot of said details.  I was going to add a radio room which the kit lacks, but that's going  by the wayside!
I started adding some Eduard etch into the cockpit, but lately I've lost any sort of 'steady hand' and the throttle levers etch aren't going to make it in!
I tried a bit of 'smoke and mirrors' by spraying a darker shade of Aluminium over some strips of masking tape to show some ribbing but don't know how that'll turn out when closed up.
Bit more paint to do in the cockpit yet, and I've started adding the small glazing in the nose which, so far, fit quite well.
Hope everyone had a good Christmas and have a Happy new Year!
Davey.
DSC_0028DSC_0027DSC_0025
The painted tape is an interesting idea since you only need the visual effect of ribbing.
Whilst looking on the net for more photo's of CC Fortress's, and having another look at the only shot of 'Hettie' I have found, I noticed she hasn't got an upper turret!  See here on this link https://wartimememoriesproject.com/ww2/view.php?uid=226205
I continued to try to find photo's of 251 (MET) Sqn machines, and I came across some pages from the book by Robert M. Stitt, of which I don't have a copy.  There were a couple of shots of 251 Sqn machines which show both no lower or upper turret, unfortunately not 'Hettie', but I'm now going with the fact that these all had them removed for the role they were employed for. The pictures show they still retained rear guns.
Interestingly, the book describes the two upper nose windows were 'plated over', so will incorporate all of this in my model.
Watch this space.
Davey.
Bashing on with this, as previously mentioned not going to attempt scratch building the radio compartment, so, with all the glazing installed the fuselage is ready to close up.
Anyone adding the Eduard detail set, be aware that the throttle/engine control quadrant fouls the seats, so remove the seat tabs and install them after fitting the etch part. It makes a tight squeeze when installing the cockpit though.
The fuselage halves look as though they will fit together very nicely, with minimal filler if any at all (famous last words!)
DSC_0034DSC_0033DSC_0032DSC_0030
Quick update, have added the blanking plates into one of the fuselage halves, then sprayed with aluminium.  Joined the fuselage halves and started sorting a couple of minor join faults.  The lower blanking plate had 'sunk' a bit so building up with filler.  Also noticed the starboard waist gunner's window had dislodged, so had to get it out.... good job I had left off the radio room upper glazing!
The bomb-bay doors weren't a good fit, but maybe just my poor modelling! , so will need some tidying up.
Busy sorting the wings, and tail gunner's position, which is made up of separate clear halves.
More to come, but don't know if I'll get this done in time.
Davey.
DSC_0036DSC_0037DSC_0038DSC_0039DSC_0040
A bit more done, started on the resin QB engines, cowlings and props.
Much removal off casting plugs on the engines and back plates which have to be glued together.  The cowlings had difficult (for me!) to remove casting plugs inside the front of the cowl itself, to preserve the rounded edge, but  found it difficult to blend in a round smooth edge.
12 separate blades to assemble, a jig is supplied to do this, got to take care to remove the blades and the hubs, the detail is superb on the hubs and can be broken off quite easily when handling, as I found out!
Photo's are a bit blurred, the auto focus on my camera has packed in and I'm not an expert at photography!
Davey.
DSC_0002DSC_0003DSC_0004
Bit more done.  Forgot, I had to add an astrodome to the nose so have been making some modifications 🙄
DSC_0007
I've also been starting to tackle the overdone main wing dihedral.  I decided to glue on the lower wing halves, adding some plasticard fillets to drop the angle. I also added the main wheel gear legs, which you have to do anyway before adding the top halves, to make sure they were going to be set correctly.
There is some flex in the wings, and when I add the upper halves, holding them against the root with tape across the full span, the dihedral will look better.... I think 🤔. This isn't scientifically done, I'm just comparing it to drawings on the net, on my ipad.
DSC_0005DSC_0006DSC_0011DSC_0009
The tailplanes are a nice fit, hardly any filler required.
DSC_0010
Tailgun position also added, used superglue which has affected the plastic, hope it doesn't look too bad on the glazed areas!
DSC_0008
Still plodding on with this, I think the Dihedral looks a lot better with placing 10 thou plasticard wedges in. Had to make sure the undercarriage legs were still correctly aligned.  Just got the joins to sort out and install the cockpit glazing, mask the glazed areas and do an initial undercoat to check all is well.
Hopefully will get this done before next weekend.
DSC_0005DSC_0006DSC_0007
Quick update, paint going on for better or worse!  Took ages to get the white on, Ultimate white primer which does not cover as well as their grey or black primers. Used Vallejo ModelAir RLM21 White. Masked off and put on Xtracrylix EDSG, ( I've had problems with this make of paint in the past but have now got to grips with, just me, not the paint, it covers well ).
Letting this harden a bit till I mask off for the Dark Slate Grey.
DSC_0011DSC_0010DSC_0009
Colours on, some overspray in places that I'll just make into 'weathering'.  Going to put a gloss coat on later and get on with the decaling this weekend. Have one of the grandchildren all day tomorrow so gonna get nowt done then!
Quickboost engines and cowlings are a bit better than kit items, someone with more patience and skill than me could add more to the engines but I just left them as is.
DSC_0012DSC_0013DSC_0014DSC_0015DSC_0016
Looks the business Davey, race you to the finish line :goodjob:
cheers Pat
cheers Pat
Well, I'm up to this point at the moment Pat, also busy painting the props and wheels.  Still all the 'fiddly bits to do and needs A LOT of touching up here and there. Hopefully see you t the finishing line but whether I get across before you remains to be seen 🤔
Davey.
DSC_0009DSC_0007
The fact that there is no upper turret, and the upper camo scheme extends along to the prop end of the cowlings (unlike what is shown on the 'Kitsworld Drawings) are based on photo's you can see following this link, just scroll down a bit and you'll find 'Hettie', 'Bess' and an unidentified B-17; https://wartimememoriesproject.com/ww2/airfields/airfield.php?pid=1883
The placement of the codes and the sharper angle of the upper scheme towards the tail are based on another 251 Sqn Fortress AD-E, shown on the middle photo of this link;
https://www.pinterest.co.uk/pin/472878029601067836/?lp=true
Come on Davey....
Watch you don't lose any bits between the cushions on the sofa !
Big push to the finish we are all behind you :goodjob:
cheers Pat
Well, I was determined to get her finished, and here she is.
The Kitsworld decals went on really well, responded well with Micro Sol/Set.
I fashioned a tailwheel strut but it collapsed during photography! Back to the drawing board 🙄
Overall a fair build, a lot of the tribulations were down to me and not the kit. It's a pity they have done the Dihedral way out but it is easily fixed.
I ended up using the nose gazing from the Revell kit as I made a mess of the Pavla Vac-formed one! The glazing does not fit well but serves its purpose.
Apologies to the B-17 'Buffs' for not improving/correcting the Carb'/Oil Cooler intakes, I'll do better next time 😉
Thanks for the words of encouragement and to the Host's for...….. well, hosting it!
Well done to everyone on their excellent builds, hopefully 'Hettie' will fit in well 🙂
Davey.
DSC_0014DSC_0015DSC_0018DSC_0024DSC_0023DSC_0021
E's only gone an dun it !
:partytime:
Much like yourself mate, its a thing of beauty  :winkgrin:
I have always thought these tail wheels were overrated, when a skid works just as well.
@vppelt68 is serving drinks and nibbles after midnight when the Gallery closes, look forward to meeting you
cheers Pat
Sure, whoever of you B-17 builders rings MY doorbell here in Finland shall not be disappointed regarding the number and quality of drinks and nibbles I shall serve :rofl2:.
Ding Dong !
:cheers:
