Blacktjet Posted November 15, 2018 Share Posted November 15, 2018 XN793 in green, with "flagship 92", appears to be missing the yellow "stitching" from the rear fuselage, normally seen on green F.2As. Does anyone know if it was not applied or were they applied in black? I can see the usual black portion on the underside. Any help would be appreciated. Link to comment Share on other sites More sharing options...
tweeky Posted November 15, 2018 Share Posted November 15, 2018 (edited) This is location for the rear trestle so I think it should be there. 5 years on F3's T5's & F6's and never seen one without the markings applied Edited November 15, 2018 by tweeky Link to comment Share on other sites More sharing options...
Blacktjet Posted November 15, 2018 Author Share Posted November 15, 2018 (edited) 21 minutes ago, tweeky said: This is location for the rear trestle so I think it should be there. 5 years on F3's T5's & F6's and never seen one without the markings applied Not those markings, the broken yellow/black lines that I presume mark the point where the rear fuselage can be broken to remove the engines http://www.airpics.net/photo/XN776-English-Electric-Lightning-F2A-Roy http://www.aviation-picture-hangar.co.uk/xn793kc.html Edited November 15, 2018 by Blacktjet Link to comment Share on other sites More sharing options...
tweeky Posted November 15, 2018 Share Posted November 15, 2018 The front ventral tank come off the no1 engine drops out. there's a top hatch (starts in front of the fin ) this is removed and the No2 engine is lifted out. if your referring to the yellow broken lines that run up rear fuselage that the trestle position when removing the radar bullet and the no one engine other wise she sit on her bottom. 1 Link to comment Share on other sites More sharing options...
Blacktjet Posted November 15, 2018 Author Share Posted November 15, 2018 Well that somthing new I've learnt about Lightnings. If you look at the picture of 793 in the link, it's either missing the broken lines or they are in black, just need confirmation. Link to comment Share on other sites More sharing options...
tweeky Posted November 15, 2018 Share Posted November 15, 2018 looks like the lower ones are there but the ones that would be in yellow are missing Link to comment Share on other sites More sharing options...
tweeky Posted November 15, 2018 Share Posted November 15, 2018 here and in bits so you can see the removed hatches and panels https://www.bing.com/images/search?view=detailV2&ccid=C3%2f13TCy&id=3053E97B503FD655D7E3D0A2DEC92895F92CBD59&thid=OIP.C3_13TCy0JfOVCiJ5Y3fsQHaEn&mediaurl=http%3a%2f%2fwww.aviation-picture-hangar.co.uk%2fxn778prm.jpg&exph=436&expw=700&q=lighttning+f2a&simid=608052859372702480&selectedIndex=156&ajaxhist=0 Link to comment Share on other sites More sharing options...
canberra kid Posted November 15, 2018 Share Posted November 15, 2018 Is it the two dashed black lines at the back end as here on XN733? If so, looking at this photo I would say they were not applied? John Link to comment Share on other sites More sharing options...
71chally Posted November 16, 2018 Share Posted November 16, 2018 Generally speaking the Green F.2As did have the yellow dashed marks, guessing some exceptions after a repaint etc Phil Bradshaw Flickr Link to comment Share on other sites More sharing options...
