Bughunter
Royal Aircraft Factory SE.5a "Night Fighter", Eduard 1/48
Out of a Eduard "Royal Dual Combo" kit in 1/48 I build a Royal Aircraft Factory SE.5a as Night Fighter. This is model number six of 2018.
Beside the kit I used further Eduard accessories, like Brassin radiator, wheels, stretchers and air screw hub. Some other resin and additional PE was already part of the Royal edition. The air screw is again a self made wooden one.
I used paints form Alclad, Gunze, Mr.Paint and oils for weathering.
The original SE.5a is shown in Windsock Datafile Special with two pictures and a color profile.
The kit and the accessories allows great details, but the build is a bit complex.
And now the pictures!
uc?export=view&id=1JCD7nkgfQsbpyDxhmfLc4
uc?export=view&id=1NHSfMixU9P-3gWthwrQaU
uc?export=view&id=1u7Vj3pmUZrS00yanCrrky
uc?export=view&id=1XrlRBNwN2dNuGXkQpwAVu
uc?export=view&id=1UFHthepRCEglvD1vuAlOa
uc?export=view&id=1aowoA7fABsrpNe2ni_SWZ
uc?export=view&id=1ia3ZiVBspR0Kf_IwrqwDL
uc?export=view&id=1PAZxFAhmX3jsq8UP2-W_2
uc?export=view&id=1JdcgNaaLSrefH78_iJ5OJ
uc?export=view&id=1gvZKRxP7y55GTlP0sAcFl
uc?export=view&id=1ITm7eADfSbmh5XTTQDI8V
uc?export=view&id=1na0C6ni_rlxHMkVaUs7C6
uc?export=view&id=1_nG37Quw4Bg4q0dBKlouc
uc?export=view&id=10DJG8f63u1kmHSvKC8sdw
uc?export=view&id=14uzCOCiEWvN6xv3Slsldt
The NIVO color (Night Invisible Varnish Orfordness) is a good camouflage :)
Frank
Excellent work :clap2: ... Really like the scheme. Are those flare launcers under the rear fuselage ? I imagine dropping a super hot burning flare on an Hydrogen filled dirigible would work.
Great job and admire your wooden prop.
Regards
Dave
Thank you all!
There are Holt flares under the fuselage. It was possible to fire them with the six start buttons on the right side of the cockpit. But not for dropping - the burning magnesia was used as landing lights. This gives a bright light, but with the big disadvantage, that the pilot sees nothing, if the flare is burned out and he do not touched the ground yet.
That is also the reason of the location - no direct sight by pilot. On some other aircrafts I have noticed such flares below the lower wing.
Thanks you very much for your comments!
My friends of the german model board ask for more details on the pictures, on a brighter background, so I made another set.
uc?export=view&id=1kcL0zngM_tFLp3reXH6tq
uc?export=view&id=1s5jVAzusDEbv3y3rOqp2g
uc?export=view&id=1vjoSpcnqYGy9IHAnWWNy6
uc?export=view&id=1sFqTLJOunJVgnjT5iYKeU
uc?export=view&id=1kk02s1XkL7KG3R49A76JF
On the right side there are the six starter buttons of the flares visible:
uc?export=view&id=1wH59wx0VKQvUQBXwQB7II
uc?export=view&id=1C_C5VOgp90CWZMOwgYCY2
uc?export=view&id=1qaBs28sWZMtJfxuS4qOvu
uc?export=view&id=1Tos49Owr23cKjW8ws-RbG
uc?export=view&id=1rdAbm329SSzTKi6k_uZtJ
An a open air experiment from the balcony:
uc?export=view&id=18NkBFNElKv13zNmwjoVBa
Frank
Completely agree with Marco -0 those pictures are much better and show what a fantastic model this is.
P
Thank you!
With the first set of pictures I wanted to capture the dark atmosphere of the dark Night Fighter painting, even if some details are lost then. The color is really dark and depending on angel and light the green looks even different.
Frank
