Julien Posted November 3, 2018 Posted November 3, 2018 Messerschmitt Bf 109G-4 (84149) 1:48 Eduard Weekend The Messerschmidt Bf 109 is one of the iconic aircraft of WWII. The G models arrived in 1942 and the G-4 was nearly identical to the G-2 but was fitted with a much improved VHF radio set. The R versions were also designed for reconnaissance some versions of the G-4 were fitted with underwing canon pods. Due to the increasing weight of the G models larger main wheels were fitted which resulted in the teardrop fairings on the upper wing surfaces. A larger tail wheel was also fitted and the retraction mechanism removed as it was too large to retract. 1242 G-4s were produced in total. The Kit This is a weekend boxing, with 4 sprues of plastic, a clear sprue, and a small decal sheet with 2 options. Construction starts shockingly enough with the cockpit. Various control wheels and the main control column is added along with the armoured seat back. Following this the seat pan and rudder pedals are added. Following this side panels and parts are added into the fuselage sides. Once all of these sub-assemblies are made up they can be placed inside the fuselage and this closed up. As well as the cockpit the tail wheel and exhausts need to be added before the closure takes place. Once the main fuselage is together the intake needs to be added on the side. For the tropical version this will need the additional filter adding as well. Construction then moves to the rear of the main fuselage with the tail planes and rudder being added. All of the control surfaces are separate so can be posed as needed by the modeller. Next up are the wings. The lower is one part with left and right uppers. The wheel well detail needs to be added into the lower wing and then the uppers can be added on. Once complete the wing assembly is mated with the main fuselage. Next up the leading edge slats and ailerons can be added. On the underside of the wing the left and right radiators are assembled and added to the wing. The flaps can then be added making sure to get the radiator flaps at the correct angle. Moving towards finishing the model the main landing gear units are completed and added to the model. The wheels are a single part with a left and right hub. The gear leg is attached as is the door. The canopy parts can then be added not forgetting the pilots head rest & armour in the main centre part. Last but not least for the main kit the propeller and spinner are added. Decals Decals are in house from Eduard and should pose no issues. There is a main sheet and a supplemental sheet for the stencils, markings are provided for 2 examples; Bf 109G-4/R6, flown by Hptm. Waldemar Wübke, CO of 7./ JG 54, Lille – Vendeville, France, February/March 1943 Bf 109G-4/R6 Trop, flown by Lt. Franz Schiehs, CO of 8./ JG 53, Tindja, Tunisia, April 1943 Conclusion This is a welcome new G-4 release from Eduard in a weekend edition. Highly recommended. Review sample courtesy of
