fjaweijfopi4j48 Posted November 3, 2018 Share Posted November 3, 2018 (edited) A model from 4 years ago: I really enjoy and applaud every time a manufacturer ventures beyond the usual frontiers and presents something refreshing. In this case, Special Hobby offering started nevertheless as a war bird, as you can tell for the machine-gun holes and other clues. These exact molds were first released as such. But then, in a welcome turn of inspiration, Special Hobby went for the racers to which many of this military machines were converted after the war. The decal sheet offers no less than four choices! The complete kit package is constituted by multiple resin parts nicely and cleanly cast, a small photoetched fret, a piece of printed film for the instrument panel, extensive decals as said before, two (!) vacuformed canopies and several pages of instructions. All of the items are neatly bagged and therefore protected, only to put them in one of those self-squashing, end-opening boxes. The model is not new now (2014) but it is still available for a reasonable price. The price is reasonable, sure, because the moldings show the effects of a lesser molding technology, with no locating pins, thick gates and prominent seam lines. Very little flash is present, but to get out some of the parts is not easy, and I broke two -that I promptly repaired- even when I was extra careful and, err, have been doing this for a little while. The surface detail is very good, and dry trials showed a not too precise fit, although not bad either. The masters for these parts were superb, but the technology for the fabrication of the kit traded low cost for some loss of quality. So be it. This subject is a tad outside my usual choices' envelope and is the one portrayed in the box art, but bear in mind that the contemporary machine you see on the Net is not exactly like the original machine that participated in the races in the late 40's. You get parts for both, as well as others to cater for some little differences between the other subjects in the decal sheet. Beware that in spite the abundant decals some areas still have to be painted, in this case white at the front of the nose and the vertical stabilizer tip. Always study your photos (NOT drawings) and compare, then take notes and proceed. The kit got an incorrect 9-cyl row engine, but the kit I am building has a 7-cyl row that came with later -corrected- releases, although it still has three magnetos instead of the seven needed. And so it began: As soon as I compared the "corrected" resin engine with the real thing I noticed that if it was true that the cylinder count was now correct, the cylinders themselves were not; being the shape, pushrods, configuration, all not accurate. So I ordered and Engine & Things P&W R-4360 aftermarket engine and to hell with the kit's one. Then I turned my attention to the resin bits. There are three things I don't like about resin parts: 1) When they are bad (NOT this case) 2) When they do not have a good fit (more on this) 3) When they are ridden with flash, pinholes, bubbles, etc ( again, NOT this case) 4) When the pouring blocks are not intelligently or practically connected to the parts themselves (more on that) 5) That they are made of resin (more on that too) Sorry, did I say I didn't like three things about resin parts? I guess they were more. The resin parts as said are good, well detailed, and mine had no blemishes whatsoever. While most came out obediently from their pouring blocks, the wheel wells were cast in a way that made very difficult to remove the excess resin, and this is critical because these parts are trapped between the wing halves, and of course, like every other resin cockpit and wheel well in the universe, they do not fit, being too thick (point 2). But if you sand too much, you will come through the wheel well roof , ruining the part, so WHY was the pouring block located there (point 4)? Anyway, you will have to sand too the wing parts to allow for the part to fit. As you sand the resin parts you produce an interesting amount of harmful resin dust, a health hazard. So the more you have to sand away those pouring blocks and the parts for them to fit the more crap you generate. I use a mask and do it partially under running water, but the stuff surely gets somewhere else too (point 5). The resin exhaust stubs are correct for the original racer (the two top on the sides being larger and the two lower ones shorter). The contemporary rebuilt plane has all four side stubs of the same length. The kit manufacturer omitted the ones that run underneath the fuselage, another three pairs of them, that you will have to scratch and add. The prop is too small for this variant,. Another glitch that keeps you in "step 0" fixing things and thus unable to proceed with the building itself. It is good that the overall quality of this kit is so high, and that's a strong motivation to persist. All these minor issues are not something terrible, and are relatively easily taken care off. But I have one complaint: the fuselage is split in two halves as usual vertically, but all the way up to the front; no separate cowl, no separate lip. This for me is a mistake, because you trap the engine as you join the fuselage, therefore corrections on the joints inside the cowl's lip are very difficult. A separate front lip was all that was required, and as it is, is reminiscent of bad and old kits. I was tempted to cut the cowl off and assemble it separately, or at least cut the lips off and join them apart, but decided against it in order not to mount even more corrections and tidying ups. The model shows the beautiful lines of the original now at the service of a more peaceful purpose. I liked this one, especially for the well-cast resins, the crisp and sturdy vac canopies (2!) and the superb level of surface detail; although it is not -as any other kit- without its issues. The decals cover many subjects and the graphics and register are superb, but they are really fragile and shatter easily, and there are a few wrong calls in the numbers. The decals adapt to the surface detail superbly, but are a pain in the neck to handle. There are, as you know, other good-looking racing colors and designs for this kit. As I commented, there are some differences between the restored machines and the originals, so study your references. Although restorations and rebuilds of planes are commendable and deserve high praise, as a norm I never trust them as a source for information regarding the original machines, since invariably something is off. And it is in this case as usual. You could model, of course, the contemporary machine and be done with the issue, but I am a nostalgic and enjoy digging in the past to rescue as much as possible of the golden glory and charm of the vintage subjects. As you may know, besides this Special Hobby kit, there is an Aviation Usk / Xotic-72 kit of the same plane, but I can't comment on it since I have never seen one. This model requires care and attention, and for sure some skill, but the reward for your no little efforts is a stunning racer with lots of pizzazz. Edited November 3, 2018 by Moa 34 1 Link to comment Share on other sites More sharing options...
Dazey Posted November 3, 2018 Share Posted November 3, 2018 Hi Moa, That's a lovely model, and a refreshing change. I'll have to keep an eye out for some of these kits (once I find a Gee Bee racer, that is). Regards, David 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted November 3, 2018 Share Posted November 3, 2018 BEAUTIFUL F2G !!! 1 Link to comment Share on other sites More sharing options...
hsr Posted November 3, 2018 Share Posted November 3, 2018 Nice build. That Engines & Things r-4360 has been out of production for a while and impossible to find. I don't suppose you got 2 ❓ 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted November 3, 2018 Author Share Posted November 3, 2018 38 minutes ago, hsr said: I don't suppose you got 2 ❓ Nope. 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted November 3, 2018 Author Share Posted November 3, 2018 47 minutes ago, hsr said: I don't suppose you got 2 ❓ I just sent an email to E&T, asking if it would be possible to do a limited run of them. You guys may like to write to show your interest, so it's worth for them to do it. [email protected] 1 Link to comment Share on other sites More sharing options...
Spitfire31 Posted November 3, 2018 Share Posted November 3, 2018 Slick looking machine! Kind regards, Joachim 1 Link to comment Share on other sites More sharing options...
Unfinished project Posted November 3, 2018 Share Posted November 3, 2018 That’s a beautiful Corsair Moa the glossy finish is flawless 👍 1 Link to comment Share on other sites More sharing options...
Courageous Posted November 3, 2018 Share Posted November 3, 2018 That's rather cute. Stuart 1 Link to comment Share on other sites More sharing options...
hsr Posted November 3, 2018 Share Posted November 3, 2018 7 hours ago, Moa said: I just sent an email to E&T, asking if it would be possible to do a limited run of them. You guys may like to write to show your interest, so it's worth for them to do it. [email protected] I tried that a while ago and exchanged emails with Linda.. Unfortunately she stopped because the molds kept tearing and she just couldn't make them work. 2 Link to comment Share on other sites More sharing options...
RidgeRunner Posted November 3, 2018 Share Posted November 3, 2018 You did again, Moa. I wouldn't have expected anything less Martin 1 Link to comment Share on other sites More sharing options...
72modeler Posted November 3, 2018 Share Posted November 3, 2018 9 hours ago, hsr said: Nice build. That Engines & Things r-4360 has been out of production for a while and impossible to find. I don't suppose you got 2 ❓ Aeroclub did a metal R-4360 front, which I have. It's OOP, but you might be able to find one and cast as many copies as you need. You're not going to see the other three rows anyway. I also have the Engines and Things resin engine- wish I had bought more when they were in production. They do have the accessory section at the back of the engine, for those insane types who want to expose it and scratchbuild the bundle of snakes that comprise the exhaust manifolds! Mike 1 Link to comment Share on other sites More sharing options...
Toryu Posted November 3, 2018 Share Posted November 3, 2018 Wonderful F2G! I've always wanted to convert one of the test planes in 1/48 but it would be my 538th project... 1 Link to comment Share on other sites More sharing options...
Skymonster Posted November 3, 2018 Share Posted November 3, 2018 (edited) Sadly she doesn't race anymore, but having watched her at close quarters going round the pylons in Reno at <150ft and 350mph+ - along with as many as seven other former warbirds - she was a true sight (and sound) to behold, something I will never forget. The model captures the essence of the Super Corsair very very well... Edited November 3, 2018 by Skymonster 2 Link to comment Share on other sites More sharing options...
TheLurker Posted November 3, 2018 Share Posted November 3, 2018 What a little stunner. 1 Link to comment Share on other sites More sharing options...
72modeler Posted November 3, 2018 Share Posted November 3, 2018 2 hours ago, Skymonster said: Sadly she doesn't race anymore, but having watched her at close quarters going round the pylons in Reno at <150ft and 350mph+ - along with as many as seven other former warbirds - she was a true sight (and sound) to behold, something I will never forget. The model captures the essence of the Super Corsair very very well... Yep, nothing like seeing and hearing an R-4360 at full song with the air whistling through the oil coolers at a ridiculous speed around a pylon to get the juices flowing! I have never had the pleasure of watching one of the F2G's race, but have heard Unlimited racing Mustangs and Bearcats...that's what Depends were truly made for! Mike Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted November 3, 2018 Author Share Posted November 3, 2018 (edited) 6 minutes ago, 72modeler said: watching one of the F2G's race, Speaking of races and Texas, I love the sound of the supercharged B2 (not quite the spelling, but with a little of imagination..) It's like...an intelligent sound. Edited November 3, 2018 by Moa to correct typo 1 Link to comment Share on other sites More sharing options...
Feelip90 Posted November 3, 2018 Share Posted November 3, 2018 Wow, unusual Corsair! 1 Link to comment Share on other sites More sharing options...
Fastcat Posted November 4, 2018 Share Posted November 4, 2018 Great subject, great treatment and lovely to look at. Nice to see these old warbirds with a smart new scheme and a new lease of life. Wonderful. Dave 1 Link to comment Share on other sites More sharing options...
greggles.w Posted November 7, 2018 Share Posted November 7, 2018 On 11/3/2018 at 12:07 PM, Moa said: a stunning racer with lots of pizzazz. Indeed! Well done, congratulations 1 Link to comment Share on other sites More sharing options...
Alpha Delta 210 Posted November 7, 2018 Share Posted November 7, 2018 Another wonderful model from the Moa hangar! Keep them coming. 1 Link to comment Share on other sites More sharing options...
F-32 Posted November 8, 2018 Share Posted November 8, 2018 That's really smart, bet that Corsair could move! 1 Link to comment Share on other sites More sharing options...
danntheman Posted November 8, 2018 Share Posted November 8, 2018 Love it, great finish, and I love a bit of colour after all the drab finishes. 1 Link to comment Share on other sites More sharing options...
pheonix Posted November 8, 2018 Share Posted November 8, 2018 Super finish and impeccable photography. How nice to see a familiar type in unfamiliar colours - and such striking ones too. P 1 Link to comment Share on other sites More sharing options...
