andmarsh Posted November 1, 2018 Share Posted November 1, 2018 Hi It was all going so well,,,,, managed to gunk up the windscreen when fitting - is there anyway to get this superglue off, have tried thinner and nail polish remover Link to comment Share on other sites More sharing options...
Bill.B Posted November 1, 2018 Share Posted November 1, 2018 (edited) Been there, done that, but don’t worry all is not lost. My suggestions to effect a repair would be as follows: If it’s only a smear I would use automotive T-cut (or some other fine liquid cutting agent) applying it with a cotton bud (or cotton cloth) and gently cut back the affected area. When finished any liquid car polish can be used to finish off. Alternatively you could use Tamiya’s own polishing pastes. If the glue is quite thick then the only course of action is to use various grades of ‘wet or dry’ paper, possibly starting at 2400 grit and working up to 12000 grit, and then finishing off with a liquid polish. If you choose this method don’t forget it is essential to use the grit paper ‘wet’ for best results. For future projects could I suggest you perhaps try Revell’s Contacta Clear instead of CA? I’ve found this to be ideal for clear parts as it has a fairly quick setting time and is completely clear when dry. Edited November 1, 2018 by Bill.B Link to comment Share on other sites More sharing options...
Black Knight Posted November 1, 2018 Share Posted November 1, 2018 You can get a tube or small bottle of superglue release. Meant to release your fingers from that piece of photo-etch. Not only do I use it for that but also to remove unwanted superglue blobs off kits. It does not harm the plastic at all 1 Link to comment Share on other sites More sharing options...
andmarsh Posted November 1, 2018 Author Share Posted November 1, 2018 thanks everyone , almost done with my first Tamiya car- Link to comment Share on other sites More sharing options...
rayprit Posted November 1, 2018 Share Posted November 1, 2018 Quote http://www.finescale.com/videos/how-to-videos/2013/04/repairing-clear-parts polish it out...……………………...video here Link to comment Share on other sites More sharing options...
Black Knight Posted November 1, 2018 Share Posted November 1, 2018 Why used destructive polishing when you can buy a tube of superglue release which will take it off easily and cleanly? Link to comment Share on other sites More sharing options...
cmatthewbacon Posted November 1, 2018 Share Posted November 1, 2018 You must have different superglue release... The Roket Glue Buster I have will certainly soften the surface of plastic, and I've never dared get use it on a clear piece... For future reference, it's hard to beat Formula 560 Canopy Glue for attaching clear parts -- it's basically PVA that dries crystal clear. Has no effect on plastic, glues very firmly, and can be softened and removed with water if you need to... best, M. Link to comment Share on other sites More sharing options...
