JWM
Three amphibias: Duck, Goose, Gosling
Hi
I will try to do three amphibias of WWII by Grumman: Duck (Airfix), Goose (Sword) and Gosling (Pavla).
Duck will be my second attempt on this kit after 50 years (!) - first I did at age of 9. It was my second "serious" model of airplane (if I do not count some Ruch models made before) in 1/72. Serious also means that it was painted and models done before it were not painted. . As far as I remember and then after about next 10 years I broken it into pieces, washed out all paint  and - converted it into.... Ge-23 (FF1) which is still existing on my shelvs! I posted it not long ago on RFI:
So I am not decided on version and scheme yet. Maybe it will be J2f4 converted from j2f6.
Second will be Pavla Gosling or Wigdeon - in colours of US Coast Guard from 1942, so not yellow/silver  but blue/gray colours. I have never done Gosling/Widgeon before.
The third one will be Goose in some US colours. The kit is by Sword. I have no experience with Goose neither.
I will post photos of kits in another post very soon. I have to do them.
Regards
Jerzy-Wojtek
Sword Goose:
Gosling/Widgeon by Pavla
Airfix Duck
To be cont.
Regards
J-W
Edited by JWM
Nice choices!
I see a spray rail in the Goose box art. I'm not convinced any USAAC/USAAF or USN Goose ever had those spray rails. I was led astray by this when I built CM's 1/48 Goose.
Good morning J-W
 Welcome to this Gb with this very interesting trio ..
Enjoy your build
Patrice
If you were a glutton for punishment, you could add in an A-Model Albatross, and a lot of filler...
Excellent choice of subjects!
Regards,
David
I gathered drawings for Duck scaled all to 1/72. However now I have to judge which is the best one, since they change a lot one to onother,,,
Any suggestions, comments?
Regards
J-W
I see your drawings show a J2F-4, -5, and -6. Is your kit a "Duck", which could be an amalgam of versions, or a specific version?
My kit is J2F6 since it is Airfix. My question is a bit aside of my build - on some drawing J2F5 and F6 have the same cowling, on other F5 has shorter then F6. I have to judge which is correct? For me it is a general test for credibility which drawings use as the proper one.  If I look at photos F5 has indeed shorter cowling chord than F6.
(of course we are talking about NACA cowling of late variants, not the very short Towdend of early machines)
The F6 is characteristic due to to air  outlets shortly behind the cowling, like here:
J2F4 sometimes is shown (descripted) as mashines with Towdend, sometime with NACA cowl.
J-W
True, the drawings themselves could have mistakenly included or mislabeled features from multiple versions. And, photos of specific aircraft could have post-manufacturing modifications further confounding identification. And in particular, a current aircraft, airworthy or not, could have just have the wrong parts due to availability.
I have some J2F materials from Grumman. For the -4, I have their 1/48 scale "Model Builders Drawing", and for the -5 the "Erection Procedures." The -5 document should be authoritative since it was contemporaneous with the aircraft. The model drawing is from 1966; so while from Grumman, it's not quite primary documentation.
Edited by dnl42
Grammar
This Goose landed on the Avon River, at Windsor, Nova Scotia, while transporting WWI ace Billy Bishop from Halifax to Ottawa. About 3 miles away, above the port engine, is the home of my grandparents. My father bought it from his brother, who had inherited the farm and that's where I grew up before I moved west in 1980.
https://www.geocaching.com/geocache/GC192P5_billy-bishop-visits-windsor-feb8?guid=b88c90ae-e950-4f12-a23a-a36e2607fcdc
.item?app=fondsandcol&op=img&id=a092528-
Chris
Notice than neither of these photos show that fine spray rail.
Can you tell I'm still peeved I included it on my build?
I strated work on Goose and Goslling which will be almost OOBs.
Here what I have:
Gosling:
Goose
The Duck will be build a bit later since it will be a conversion to J2F5 (most likely)
Regards
Jerzy-Wojtek
The riging of small floats I have to do before glueing wings together.  So in both Goose and Gosling I drilled holes in floats and glued them to bottom  halves of wings:
In case of goose i have to study more photos to check more precisely the places for drilling the wings...
I made more slim and shaped props of  Gosling today also (left after, right before it):
That is all for today, let the float get fixed
J-W
Here's another view of a Goose that may help. Czech Models' 1/48 kit has markings for this aircraft. The decals are fine, but CM's placement guide and airframe colors are incorrect
Ambitious build thread. I'll be following along as I'm doing a Goose as well, albeit in FAA colours. So far I've only done a bit of painting but have had to clear out massive ejection pins from the wheel wells. Good luck with all three.
Edited by 825
Many thanks !
Today only Gosling.
Riging of floats . One have to do it before wings are glued together. Then you glue wings. This is result:
And some more of inside
J-W
