neil5208
B17E Old Maid ser 41-2409 Finished 09/01/19
My build will be of Old Maid, one of the B17E's repainted in the Haywain Air Depot camouflage scheme after the attack on Pearl Harbour, I will be using the Revell B17F kit. I know that the aircraft would have had the Sperry lower turret fitted but some of the images that are available show the aircraft was retro fitted with the later F model ball turret and the kit has the earlier style nose glass with single mg mount so show be fairly accurate. I recieved the kit as a birthday present and made a start before I knew about the GB but only did a few parts before joining.
45463678711_ef100f3b54_h.jpgIMGA0342 by neil Connor, on Flickr
45463677851_905210ca9a_h.jpgIMGA0341 by neil Connor, on Flickr
43646410300_b3008f9c9e_h.jpgIMGA0340 by neil Connor, on Flickr
45463678331_9e30befeb8_h.jpgIMGA0339 by neil Connor, on Flickr
Now the GB has started I can get stuck in
Edited by neil5208
Some progress to report interior mostly sprayed, seats will be next to be made up. Start one ot the wings and followed the kit instructions before finding Tom Proberts post that the wheel wells were aluminuim rather than interior green
45586295941_b84dc7626a_h.jpgIMGA0468 by neil Connor, on Flickr
44861402544_e7267b26e6_h.jpgIMGA0469 by neil Connor, on Flickr
44861402354_e2e0f76599_h.jpgIMGA0470 by neil Connor, on Flickr
45535793862_2439ac96e4_h.jpgIMGA0471 by neil Connor, on Flickr
45535793662_638b052d8c_h.jpgIMGA0474 by neil Connor, on Flickr
Been quite busy off late but managed to get some work done on the old maid yesterday, radio room is done and start made on the 2 turrets. As you can see masked up and sprayed silver, also sprayed the inside of the clear check pieces so they will be ready to slot in soon. Bomb site fitted to bombardiers position. Revell's instructions for painting are terrible some small parts have no paint reference at all.
31115303317_303f3b1794_h.jpgIMGA0508 by neil Connor, on Flickr
31115303477_cc6d5a23f4_h.jpgIMGA0507 by neil Connor, on Flickr
44238306680_9843c9cbd2_h.jpgIMGA0509 by neil Connor, on Flickr
44238307250_b52a387ccd_h.jpgIMGA0510 by neil Connor, on Flickr
So, just a small update for last week. The waist gunners ammo stowage is in place, but I relocated it as Revell would have it to far away from the gun to be usable. Upper ball turret id one but I have yet to finish the lower turret. I have 3 weeks off for christmas so should be able to get alot done then.
45243410055_1313483b30_h.jpgIMGA0514 by neil Connor, on Flickr
46105043142_93a4d216f6_h.jpgIMGA0512 by neil Connor, on Flickr
This is where Revell would have the ammo box positioned.
46105042892_aadbb4633d_h.jpgIMGA0515 by neil Connor, on Flickr
46105043052_51753ec60e_h.jpgIMGA0513 by neil Connor, on Flickr
The starboard side one wasn't to far off but the port side was, also don't know why they didn't have a right hand feed gun. If I had more time I would correct the short floor in the rear fusalage and mount the ammo boxes as they should be.
Edited by neil5208
So the fuselage is together... just needs a bucket of filler.
31240364967_a0aa34da35_h.jpgIMGA0516 by neil Connor, on Flickr
46128834442_7fa2b83cd0_h.jpgIMGA0517 by neil Connor, on Flickr
31240364697_39eee087ed_h.jpgIMGA0518 by neil Connor, on Flickr
And said filler!
46128833992_f7d1364787_h.jpgIMGA0519 by neil Connor, on Flickr
Leave for tomorrow and start sanding.
Edited by neil5208
I also have a nose interior that bulges the fuselage of my G. I'm about to trim the interior so that it fits, in order to lessen the need for filling the seam. Anyways, nice progress! V-P
Looking good !
I am still dry fitting my build and gently sanding the interior, as the Airfix kit is also very snug !
I would have liked to try the Airfix one but as this one was a present I couldn't say no. Does the Airfix kit have the wing cooler intakes?
It does but they fit poorly. I built the Revell model also. In my opinion they fit better than the Airfix example.
All the Best!
Don
A couple of sanding sessions later I have put some of the glazing in. Some further sanding need on the under side and the tail gunner position will need work and then onto wings!
32361014998_e4ec53d414_h.jpgIMGA0521 by neil Connor, on Flickr
I knocked the bomb sight off when fitting the glazing and will need to refit before the nose glass goes on
46233298431_bc7c1c185e_h.jpgIMGA0520 by neil Connor, on Flickr
32361015228_f126d90857_h.jpgIMGA0522 by neil Connor, on Flickr
Just one more week at work before the Christmas break starts so I should be able to get alot done then as the end date is creeping closer.
Edited by neil5208
Due to a broadband tech issue I haven't been able to upload since Saturday but it fixed today so this will be big update.
Round 3 of filling covered to poorly fitting rear tail gun section and the forward lower fuselage, the tail section was particularly bad.
31350315217_4783039424_h.jpgIMGA0525 by neil Connor, on Flickr
31350315967_74a6859c51_h.jpgIMGA0524 by neil Connor, on Flickr
31350315397_42ff1dcfa7_h.jpgIMGA0523 by neil Connor, on Flickr
The results from this round is not bad.
31350316297_9a05ed761a_h.jpgIMGA0531 by neil Connor, on Flickr
31350315557_6d0d4aa1fd_h.jpgIMGA0532 by neil Connor, on Flickr
The nose will need some further work but will be done once the front glazing is on, The tail planes are on but the elevators have not been glued as I don't know what the normal parked up position is. The bomb bay doors have been fitted and will need to be sanded flush as the fit was not good. Masking for the windows is almost done, tail gunners windows and front glazing.
44472173910_3254a0f3b0_h.jpgIMGA0533 by neil Connor, on Flickr
31350315007_91c87463ea_h.jpgIMGA0527 by neil Connor, on Flickr
44472173710_f0c182a2c8_h.jpgIMGA0526 by neil Connor, on Flickr
44472173850_e4f499de2f_h.jpgIMGA0534 by neil Connor, on Flickr
One wing is 80% done but again will require several rounds of filler before fitting
Edited by neil5208
Spray a quick silver coat, prefer silver to grey as I think it shows more defect than grey. Looks quite good with just a few issues to sort. The nose side pieces that incorporate the side windows both need filling and profiling as they don't follow very well.
31388937977_c03317b527_h.jpgIMGA0542 by neil Connor, on Flickr
46277576992_f0d71f4cdc_h.jpgIMGA0540 by neil Connor, on Flickr
44511281250_2e68fe3cf1_h.jpgIMGA0541 by neil Connor, on Flickr
46277577172_cdf23ea54d_h.jpgIMGA0539 by neil Connor, on Flickr
44511281330_f9c4cf74a7_h.jpgIMGA0538 by neil Connor, on Flickr
31388938367_660cc7bd46_h.jpgIMGA0537 by neil Connor, on Flickr
Looking good, Neil, but you’ve got the cheek glazing mixed up!
You’ve got the left on the right and vice-versa. Hopefully not too late to change?
Tom
That will probably help the fit issue too. Odd that they are symmetrical enough to be installed reversed. Hope those can be swapped easily.
I like the idea of silver primer. You're right that it reveals flaws better, and if you choose to "wear" your final coat there is silver underneath to be revealed.
Nose panesl have been refitted and seems to have been successful. Reworked the seams that needed further work, bomb bay doors have been filed just short of flush as some pictures show a less than perfect flush fit.
46291873752_ef9d5aa4d3_h.jpgIMGA0552 by neil Connor, on Flickr
46291874612_e8dfb80122_h.jpgIMGA0553 by neil Connor, on Flickr
46291874492_7042ff4fe7_h.jpgIMGA0554 by neil Connor, on Flickr
46291873572_0c09df93fb_h.jpgIMGA0555 by neil Connor, on Flickr
46291874332_0f2cbae587_h.jpgIMGA0556 by neil Connor, on Flickr
Hopefully can move onto the wings and engines soon,
Assembled the second wing this morning at last. Quick test fit shows they shouldn't have any fit issues, will move on to the engines tomorrow. Spray around all areas touched up last night as well.
32480346138_263115b24e_h.jpgIMGA0560 by neil Connor, on Flickr
46301775462_afccde7ac4_h.jpgIMGA0561 by neil Connor, on Flickr
46352479681_d746d8ba86_h.jpgIMGA0562 by neil Connor, on Flickr
46352482141_a5f94ae2cc_h.jpgIMGA0565 by neil Connor, on Flickr
Just need to check my stock of US underside grey as this one is going to need alot!
This one only just fits in my spray booth. Sprayed a grey primer layer last night to see if any further filling is needed before the proper colours go on, some minor touch ups on wing leading edges and engine cowls. Only thing to decide is if I go for pre shading or not.
45667991874_00e995e25a_h.jpgIMGA0578 by neil Connor, on Flickr
32519147308_c1255fb259_h.jpgIMGA0579 by neil Connor, on Flickr
32519147208_e6060e494f_h.jpgIMGA0573 by neil Connor, on Flickr
45667991754_39f84ef0c8_h.jpgIMGA0574 by neil Connor, on Flickr
Edited by neil5208
Looking very good, What colour are you going for on the underside? you mentioned U.S. underside grey is that from a specific range? the call outs on my Kitsworld decal sheet just reference a medium grey!
Mark.
