Brad Posted October 20, 2018 Share Posted October 20, 2018 This is the Hasegawa kit in 1/72. It's not a bad model, although I did have some issues fitting the engine nacelles that required a bit of filling and sanding, otherwise things went together well. Chinese markings come from the spares box with the fin flash being masked and painted. Surprisingly, the colour picture which my build is based on shows the aircraft in a reasonable condition, thus I chose not to highlight all the panel lines, just those around the engines as they appeared a bit grimey. I am lacking some white numbers on the tail, I couldn't find small enough decals in the spares. 15 1 Link to comment Share on other sites More sharing options...
Uncle Pete Posted October 20, 2018 Share Posted October 20, 2018 (edited) 8 minutes ago, Brad said: white numbers I have some white numbers left over from a Corsair... 167 in 2mm and 9mm and 530 in 2mm and 6mm. They are in a "stencil" font. You're welcome to them if they're any use. Edited October 20, 2018 by Uncle Pete 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted October 20, 2018 Share Posted October 20, 2018 That's come up lovely Brad, nice and clean and what appears to be a canopy masking nightmare - however you've won that battle. Cheers and well modelled.. Dave 1 Link to comment Share on other sites More sharing options...
Brad Posted October 20, 2018 Author Share Posted October 20, 2018 49 minutes ago, Uncle Pete said: I have some white numbers left over from a Corsair... 167 in 2mm and 9mm and 530 in 2mm and 6mm. They are in a "stencil" font. You're welcome to them if they're any use. Thanks mate. Unfortunately the numbers aren't stencil format. I might have to dig through the stash kits too lol. 1 Link to comment Share on other sites More sharing options...
Vinnie Posted October 20, 2018 Share Posted October 20, 2018 That's a really nice clean build, Brad. Impressive work on the clear parts framing.👍 1 Link to comment Share on other sites More sharing options...
Dazey Posted October 20, 2018 Share Posted October 20, 2018 Hi Brad, That's a nice Ki-48. May I ask what paint you used? I don't know anything about the Chinese colour schemes. Regards, David 1 Link to comment Share on other sites More sharing options...
Brad Posted October 20, 2018 Author Share Posted October 20, 2018 4 minutes ago, Dazey said: Hi Brad, That's a nice Ki-48. May I ask what paint you used? I don't know anything about the Chinese colour schemes. Regards, David Neither do I really, I just kinda picked some Japanese colours that looked similar to the colour picture. Lower surface is IJA Grey from Gunze and the upper is IJN Green Grey from Tamiya. 1 Link to comment Share on other sites More sharing options...
Dazey Posted October 20, 2018 Share Posted October 20, 2018 2 minutes ago, Brad said: Neither do I really, I just kinda picked some Japanese colours that looked similar to the colour picture. Lower surface is IJA Grey from Gunze and the upper is IJN Green Grey from Tamiya. OK, thanks. I know that the Hasegawa instructions use Gunze colour callouts, so that makes sense. Regards, David 1 Link to comment Share on other sites More sharing options...
