Welkin Posted October 14, 2018 Share Posted October 14, 2018 I am in the process of building four Tamiya 1:48 Beaufighters - Mk.IF; Mk.IIF (using CMK conversion); Mk.VIc; TF.X. The Mk.IF I want to build as John Cunningham's R-for-Robert, which from the attached photograph (courtesy of the internet) has a 'towel-rail' aerial under the fuselage - not supplied in the Tamiya kit. I am reasonable confident in the placing of this fore and aft, but I am not sure where it should be located laterally and am unable to find any drawings showing this. I assume that it is probably along the centreline, but cannot ignore the possibility that it might have been offset to one side? Can anyone help with this? Link to comment Share on other sites More sharing options...
Muddyf Posted October 14, 2018 Share Posted October 14, 2018 (edited) From what I have seen, they were offset to the Starboard side (right). There is a photo that shows this in the IWM archives. https://www.iwm.org.uk/collections/item/object/205208769 Hope this helps Edited October 14, 2018 by Muddyf Grammar Link to comment Share on other sites More sharing options...
Welkin Posted October 14, 2018 Author Share Posted October 14, 2018 Thanks Muddyf - I think that photograph gives me enough to get the correct location. Martin Link to comment Share on other sites More sharing options...
brewerjerry Posted October 15, 2018 Share Posted October 15, 2018 Hi I like what appears to be a nose roundel on the IWM beau photo cheers jerry 1 Link to comment Share on other sites More sharing options...
