Sign in to follow this
Xmald
Junkers D.I Wingnut Wings 1/32
My first experience with the Wingnut Wings kit is finished and I must admit it was a pure joy!
I`ve used TaurusModels engine goodies and my own hand-carved propeller with a resin hub by ProperPlane.
Painted mostly with Tamiya acrylics.
Just like looking at the real thing. Excellent photography as well.
Thoroughly impressive and superbly artistic work!
Kind regards,
Joachim
That's brilliant, so realistic. What paint did you use for the mauve and green on the wings?
Mick
Mick
Thanks! I`ve used the mix of Tamiya paints from the instruction - I don`t remember the ratio but I may look for it if you want.
First Class job! Extremely realistic work on the engine bay and just the right amount of weathering, chipping etc. Beautiful!
Yes Please. I use Tamiya myself so I may have the colours, can you let me also know the numbers?
Mick
Awesome job.
Have you painted the insignia or used decals - and if decals, how did you get them to sit so perfectly on the corrugated surfaces?
Nigel
Wow, what a beautiful job. I love the weathering, and the photography is great too!
John
Mick
the green is XF71
mauve X16 x1 + XF52 x1 +XF2 x 1
7 hours ago, nheather said:
Awesome job.
Nigel
I`ve used and tried all the solutions that I had but;) Microscale set and sol worked best, I still had to cut the decals in some places and do the touch-ups afterwards.
Excellent model and build and with accurate and no OTT weathering or 'chipping'; I like everything about this !
Gary
1 hour ago, sanfrandragon said:
 I don't know anything about woodwork; how do you hand carve the prop?
You need to make a plywood out of thin veneer sheets. And then you print the plans of the propeller you need, glue it to the plywood and carve it using blades and sanding paper. It`s very easy but rather time-consuming.
Superb work. Please tell a mundane modeller how you do the 'chipping'?
The whole model was sprayed with MR. Color 8 prior to painting the camo and the black fuselage. It allows you to use the toothpick and other tools to make the scratches. Some others are simply painted.
