On 8/20/2019 at 5:29 PM, beefy66 said:
From what could have been a disaster with the bow to a stunning build 👍🏻
beefy
Cheers Beefy, since starting the hobby again it's the closest I've come to giving up on a kit. If I hadn't bough all the AM bits I probably would of done.
Thanks all for the kind comments and likes.
Nick
Nick
As previously Nick, I did exactly the same thing, trying exactly the same thing, in exactly the same place. Mine is still a little bit iffy in that area by flat matt paint hide a sin here and there. Ish.
Gidday, I'm all in favour of that. On models too. 😇
     Seriously, I've used the dividing line between light and dark paint in dazzle camo to 'hide' a poor join, but that only works with whiffs or when the camo pattern is not specific.
I'm impressed that you didn't give up, whatever the reason. Regards, Jeff.
On 8/31/2019 at 8:59 PM, maurice northcott said:
Fantastic workmanship Nick 🙂
Thanks Maurice
Cheers Jeff
Bit more progress over the last week;
Mainmast signal halyards from fine Uschi line;
IMG_5082
Foremast Halyards;
IMG_5085
And the rest of the foremast rigging in standard Uschi;
IMG_5087
Boats and lockers fitted, along with the quad vickers;
IMG_5088 IMG_5088
And secondary armament;
IMG_5089
And finally the big guns!!!;
IMG_5091 IMG_5092
I decided to leave the storm wires on all the turrets even though they were probably removed in real life as I didn't want to risk damaging the finish.
She looks quite mean;
IMG_5093
I've been trying to figure out a way to reproduce the helm indicators on the mainmast halyards, 2 cones on the starboard and a ball on the port side.
IMG_5100
In the end I decided to try 3D printing - we'll see how they work out (the fairleads are for HMS Ark Royal when I get round to her - Crisp has found some missing from the kit!!)
IMG_5097
Rigging next and then sea base and crew.
Nick
Been a while (working away) but some pics below of slow progress over the last few months;
3D printed helm indicators turned out ok;
IMG_5117
The Aerial screen and trunk from the bottom of the main mast are missing so made these from a spare from Dreadnought and some 1mm rod with masking tape along with piles of timber, oars and resin crates, and coil of rope to busy things up a bit;
IMG_5113
Mainmast rigged (admirals flag to be fitted). At the base of the mast are the aerial cage and aerial trunk;
IMG_5242
Rigging between the masts done, mix of standard uschi line and caenis line;
IMG_5241
Bits and bobs added;
IMG_5240
IMG_5237 IMG_5236
Hull fitted to the base and wrapped in clingfilm to protect from the acrylic paste I'll use for the sea (won't try that again - more trouble than it was worth as it tended to leave a gap between the 'sea' and the ship, which had to be filled after the clingfilm was removed, thereby defeating the object);
IMG_5250
Sea painted in acrylics, ready for gloss medium and white oil pint for foam;
IMG_5261
Nick
48 minutes ago, ArnoldAmbrose said:
Gidday Nick, your detail is mind-boggling. This is truly a work of art. Regards, Jeff.
Second that stunning stuff
beefy
Well up to your habitually fantastic standard, Nick!  The boat covers are really effective; remind me how you did them again?  Was it paper or foil?
Thanks all for the kind comments.
Hi Crisp, extra thick tin foil, tried tissue paper but it didn't work out.
I'm following Ark, looks brilliant, just not finding much time to post.
Nick
IMO, there is no such thing as too many good looking HMS Hood models; good work! 👍
Seriously impressed with the level of detail you've achieved.
I must confess I'd be very nervous at wrapping a model in clingfilm to create the base with that much detail already on there - especially the rigging.  Although I do often wrap the hull in clingfil while I create the sea around it, I tend to do it much earlier on while the hull can be manhandled.
Was also interested to see the results you've achieved with Uschi line.  I've not tried that one but must give it a go.  The EZ line that I've used in the past is so tense that I find I have to put balanced tension across both sides or otherwise it just bends the mast/yard out of shape.
Thanks Chewie
I was very nervous 🙂
I was in two minds really, I like to keep the hull loose from the base whilst detailing and I've seen clingfilm used early and then the hull removed. This wouldn't work with Hood because the torpedo bulge would form an undercut with the sea. Clingfilm at the end seemed like the lesser of two evils given my habit of throwing acrylic paste everywhere but it didn't really work out.
Upcoming ships are all full hull so I think I'll go for the foam board method - although I can get my head round how you get an accurate waterline cutout?
I really like the Uschi line - 'Standard' for most lines, 'Fine' for signal halyards. Rarely use the 'Extra Fine' as it goes translucent under tension. The lines that I don't want to stretch i.e. stay as straight as possible with other bits of rigging pulling on them, are doubled up 700 denier Caenis line.
Nick
This is stunning work, I just keep being astounded by the detail.
I also appreciate the technique hints thrown in throughout, it means my lunch times at work are actually mildly productive rather than be just scrolling through pretty pictures of boats.
I've had the same problem, it's easy to over stretch the line when attaching the other end, and for something so fine it seem to have a lot of elastic strength in it
Thanks for the kind comments.
Cheers Joel, the techniques are almost all stuff I've picked up here or on other forum's.
I barely stretch the Uschi line; it only has to be just tight enough to not sag so that it looks tight if that makes sense
Bit more progress;
Bow waves installed - if that's the right word?
Cotton wool encased in clear acrylic gel (thanks Jamie @ Sovereign Hobbies for the advice). They'll be blended into the sea with white at the next stage;
IMG_5271
Clear Acrylic Gel applied to the sea;
IMG_5275
Rigged the boat boom which I keep forgetting to do;
IMG_5276
Admirals flag fitted;
IMG_5277
Nick
Nick, stunning job. Looks like nearly finish.
Thanks.  Almost the next job on BULOLO (when I can finally get back to it) is the rigging to I think I will have to invest in some Uschi line
Cheers Kris - nearly there!
White bits applied to the sea, various weights of white washes and highlights over the clear gloss medium;
Before;
IMG_5275
After;
IMG_5286
Few shots in natural light;
IMG_5288
IMG_5289
The bow wave needs a bit more work, then the crew.
Nick
