Julien Posted October 7, 2018 Share Posted October 7, 2018 US M911 C-HET With M747 Heavy Equipment Semi-Trailer (85519) 1:35 Hobby Boss via Creative Models Any army requires transporters for their heavy equipment, and in the US this is abbreviated to HET, which stands for Heavy Equipment Transport, so you hear the use of the phrase applied to a number of heavy-haulers. Tank transport is particularly heavy, with your average M1 Abrams weighing in around 60 tons. The M911 tractor unit was a product of the 70s and was initially paired with a trailer that had previously been used with the M746 that the M911 replaced. During the Gulf War the M911 saw extensive use pulling Abrams tanks from battle to battle, which exposed weaknesses in the tractor's mechanicals that led to its replacement by the M1070, from the same Oshkosh stable. The easiest way of telling them apart is the more streamlined grille of the M1070, versus the square shape of the M911. The Kit This is a completely new tooling from Hobby Boss, and arrives shortly after Meng have done the very same combo. It arrives in a large sturdy cardboard box, and once you open it up, you're greeted by a pretty comprehensive package: Their are 10 spures of caramac plastic, 1 clear spure, 3 cab parts, 1 large trailer bed part, 13 large tyres, 17 small tyres, 3 sheets of PE, chain, rope and cable as well as decals & masks for the cab windows. Construction starts with the cab chassis. Various arts are built up at first including the transmission, air reservoir, cross beams, and differentials. These parts can then be fitted into the chassis rails . Onto these are then added the parts for the suspension units. Once made up these and their power shafts are added to the chassis. The fuel tanks and side lockers are then built up and added. The wheels can then be built up and added. At the front the radiator units is added. Construction then moves onto the cab. Seats are made up and added to the cab floor. The dash is made up along with the steering column and this is added to the main cab unit. The floor is then added to the cab. The doors and various parts such as the mirrors, wipers, lights etc are added. The bonnet is then added and the cab can be added to the chassis. The bumper and grill can then be added at the front. Tot the side the air cleaner is added. To the rear of the cab the large winch and motor are made up and added, along with the spare wheel carrier and 5th wheel plate. PE mud flaps are added to the back. The exhaust and its PE shroud are fitted. Construction then moves onto the trailer. The lower fame work is made up from two side parts and the many cross members, plus rear support frame. The lower frame can then be added into the single part top frame. The air reservoirs are built up and added in. Side reinforcement plates are then added in in the underside. Also on the underside a mass of small parts are then added. The trailer axles are made up and added. These are followed by the wheels. The landing legs are made up and added to the front of the trailer. On the bed of the trailer the central bed plates are added along the rear loading ramps. The chain is to hold these ramps up. The trailer can then be added to the truck. Markings Despite this being a big model, it has a smallish decal sheet. markings are provided for 4 units; 257th Transportation Company (Dessert Yellow overall) 1st Armoured Division, 708th Support Battalion (Camo unit, Overall green trailer) 1st Armoured Division, 708th Support Battalion (Overall green truck & trailer) 2123rd Transportation Company (overall camo truck & trailer) Conclusion It's not a pocket-money kit by any stretch of the imagination, but the effort, attention to detail and care that has gone into the design makes it a worthy addition to your stash. Once built up it will make an impressive model. Online this Kit is fully 2/3 the price of the Meng Version. Very highly recommended. Review sample courtesy of 2 Link to comment Share on other sites More sharing options...
harvey1847 Posted October 15, 2019 Share Posted October 15, 2019 WOW! Is there actually any other topic that actually explain how to build a Truck or a Semi-trailer!? Am I the only one on Britmodeller actually building one of these? Sorry but still getting familiar with the forum... Daniel Link to comment Share on other sites More sharing options...
Julien Posted October 15, 2019 Author Share Posted October 15, 2019 2 hours ago, harvey1847 said: WOW! Is there actually any other topic that actually explain how to build a Truck or a Semi-trailer!? Am I the only one on Britmodeller actually building one of these? Sorry but still getting familiar with the forum... Daniel You need to look in Work In Progress Armour. Or Civilian Vehicles. Link to comment Share on other sites More sharing options...
armored76 Posted June 27, 2020 Share Posted June 27, 2020 Sorry if this is obvious to you, guys but not being a US-subject modeller, I'll have to ask... what loads would go with this truck? I think any M60 would be a match probably but what else? The Abrams's are probably not the same generation, right? Many thanks in advance! Cristian Link to comment Share on other sites More sharing options...
Julien Posted June 27, 2020 Author Share Posted June 27, 2020 Its been around for a while so M60, Abrams, Bradley, Striker, M113 you can use them all, some are even in civilian hands now; 1 Link to comment Share on other sites More sharing options...
armored76 Posted June 27, 2020 Share Posted June 27, 2020 Thank you, Julien! The one carrying the bulldozer looks really nice. 1 Link to comment Share on other sites More sharing options...
