Shar2 Posted October 7, 2018 Share Posted October 7, 2018 USS Enterprise CVN-65 Eduard 1:350 The Tamiya 1:350 CVN-65 USS Enterprise was released as far back as 1984. It was the first aircraft carrier in 1:350 I had seen, so had to buy it, only a week after it was released, the first model I used an airbrush, and I still have it, although in a rather poor condition, this was also the year I joined the Royal Navy, and it became the centrepiece for many a Captains rounds, distracting the inspecting party from doing any actual inspecting. For some reason it has been ignored by Eduard, but they have finally released the first of a number of sets for the venerable old kit. As usual, there are many small parts and a number of kit details that will need to be removed before the PE parts can be added. Ships Boats and Liferafts, (53-223). This single sheet set contains an awful lot of parts, but for only a couple of areas, namely all the emergency liferaft canisters that are hung around the edges of the flightdeck and the ships boats. The Liferafts in the kit come as runs of anything between two and five rafts, these will need to be separated and cleaned up of the joints. The racks are then folded to shape and glued to separate backing plates, before the liferafts can be added and the whole assembly attached to the model. The backing plates are joined together by a thin length of PE and come in sections of two, three, four and five plates. With the number of liferafts in the kit, this could get rather laborious, and certainly time consuming; but the effect will be worth it. The ships open boat will need to have its centre section hollowed out carefully before the new engine casing, control lectern and wheel can be added, as well as the waist thwart that goes around the inside of the boat, followed by the fore and aft decking, and gunwhales, which are as one piece, is attached. The pinnace is also modified, with eh removal of all the top hamper, then opened up, the new, carefully folded PE is then glued into place and additional details such as the railings, windshield, propeller skeg, propeller and rudder are attached. Conclusion It’s about time this fabulous kit got the Eduard treatment, I know other companies have released etch for it, mostly before I even knew PE existed, but I find some companies PE rather too fragile and thin. I look forward to the next releases as they might give me the impetuous to take my old kit and give it a good refurbishing, and hope the skills I have learnt in the intervening years will be put to good use. Review sample courtesy of 2 Link to comment Share on other sites More sharing options...
prowler0000 Posted October 7, 2018 Share Posted October 7, 2018 (edited) Part 2 is pretty much exclusively for the airwing, Part 3 is mainly the island & the CIWS areas. Edited October 7, 2018 by prowler0000 Link to comment Share on other sites More sharing options...
