Sign in to follow this
Shar2
Type VII U-Boat, Model Warship Builder Cartoon Ship
Type VII U-Boat
Meng Model Warship Builder Cartoon Ship
Normally we review highly detailed models of famous ships and submarines but in this instance, give your pedantry about colours and accuracy a rest and feast your eyes on this cartoon Type VII U-Boat.
The Model
The model comes in a small but quite deep box with an artists impression of the submarine cruising underwater scaring the local fish. Inside there are four sprues of dark and light grey styrene, a black styrene stand and a small decal sheet. Whilst it is a cartoon model the parts are nicely moulded with no sign of flash, which is a good thing as it appears to be more of a snap together kit rather than a glue it together one, although you might want to glue it together just in case it decides to fall apart.
Construction, as you’d be right to guess, is very simple, the two inner hull parts are joined together followed by the two upper hull sections. One of the lower hull sections is then fitted with two pegs, the two sections are then fitted to the previous assembly with the separate keel sandwiched between them. The anchor, forward dive planes, propeller shafts and propellers are next to be attached. Strangely, even though it’s a cartoon, no aft diveplanes are included. The three deck sections are then fitted into position along with the wire cutter at the bow and the two railings, one on either side of the tower, which is the next part to be attached. The two, two piece periscopes are fitted, as are the tower mounted 20mm cannon and the two piece deck gun. The completed model can then be displayed ont eh provided stand.
Decals
The single sheet of decals provides items for four different emblems.  The decals are nicely produced with good register and slightly matt. The nameplate that goes on the stand is of the self adhesive type sticker.
Conclusion
Well, what can I say about this kit? It will certainly be something different in your display cabinet and will be quite a fun build that should take all of 10 minutes to build and  a bit longer to paint. It will be good for a bit of fun after a day on a bigger build and would be great for a child to start modelling with. I think it’s a little pricey, but you should be able to get it cheaper if you look around.
Review sample courtesy of
I have built one of these they are great fun, the fit is superb, just requiring a little force in places to put together.
All the best Chris
