Julien Posted September 24, 2018 Share Posted September 24, 2018 North American P-51D Mustang "Yellow Nose" (LS-009) 1:48 Meng Model via Creative Models Originally developed to fulfil a British requirement for new fighter aircraft, the unmistakable North American P-51 Mustang famously went from drawing board to first flight in just 178 days. It went on to become one of the most famous and successful aircraft of the Second World War. Transformed by the addition of Rolls Royce’s legendary Merlin engine, the Mustang went from strength to strength and was eventually developed into several variants. The P-51D introduced a number of improvements in response to combat experience, including a cut-down rear fuselage and bubble canopy and an increase in the number of 0.5 inch machine guns from four to six. Over 8000 P-51Ds were produced, more than any other Mustang variant. The Kit This new tooled P-51D from Meng is designed as a "snap together" kit and Meng trumpet it can be put together without glue. As such the kit is designed in a different way than your standard kit. There are more tabs and inserts and construction varies from a standard kit. Having spoken to a couple of modellers who have built the kit it certainly does go together without glue, however the modeller it would seem would be wise to glue it as they go. The kit arrives on five sprues of dark grey plastic and a clear sprue. Construction starts its seems in the conventional way with the cockpit. The front fire wall and instrument coaming are assembled with the rudder pedals clipping it. The radio area behind the pilot is installed onto the cockpit floor. The control column is added and the seat made up, then fitted. Moving on to the fuselage sides, side panels are added, then the tail wheel well & wheel are made up and attached. A couple of insert parts are attached and then the fuselage can be closed up. The propeller is then made up fro two sets of two bladed added to hub. The top engine cowl part is added along with the exhausts (2 different types being provided). Construction then moves onto the wings. The landing gear complete with wheels are added into the gear bay, this is then inserted into the rear wing. The flaps (down position only) are then added into the lower wing, and the whole thing is trapped by the addition of the upper wing. Inserts are provided on the leading edge for the guns. The cowling under the main engine is then added to the fuselage. The main ventral radiator assembly is then made up, the wing installed and then the radiator installed. Next the gear doors are installed (either up or down) and the rear scoop for the radiator added. Underwing stores are made up and installed. There is a choice for 100lb bombs, 75 Gal & 108 Gal drop tanks. Lastly the frame is added inside the canopy and its installed, followed by a top fuselage insert, the tailplanes and the rudder. Markings Two options are provided on a sheet made in house by Meng. 308 FS, 31 FG 44-15459 (Capt. John Voll) 356 FS, 354 FG, 9 AF 44-15622 (Capt. Richard Turner) Conclusion Recommended if you want something a bit different, or you would like a project that snaps together, however I wont be replacing any of my other Mustang kits with this one. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
