Argosy 1:72 Mach 2
Reebo
That looks ace ,made my day . What are these motors you've used ? We had the Whistling T** in bay 1 Base Hangar , Brize on servicing from about 76 ish ,115 Sqn.
I'm with the others ,need more pics pleeeese , Paint looks really good . Well done !
Thanks for the kind comments. I’ll try and upload some more photos and a video.
The sensor is a ‘Sensky SK010 PIR.... (£7 from Amazon) It operates between 4v and 25v and works well with the 6v supply I feed through it.  The motors are ‘3.7v 22500rpm 1mm shaft coreless’ £3 for 5 from ebay.  The four engines are wired via a 1kohm variable pot adjustable through the rear cargo doors.  It’s set about midway (this was adjusted last to give the best speed after all other wiring had been completed). So the 6v supply is cut down to about 3v and shared between the 4 motors in series, so less than 1v each.
9
photoshoped1
photoshopped2
  • Like 9
  • Thanks 2
