rockpopandchips Posted September 19, 2018 Share Posted September 19, 2018 I ask as I have ordered a very cheap brush from China ( before they close the borders in the UK) just for fun really. One of These And I was thinking how much difference does the needle make, so I ordered the 0.2 brush so I can try out my H&S needle in the cheep brush and the cheep needle in the H&S. Not even sure they will fit but what the hell, anyone know if needles of the same size are interchangeable? Brian. Link to comment Share on other sites More sharing options...
Stew Dapple Posted September 19, 2018 Share Posted September 19, 2018 I can't speak for the H&S needles, but I did try out the needle of a cheap Chinese airbrush in my Badger 150 and the needle fitted well enough (though it was a bit longer, not enough to make a difference) but the taper on the needle was a different length so it produced a different (and unsatisfactory) spray pattern. Give it a try anyway, as long as the diameter is the same all you risk is disappointment... Cheers, Stew 1 Link to comment Share on other sites More sharing options...
bmwh548 Posted September 19, 2018 Share Posted September 19, 2018 Make sure you check the needle diameter first (the two Chinese airbrushes I have are different in that department, didn't try it against the H&S). You don't want to spend your day cleaning paint out of the air valve area. 1 Link to comment Share on other sites More sharing options...
Bigdave22014 Posted September 22, 2018 Share Posted September 22, 2018 Another issue is the needles aren't finished to the same quality. Have a close look with a magnifying glass and they are usually rough as old ****holes. I polish mine with Tamiya Fine polishing compound. The more you polish, the smoother they get, the better the spray pattern. 1 Link to comment Share on other sites More sharing options...
Robbyrockett Posted September 23, 2018 Share Posted September 23, 2018 They vary a lot, taper angle, surface finish, diameter, and taper profile. But yes most .2 will be a 1.2mm shaft And basically they will work. How well??? That's always the question. Doesn't make as much difference as nozzles usually but it does make a significant difference. Chinese nozzles usually fit iwata HP plus or procon boys ( which use identical nozzles). But the Chinese nozzles are horrible. 1 Link to comment Share on other sites More sharing options...
